查看: 1926|回复: 2
这个超声波测距的程序能有人讲解一下么,有点看不太懂
ID:429467 发表于 2018-12-12 10:51 来自触屏版 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<REG52.H>#include<intrins.h>#define uint unsigned int#define uchar unsigned charsfr ISP_CON=0xe7; sbit IO=P1^0;sbit CS=P2^1;sbit CLK=P2^2;sbit DAT=P2^0;uint juli,i;bit flag;void delay(uint i){        uint j,k;        for(j=i;j>0;j--)                for(k=0;k<114;k++);}void send(uchar add,uchar dat){        uchar i;        CS=0;        for(i=0;i<8;i++)        {                CLK=0;                DAT=(bit)(add&0x80);                add<<=1;                CLK=1;        }        for(i=0;i<8;i++)        {                CLK=0;                DAT=(bit)(dat&0x80);                dat<<=1;                CLK=1;        }        CS=1;}void dis(){        send(1,0);        send(2,0);        send(3,0);        send(4,0);        send(5,0);        send(6,juli/100);          send(7,(juli/10)%10);        send(8,juli%10);}void launch(){                uchar i;        for(i=0;i<50;i++)        {                IO=0;                _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();                IO=1;                _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();        }}void init(){        TMOD=0x01;        TH0=0,TL0=0;        IT0=1;        EA=1;        send(0x09,0xff);        send(0x0b,0x07);                         send(0x0a,0x0f);        send(0x0c,0x01);        send(0x0f,0x00);}void main(){        init();        dis();        while(1)        {                do                {                        IO=1;                        TH0=0,TL0=0;                        EX0=1;                        TR0=1;                        launch();                        delay(10);                }                while(flag==0);                flag=0;                        juli=(i/2)*0.033;                dis();                 delay(500);                 ISP_CON=0x60;          }}void int0() interrupt 0{        TR0=0;        EX0=0;        flag=1;        i=(TH0*256)+TL0;}
收藏收藏1 分享淘帖 顶 踩
ID:338671 发表于 2018-12-12 12:33 | 只看该作者
有点心整理一下再发出来好吗,建议截图发,
ID:429467 发表于 2018-12-12 12:57 来自触屏版 | 只看该作者
#include<REG52.H>
#include<intrins.h>
sfr ISP_CON=0xe7;
sbit IO=P1^0;
sbit CS=P2^1;
sbit CLK=P2^2;
sbit DAT=P2^0;
uint juli,i;
bit flag;
void delay(uint i)
uint j,k;
for(j=i;j>0;j--)
for(k=0;k<114;k++);
uchar i;
CS=0;
for(i=0;i<8;i++)
CLK=0;
add<<=1;
CLK=1;
for(i=0;i<8;i++)
CLK=0;
dat<<=1;
CLK=1;
CS=1;
void dis()
send(1,0);
send(2,0);
send(3,0);
send(4,0);
send(5,0);
send(6,juli/100);
send(8,juli%10);
void launch()
uchar i;
for(i=0;i<50;i++)
void init()
TMOD=0x01;
TH0=0,TL0=0;
IT0=1;
EA=1;
send(0x09,0xff);
send(0x0b,0x07);
send(0x0a,0x0f);
send(0x0c,0x01);
send(0x0f,0x00);
init();
dis();
do
IO=1;
TH0=0,TL0=0;
EX0=1;
TR0=1;
launch();
delay(10);
while(flag==0);
flag=0;
juli=(i/2)*0.033;
dis();
delay(500);
ISP_CON=0x60;
TR0=0;
EX0=0;
flag=1;
i=(TH0*256)+TL0;
