查看: 1486|回复: 0
STM32f103控制系统板灯的呼吸亮灭源程序
ID:361500 发表于 2018-12-26 15:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "stm32f10x.h"q
#include "stm32_eval.h"
#include <stdio.h>
#ifdef USE_STM32100B_EVAL
#include "stm32100b_eval_lcd.h"
#elif defined USE_STM3210B_EVAL
#include "stm3210b_eval_lcd.h"
#elif defined USE_STM3210E_EVAL
#include "stm3210e_eval_lcd.h"
#elif defined USE_STM3210C_EVAL
#include "stm3210c_eval_lcd.h"
#elif defined USE_STM32100E_EVAL
#include "stm32100e_eval_lcd.h"
#endif
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
  #define MESSAGE1   "STM32 MD Value Line "
  #define MESSAGE2   " Device running on  "
  #define MESSAGE3   "  STM32100B-EVAL    "
#elif defined (USE_STM3210B_EVAL)
  #define MESSAGE1   "STM32 Medium Density"
  #define MESSAGE3   "   STM3210B-EVAL    "
#elif defined (STM32F10X_XL) && defined (USE_STM3210E_EVAL)
  #define MESSAGE1   "  STM32 XL Density  "
  #define MESSAGE3   "   STM3210E-EVAL    "
#elif defined (USE_STM3210E_EVAL)
  #define MESSAGE1   " STM32 High Density "
#elif defined (USE_STM3210C_EVAL)
  #define MESSAGE1   " STM32 Connectivity "
  #define MESSAGE2   " Line Device running"
  #define MESSAGE3   " on STM3210C-EVAL   "
#elif defined (USE_STM32100E_EVAL)
  #define MESSAGE1   "STM32 HD Value Line "
  #define MESSAGE3   "  STM32100E-EVAL    "
#endif
USART_InitTypeDef USART_InitStructure;
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
   set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
int main(void)
  STM_EVAL_LEDInit(LED1);
  STM_EVAL_LEDInit(LED2);
  STM_EVAL_LEDInit(LED3);
  STM_EVAL_LEDInit(LED4);
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = 115200;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  STM_EVAL_COMInit(COM1, &USART_InitStructure);
  /* Initialize the LCD */
  STM32100B_LCD_Init();
  STM3210B_LCD_Init();
  STM3210E_LCD_Init();
  STM3210C_LCD_Init();
  STM32100E_LCD_Init();
#endif
  /* Display message on STM3210X-EVAL LCD *************************************/
  /* Clear the LCD */
  LCD_Clear(LCD_COLOR_WHITE);
  /* Set the LCD Back Color */
  LCD_SetBackColor(LCD_COLOR_BLUE);
  /* Set the LCD Text Color */
  LCD_SetTextColor(LCD_COLOR_WHITE);
  LCD_DisplayStringLine(LCD_LINE_0, (uint8_t *)MESSAGE1);
  LCD_DisplayStringLine(LCD_LINE_1, (uint8_t *)MESSAGE2);
  LCD_DisplayStringLine(LCD_LINE_2, (uint8_t *)MESSAGE3);
  /* Retarget the C library printf function to the USARTx, can be USART1 or USART2
     depending on the EVAL board you are using ********************************/
  printf("\n\r %s", MESSAGE1);
  printf(" %s", MESSAGE2);
  printf(" %s\n\r", MESSAGE3);
  /* Turn on leds available on STM3210X-EVAL **********************************/
  STM_EVAL_LEDOn(LED1);
  STM_EVAL_LEDOn(LED2);
  STM_EVAL_LEDOn(LED3);
  STM_EVAL_LEDOn(LED4);
  /* Add your application code here
  /* Infinite loop */
  while (1)
PUTCHAR_PROTOTYPE
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
test.zip
305.54 KB, 下载次数: 3, 下载积分: 黑币 -5
相应工程包
