查看: 8142|回复: 0
单片机按键控制小灯的仿真+代码(三种效果)
某学校课程设计程序与电路
  1. #include <reg52.h>          //头文件
  2. #include <intrins.h>
  3. #define uint unsigned int   //宏定义
  5. sbit key1 =P2^0;            //按键1
  6. sbit key2 =P2^1;            //按键2
  7. sbit key3 =P2^2;            //按键3
  8. sbit key4 =P2^3;            //按键4
  9. uint a,b;
  10. uchar table[]={0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00,0xff};  //第一种现象的数据
  11. uchar table2[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};      //第二种现象的数据
  12. uchar table3[]={0xaa,0x55};                                    //第三种现象的数据
  13. void delay(uint t);                                            //较短延时
  14. void delayms();                                                //较长延时
  15. void main()
  16. {
  17.
  18.         while(1)
  19.         {
  20.                 if(key1==0)     //第一个按键按下
  21.                 {
  22.                         delay(10);    //消除机械抖动延时
  23.                         if(key1==0)   //再次检测
  24.                   {
  25.                                 while(!key1);//松手检测
  26.                                 while(1)
  27.                                 {
  28.                                         for(a=0;a<9;a++)
  29.                                         {
  30.                                                 P1=table[a];
  31.                                                 delayms();
  32.                                                 if(key1==0||key2==0||key3==0||key4==0) //有任一按键按下,就打破当前循环
  33.        break;
  34.                                         }
  35.                                         if(key1==0||key2==0||key3==0||key4==0)
  36.        break;
  37.                           }
  38.                         }
  39.                 }
  40.
  41.                 if(key2==0)                                        //同理
  42.                 {
  43.                         delay(10);
  44.                         if(key2==0)
  45.                   {
  46.                                 while(!key2);
  47.                                 while(1)
  48.                                 {
  49.                                         for(a=0;a<8;a++)
  50.                                         {
  51.                                                 P1=0xff;
  52.                                                 delayms();
  53.                                                 P1=table2[a];
  54.                                                 delayms();
  55.                                                 if(key1==0||key2==0||key3==0||key4==0)
  56.                                                 break;
  57.                                         }
  58.                                         if(key1==0||key2==0||key3==0||key4==0)
  59.        break;
  60.                           }
  61.                         }
  62.                 }
  63.                 if(key3==0)           //同理
  64.                 {
  65.                         delay(10);
  66.                         if(key3==0)
  67.                   {
  68.                                 while(!key3);
  69.                                 while(1)
  70.                                 {
  71.                                 for(a=0;a<2;a++)
  72.                                         {
  73.                                          P1=0xff;
  74.                                          delayms();
  75.                                          P1=table3[a];
  76.                                          delayms();
  77.                                         if(key1==0||key2==0||key3==0||key4==0)
  78.                                                 break;
  79.                                         }
  80.                                         if(key1==0||key2==0||key3==0||key4==0)
  81.        break;
  82.                                 }
  83.                         }
  84.                 }
  85.
  86.                 if(key4==0)
  87.                 {
  88.                   delay(10);
  89.                         if(key4==0)
  90.                   {
  91.                                 while(1)          //使其陷入死循环
  92.         {
  93.                                         if(key1==0||key2==0||key3==0||key4==0)
  94.                       break;
  95.                                 }
  96.                         }
  97.                 }
  98.
  99.         }
  100. }
  101. void delay(uint t)
  102. {
  103.         while(t--);
  104. }
  105. void delayms()
  106. {
  107.         for(b=0;b<200;b++)
  108.                 {
  109.                         delay(200);
  110.                         if(key1==0||key2==0||key3==0||key4==0)//可能按键按下时程序执行在延时函数里面所以需要检测打破循环
  111.                                 break;
  112.                 }
  113. }
电路仿真.zip (31.48 KB, 下载次数: 16)
程序.zip (26.66 KB, 下载次数: 11)
