查看: 1082|回复: 0
1602显示,适用于单片机初学者,
ID:368128 发表于 2018-12-9 08:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//单片机类型STC89C52,晶振频率11.0592MHz,部分注释复制时乱码。。。
#include<reg52.h>
sbit lcden=P3^4;
sbit rs=P3^5;
sbit rw=P3^6;
sbit dula=P2^6;
sbit wela=P2^7;
   uchar table1[]="0123456789ABCDEF ";//?????
   uchar table2[]="ABCDEFGHIG ";//?????
void delay(uint x)
uint a,b;
for(a=x;a>0;a--)
  for(b=10;b>0;b--);
void write_com(uchar com)    //д????
P0=com;
rs=0;           //д????
lcden=0;
delay(10);
lcden=1;
delay(10);
lcden=0;
void write_date(uchar date) //д????
P0=date;
rs=1;           //д????
lcden=0;
delay(10);
lcden=1;
delay(10);
lcden=0;
void init()
    rw=0;
dula=0;
wela=0;
write_com(0x38);   //??????????16??2?????5??7????8λ??????
delay(20);
write_com(0x0f);   //?????????
delay(20);
write_com(0x06);   //?????????????????????????
delay(20);
write_com(0x01);   //?????????????????????????
delay(20);
    uchar a,b0;
init();
     write_com(0x80);//??????????????????????????????????????????        //delay(2000);
     delay(20);
  for(a=0;a<16;a++)
         write_date(table1[a]);
         delay(20);
         //delay1(200);
    write_com(0xc0);//???????????????????0xc5?????????6??
     delay(20);  b0=47;
    for(a=0;a<15;a++)
              write_date(b0);//b0=ASCLL num;
   //write_date(table2[a]);
         delay(20);
         b0++;
while(1);//???????????
