查看: 4809|回复: 1
用液晶显示的时钟不能正确设置光标闪烁!
ID:35471 发表于 2012-4-23 21:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
程序如下,按下into0键后显示情况如图(附件)
#include<reg52.h>
#include<51hei.h>
uchar code table1[]=" 2012-04-23 TUR";
uchar code table2[]="    00:00:00";
sbit duan=P2^6;
sbit wei=P2^7;
sbit lcdrs=P3^5;
sbit lcden=P3^4;
//sbit key=P3^7;
sbit key1=P3^2;
sbit key2=P3^6;
sbit key3=P3^7;
uchar count,shi,fen,miao,keynum;
void delay(uint z)
 uint x,y;
 for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void write_cmd(uchar cmd)
 lcdrs=0;
// lcden=0;
 P0=cmd;
 delay(5);
 lcden=1;
 delay(5);
 lcden=0;
void write_dat(uchar dat)
 lcdrs=1;
// lcden=0;
 P0=dat;
 delay(5);
 lcden=1;
 delay(5);
 lcden=0;
void init()
 uchar num;
 guandz();
 guanled();
 duan=0;
 wei=0;
 lcden=0;
 keynum=0;
// miao=59;
// fen=58;
// shi=23;
 write_cmd(0x38);
 write_cmd(0x0c);
 write_cmd(0x06);
 write_cmd(0x01);
 write_cmd(0x80);
 for(num=0;num<15;num++)
  write_dat(table1[num]);
  delay(20);
 write_cmd(0x80+40);
 for(num=0;num<12;num++)
  write_dat(table2[num]);
  delay(20);
 TMOD=0X01;
 TH0=(65536-50000)/256;
 TL0=(65536-50000)%256;
 EA=1;
 ET0=1;
 TR0=1;
void write_sfm(uchar add,uchar dat)
 uchar shi,ge;
 shi=dat/10;
 ge=dat%10;
 write_cmd(0x80+0x40+add);
 write_dat(0x30+shi);
 write_dat(0x30+ge);
void keyscan()
// key=0;
 if(key1==0)
  delay(5);
  if(key1==0)
   keynum++;
   while(!key1);
   if(keynum==1)
    TR0=0;
    write_cmd(0x80+0x40+11);
    write_cmd(0x0f);
   if(keynum==2)
    write_cmd(0x80+0x40+8);
   if(keynum==3)
    write_cmd(0x80+0x40+5);
   if(keynum==4)
    keynum=0;
    write_cmd(0x0c);
    TR0=1;
 init();
  keyscan();
  if(count==20)
   count=0;
   miao++;
   if(miao==60)
    miao=0;
    fen++;
    if(fen==60)
     fen=0;
     shi++;
     if(shi==24)
      shi=0;
    write_sfm(4,shi);
   write_sfm(7,fen);
  write_sfm(10,miao);
void timer0() interrupt 1
 count++;
ID:35471 发表于 2012-4-23 21:29 | 只看该作者
找不到附件了,我描述一下吧! 按下键后光标在00:00:▋▋▋的后三位(不知道怎么多出了一位)闪烁!计时停止。
