查看: 8824|回复: 9
我想用单片机矩阵键盘控制led点阵显示数字(每个按键控制一个数字),写了一点就是...
#include<reg52.h>
typedef unsigned int u16;
typedef unsigned char u8;
//--定义要使用的IO口--//
#define READPORTS P1
#define GPIO_KEY P2
#define COMMONPORTS P0
u8 KeyValue;
void delay(u16 i){
    while(i--);
void KeyDown(void){
    char a=0;
    GPIO_KEY=0x0f;
    if(GPIO_KEY!=0x0f){
        delay(1000);
        if(GPIO_KEY!=0x0f){
            GPIO_KEY=0X0F;
            switch(GPIO_KEY){
                case(0X07): KeyValue=0;break;
                case(0X0b): KeyValue=1;break;
                case(0X0d): KeyValue=2;break;
                case(0X0e): KeyValue=3;break;
            GPIO_KEY=0XF0;
            switch(GPIO_KEY){
                    case(0X70): KeyValue=KeyValue;break;
                    case(0Xb0): KeyValue=KeyValue+4;break;
                    case(0Xd0): KeyValue=KeyValue+8;break;
                    case(0Xe0): KeyValue=KeyValue+12;break;
            while((a<50)&&(GPIO_KEY!=0xf0)){
                delay(1000);
                a++;
//--列选通控制--//
unsigned char code TAB[8] = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
//--点阵字码--//
unsigned char code CHARCODE[16][8] = {
{0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0
{0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1
{0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2
{0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3
{0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4
{0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5
{0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6
{0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7
{0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8
{0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00}, //9
{0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00}, //P
{0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00}, //R
{0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00}, //E
{0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00}, //C
{0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00}, //H
{0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00}, //I
void main(){
    unsigned char tab, j;
    unsigned int  i;//无符号整数
    while(1){
        for(i= 0; i<5000; i++ ){//两个字之间的扫描间隔时间
            for(tab=0;tab<8;tab++){
                KeyDown();
                READPORTS=0xFF;//消隐
                COMMONPORTS=CHARCODE[KeyValue][tab];//输出字码
                READPORTS=TAB[tab];
        j++;
        if(j == 16){
            j = 0;
ID:445287 发表于 2018-12-12 22:56 | 只看该作者
哪位大神帮我看看
ID:94031 发表于 2018-12-13 07:37 | 只看该作者
1 程序是否和硬件不配套。
2 查硬件供电是否正常。
ID:164602 发表于 2018-12-13 08:16 | 只看该作者
你大概没有搞清楚你的板子的点阵电路吧!
你的这个板子上,8*8点阵,是这样连接的:
你的程序中,一点届没有看到控制595的程序,点阵当然是不会亮的了。
给你一个示例程序,点阵显示一些数字字符:
#include<reg51.h>
#include<intrins.h>
sbit SRCLK=P3^6;
sbit RCLK=P3^5;
sbit SER=P3^4;
//--定义要使用的IO口--//
//--列选通控制--//
//--点阵字码--//
unsigned char code CHARCODE[18][8]=
{0x00,0x7F,0x10,0x08,0x04,0x7F,0x00,0x00}, //N
{0x7C,0x48,0x48,0xFF,0x48,0x48,0x7C,0x00}  //中
void delay(unsigned int time)
  unsigned int i,j;
  for(i=0;i<time;i++)
    for(j=0;j<121;j++);
* 函数名         : Hc595SendByte(unsigned char dat)
* 函数功能                   : 想74H595发送一个字节的数据
* 输入           : 无
* 输出                  : 无
void Hc595SendByte(unsigned char dat)
        unsigned char a;
        SRCLK=0;
        RCLK=0;
        for(a=0;a<8;a++)
                SER=dat>>7;
                dat<<=1;
                SRCLK=1;
                _nop_();
                _nop_();
                SRCLK=0;
        RCLK=1;
        _nop_();
        _nop_();
        RCLK=0;
* 函数名         : main
* 函数功能                   : 主函数
* 输入           : 无
* 输出                  : 无
        unsigned int  i;
                for(i= 0; i<50; i++ )   //两个字之间的扫描间隔时间
                                Hc595SendByte(0x00);                             //消隐
                                COMMONPORTS        = TAB[tab];                                 //输出字码
                                Hc595SendByte(CHARCODE[j][tab]);
                                delay(2);
                j++;
                if(j == 18)
                        j = 0;
另外还要提醒你,一定要将标有JOE的跳线冒接到GND那边才行哦。
参与人数 1黑币 +100 收起 理由
admin + 100 回帖助人的奖励!
ID:445287 发表于 2018-12-13 12:23 | 只看该作者
HC6800-ES-V2.0 发表于 2018-12-13 08:16
你大概没有搞清楚你的板子的点阵电路吧!
好的,我试试,谢谢老哥
ID:445287 发表于 2018-12-13 12:31 | 只看该作者
你大概没有搞清楚你的板子的点阵电路吧!
大神怎么把矩阵键盘控制加进去?
ID:438665 发表于 2018-12-13 20:07 | 只看该作者
jsj@1234 发表于 2018-12-13 12:31
大神怎么把矩阵键盘控制加进去?
设置一个按键标志位,利用中断函数来扫描这个标志位(举例:1ms进入一次中断,一旦连续4次检测到0,就更新对应的按键值)。然后在main函数里面用if(标志位)来判断就可以了;加一下自己的代码:
  1.         while(1)
  2.         {
  3.                 for (i=0; i<4; i++)
  4.                 {
  5.                         if (backup [i] != KeySta [i])
  6.                         {
  7.                                 if(backup [i] != 0)
  8.                                 {
  9.                                         if(KeySta[0]==0)
  10.                                         {
  11.                                                 TR1 = 0;                        //进入第一个程序时,关闭定时器1
  12.                                                 ENLED = 0;
  13.                                                 ADDR3 = 1;
  14.                                                 ADDR2 = 0;
  15.                                                 ADDR1 = 0;
  16.                                                 ADDR0 = 0;
  17.
  18.                                                 if (KeySta[0]==0)
  19.                                                 {
  20.                                                         P0 = LedChar[cnt];
  21.                                                         cnt++;
  22.                                                         if(cnt >= 10)
  23.                                                         cnt = 0;
  24.                                                 }
  25.                                         }
然后是中断里面的:
  1. void InterruptTimer0 () interrupt 1
  2. {
  3.         unsigned char i = 0;
  4.         static unsigned char KeyBuf[4]={
  5.                 0xFF,0xFF,0xFF,0xFF
  6.         };
  7.
  8.         TH0 = 0xFC;
  9.         TL0 = 0x67;
  10.         KeyBuf [0] = (KeyBuf[0]<<1)|KEY_IN_1;
  11.         KeyBuf [1] = (KeyBuf[1]<<1)|KEY_IN_2;
  12.         KeyBuf [2] = (KeyBuf[2]<<1)|KEY_IN_3;
  13.         KeyBuf [3] = (KeyBuf[3]<<1)|KEY_IN_4;
  14.         for (i=0; i<4; i++)
  15.         {
  16.                 if ((KeyBuf[i]&0x0F) == 0x00)
  17.                 {
  18.                         KeySta[i] = 0;
  19.                 }
  20.                  else if ((KeyBuf[i]&0x0F) == 0x0F)
  21.                 {
  22.                         KeySta[i] = 1;
  23.                 }
  24.         }
  25. }
ID:370231 发表于 2018-12-25 14:31 | 只看该作者
哈哈,拿着程序照搬是不对的,要根据程序是否和硬件配套不?跟硬件不配套你弄的代码再好也等于0。
ID:513294 发表于 2019-4-16 09:15 来自触屏版 | 只看该作者
大神怎么把矩阵键盘控制加进去?
楼主你做出来了吗,我也想做和你一样的加矩阵键盘的
ID:554850 发表于 2019-6-5 10:56 | 只看该作者
你大概没有搞清楚你的板子的点阵电路吧!
那请问下 就是完全的  每个矩阵按键控制不同的点阵数字或者图案怎么写
