查看: 2131|回复: 3
红外遥控LCD显示
ID:451728 发表于 2018-12-23 23:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
sbit lcden = P2^7;
sbit lcdrs = P2^6;
sbit lcdwr = P2^5;
sbit IR = P3^2;
uchar IRCOM[6];//数组,用于存储红外编码
uchar code table1[] = "remote control";
uchar code table2[] = "CODE:";
void delayms(uchar x)// 延时x*0.14ms
uchar i;
while(x--)
for(i=0;i<13;i++){}
void delay(uchar x)        //延时xms
uchar i,j;
for(i=x;i>0;i--)
for(j=110;j>0;j--);
/****************************LCD部分***********************************************/
void write_com(uchar com)
lcden = 0;
lcdrs = 0;
lcdwr = 0;
P0 = com;
delay(5);
lcden = 1;
delay(5);
lcden = 0;        //别忘了lcden拉低
void write_date(uchar date)
lcden = 0;
lcdrs = 1;
lcdwr = 0;
P0 = date;
delay(5);
lcden = 1;
delay(5);
lcden = 0;
void lcd_init(void)
lcden = 0;
lcdrs = 0;
lcdwr = 0;
delay(5);
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
/*****************main()************************/
void main(void)
uchar count=0;
IR = 1;
lcd_init();
write_com(0x80);
while(table1[count]!='\0')
write_date(table1[count]);
count++;
delay(5);
count = 0;
write_com(0x80+0x40);
while(table2[count]!='\0')
write_date(table2[count]);
count++;
delay(5);
IE = 0x81; //开中断
TCON = 0x01;//脉冲负边沿触发
while(1);
/*********************红外中断**************************/
void IR_time() interrupt 0
uchar i,j,TimeNum=0;//TimeNum用来计IR高电平次数 从而判断是0还是1
EX0 = 0; //关闭中断
delayms(5);
if(1 == IR)
EX0 = 1;
return;
while(!IR) //跳过9ms前导低电平
delayms(1);
for(i=0;i<4;i++)
for(j=0;j<8;j++)
while(IR) //跳过4.5ms的前导高电平
delayms(1);
while(!IR) //跳过0.56ms的低电平
delayms(1);
while(IR)
TimeNum++; //计时高电平时间从而判断读取的是0还是1
delayms(1);
if(TimeNum>=30)//按键按下时间过长 跳过
EX0 = 1;
return;
IRCOM[i] = IRCOM[i]>>1;
if(TimeNum >= 8) //8*0.14ms 这时读取的是1;
IRCOM[i] = IRCOM[i]|0x80;
TimeNum = 0;
if(IRCOM[2]!=~IRCOM[3])//判断八位数据和八位数据反码是否相等
EX0 = 1;
return;
IRCOM[4] = IRCOM[2]&0x0f;//取低四位
IRCOM[5] = IRCOM[2]>>4;        //IRCOM[5]取IRCOM[2]高四位
if(IRCOM[4] > 9) //转换成字符
IRCOM[4] = IRCOM[4] + 0x37;
IRCOM[4] = IRCOM[4] + 0x30;
if(IRCOM[5] > 9)
IRCOM[5] = IRCOM[5] + 0x37;
IRCOM[5] = IRCOM[5] + 0x30;
delay(5);
write_com(0x80 + 0x40 + 5);
write_date(IRCOM[5]);
write_date(IRCOM[4]);
EX0 = 1; //重新开启外部中断
ID:1 发表于 2018-12-24 12:58 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
ID:455251 发表于 2018-12-28 16:29 | 只看该作者
有没有原理图或者仿真图?
有图的话更直观一些
