查看: 3569|回复: 4
按一下按键数码管显示0到F的单片机程序 求帮助
  1. #include<reg51.h>
  2. sbit k1=P1^1;
  3. unsigned int code shumaguan[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  4.      0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  5. void delay (unsigned int i)
  6. {
  7.    while(i--);
  8. }
  9. void main()
  10.     {
  11.       unsigned int i;
  12.    if(k1==0)
  13.   {
  14.     while(!k1)
  15.    for(i=1;i<=16;i++)
  16.     {
  17.     P0=shumaguan[i];
  18.     delay(1000);
  19.    }
  20.   }
  21.
  22. }
ID:430574 发表于 2018-12-5 20:52 | 只看该作者
怎么按一下让数字显示1再按一下显示2这样到F
ID:438858 发表于 2018-12-8 14:07 | 只看该作者
#include<reg52.h>
sbit led=P1^0;
sbit key=P3^0;
sbit sw=P3^6;
void Delay10ms();
        unsigned char temp=0xf0;
                if(sw==0)
                        Delay10ms();
                        if(sw==0)
                                temp++;
                                P2=temp;
                                while(!sw);         //等待按键释放
void Delay10ms()                //@11.0592MHz
        unsigned char i, j;
        i = 108;
        j = 145;
        do
                while (--j);
        } while (--i);
ID:442260 发表于 2018-12-8 17:23 | 只看该作者
  2. sbit k1=P1^1;
  3. unsigned char P0;
  4. unsigned int code shumaguan[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  5.      0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  6. void delay(unsigned int times) //延迟1ms
  7. {
  8.         unsigned int i,j;
  9.         for(i=0;i<times;i++)
  10.         {for(j=0;j<124;j++);}
  11. }
  12. void main()
  13. {
  14.        unsigned char i;
  15.        while(1)
  16. {
  17.        if(k1==1)
  18.        {
  19.           while(k1);//k1仍在按下时间内空操作
  20.           P0=shumaguan[i];//按键松开瞬间执行端口赋值
ID:442293 发表于 2018-12-8 18:14 来自触屏版 | 只看该作者
Eureka!Eureka! 发表于 2018-12-8 17:23
动态显示
