查看: 3540|回复: 0
单片机矩阵式键盘输入识别程序
矩阵式键盘输入识别
编写 c 语言程序,设计一个 4X4 的矩阵键盘,键盘的号码 0~15,要求编写出一个键盘输入扫描程序,要求单片机能根据键盘排列顺序,能将按下去键盘号正确识别出来
  1. #include<reg51.h>
  2. #define uint unsigned int
  3. sbit P14=P1^4;
  4. sbit P15=P1^5;
  5. sbit P16=P1^6;
  6. sbit P17=P1^7;
  7. unsigned char code
  8. Tab[ ]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  9. unsigned char keyval;
  10. void delay(uint z)
  11. {
  12.         uint x,y;
  13.         for(x=z;x>0;x--)
  14.                 for(y=110;y>0;y--);
  15. }
  16.   void display(unsigned char k)
  17. {  P2=1;
  18.    P0=Tab[k/10];
  19.          P2=0x7f;
  20.    delay(5);
  21.          P2=1;
  22.    P0=Tab[k%10];
  23.    P2=0xbf;
  24.    delay(5);
  25. }
  26. void delay20ms(void)
  27. {
  28.    unsigned char i,j;
  29. for(i=0;i<100;i++)
  30.   for(j=0;j<60;j++)
  31.            ;
  32. }
  33. void main(void)
  34. {
  35.    EA=1;
  36. ET0=1;
  37. TMOD=0x01;
  38. TH0=(65536-500)/256;
  39. TL0=(65536-500)%256;
  40. TR0=1;
  41. keyval=0x00;
  42.
  43. while(1)
  44.   {
  45.     display(keyval);
  46.   }
  47. }
  48.   void time0_interserve(void) interrupt 1 using 1
  49.   {      TR0=0;
  50.      P1=0xf0;
  51.    if((P1&0xf0)!=0xf0)
  52.       delay20ms();               if((P1&0xf0)!=0xf0)
  53.      {
  54.         P1=0xfe;
  55.         if(P14==0)                     keyval=1;
  56.            if(P15==0)
  57.              keyval=2;
  58.            if(P16==0)
  59.              keyval=3;
  60.            if(P17==0)
  61.                                                   keyval=4;                       P1=0xfd;
  62.        if(P14==0)
  63.              keyval=5;
  64.            if(P15==0)
  65.              keyval=6;
  66.            if(P16==0)
  67.              keyval=7;
  68.            if(P17==0)
  69.              keyval=8;
  70.              P1=0xfb;            if(P14==0)
  71.              keyval=9;
  72.            if(P15==0)
  73.              keyval=10;
  74.            if(P16==0)
  75.              keyval=11;
  76.            if(P17==0)
  77.              keyval=12;
  78.            P1=0xf7;
  79.      if(P14==0)
  80.              keyval=13;
  81.            if(P15==0)
  82.              keyval=14;
  83.            if(P16==0)
  84.              keyval=15;
  85.            if(P17==0)
  86.              keyval=16;
  87.        }
  88.                   TR0=1;
  89.      TH0=(65536-500)/256;
  90.    TL0=(65536-500)%256;
  91. }
矩阵式键盘识别.zip (72.6 KB, 下载次数: 22)
