查看: 2464|回复: 1
萌新感觉51单片机想从00~99累加显示好难,有没有大佬指教指教
ID:441558 发表于 2018-12-7 11:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<hjc52.h>
#define DataPort P0
//sbit DataPort0=P0^0  ;
//sbit DataPort1=P0^1  ;
#define uint  unsigned int
uchar num1,num2;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,
                    0x6d,0x7d,0x07,0x7f,0x6f
uchar code aable[]={
     0xfe,0xfd};
void delayms(uint);
  for(num1=0;num1<10;num1++) //
    WE=1; //??u2?????
    P0=0xfe; //????λ????
    WE=0; //???u2?????
    // delays(1);
    DU=1; //??u1?????
    P0=table[num1%10]; //?????????
    DU=0; //???u1?????
    delayms(30);
    for(num1=0;num1<100;num1++) //
    WE=1; //??u2?????
    P0=0xfd; //????λ????
    WE=0; //???u2?????
    // delays(1);
    DU=1; //??u1?????
    P0=table[num1/10]; //?????????
    DU=0; //???u1?????
    delayms(10);
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)
    for(j=1000;j>0;j--);
//hjc52.h
#ifndef hjc52_H
#define hjc52_H
sbit LED0 =P1^0;
sbit LED1 =P1^1;
//sbit DU =P2^0;  //HJ-C52
//sbit WE =P2^1;  //HJ-C52
sbit DU =P2^6;  //HL-1
sbit WE =P2^7; //HL-1
sbit FM =P1^2; //P2.3  HL-1
sbit EN =P2^5; //LCD1602
sbit RST =P1^2; //DS1302
#endif
ID:213173 发表于 2018-12-7 21:26 | 只看该作者
#include<reg52.h>
uint num;
                    0x6d,0x7d,0x07,0x7f,0x6f};
void delayms(uint);
                for(num=0;num<10000;num++)
                        P0=0x00;
                        DU=1;
                        DU=0;
                        P0=0xfe;
                        WE=1;
                        WE=0;
                        P0=table[num/100%10];
                        DU=1;
                        DU=0;
                        delayms(2);
                        P0=0x00;
                        DU=1;
                        DU=0;
                        P0=0xfd;
                        WE=1;
                        WE=0;
                        P0=table[num/1000%10];
                        DU=1;
                        DU=0;
                        delayms(2);
        uint i,j;
        for(i=xms;i>0;i--)
            for(j=120;j>0;j--);
