查看: 4982|回复: 0
51单片机智能车红外循迹源程序
ID:441175 发表于 2018-12-6 19:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
/***********循迹声明*************/
sbit  led_1 = P0^6;
sbit  led_2 = P0^5;
sbit  led_3 = P0^4;
sbit  led_4 = P0^3;
sbit  led_5 = P0^2;
sbit  led_6 = P0^1;
sbit  led_7 = P0^0;
/**************电机声明************/
sbit  left_frontmotor_in1 = P1^0;
sbit  left_frontmotor_in2 = P1^1;
sbit  left_backmotor_in1 = P1^2;
sbit  left_backmotor_in2 = P1^3;
sbit  right_frontmotor_in1 = P1^6;
sbit  right_frontmotor_in2 = P1^7;
sbit  right_backmotor_in1  = P1^4;
sbit  right_backmotor_in2  = P1^5;
float val;
void Turn_Left(int x);       //左轮直走
void Turn_Right(int x);      //右轮直走
void Straight(int x);
void Xunji(void);
void delay_ms(int n)
        unsigned int i,y;
        for(i=n;i>0;i--)
        for(y=114;y>0;y--);
int main(void)
                 Xunji();
                if(val==0) Straight(10);
                else if(val>0){Turn_Right(30);Turn_Left(30-val*10);}
                        else if(val<0){Turn_Right(30+val*10);Turn_Left(30);}
        left_frontmotor_in1 = 1;
        left_backmotor_in1 = 1;
        delay_ms(x);
        left_frontmotor_in1 = 0;
        left_backmotor_in1 = 0;
    left_frontmotor_in2 = 0;
    left_backmotor_in2 = 0;
        right_frontmotor_in1 = 0;
    right_frontmotor_in2 = 0;
    right_backmotor_in1 = 0;
    right_backmotor_in2 = 0;
        delay_ms(30-x);
        right_frontmotor_in1 = 1;
    right_backmotor_in1 = 1;
        delay_ms(x);
        delay_ms(30-x);
        delay_ms(x);
        delay_ms(30-x);
void Xunji(void)
        int p;
        p=P0&0x7f;
        switch(p)
                case 0X7f:val=0;break;                //111 1111
                case 0X77:val=0;break;                //111 0111
                case 0X6F:val=2.3;break;                //110 1111
                case 0X7B:val=-2.3;break;                //111 1011
                case 0X5F:val=2.5;break;                //101 1111
                case 0X7D:val=-2.7;break;                //111 1101
                case 0X3F:val=3;break;                //011 1111
                case 0X7E:val=-3;break;                //111 1110
//        if(led_1==1&&led_2==1&&led_3==1&&led_4==0&&led_5==1&&led_6==1&&led_7==1) val=0;
//        if(led_1==1&&led_2==1&&led_3==0&&led_4==1&&led_5==1&&led_6==1&&led_7==1) val=1;
//        if(led_1==1&&led_2==1&&led_3==1&&led_4==1&&led_5==0&&led_6==1&&led_7==1) val=-1;
//        if(led_1==1&&led_2==0&&led_3==1&&led_4==1&&led_5==1&&led_6==1&&led_7==1) val=2;
//        if(led_1==1&&led_2==1&&led_3==1&&led_4==1&&led_5==1&&led_6==0&&led_7==1) val=-2;
//        if(led_1==0&&led_2==1&&led_3==1&&led_4==1&&led_5==1&&led_6==1&&led_7==1) val=3;
//        if(led_1==1&&led_2==1&&led_3==1&&led_4==1&&led_5==1&&led_6==1&&led_7==0) val=-3;
收藏收藏2 分享淘帖 顶顶 踩踩
