查看: 4196|回复: 1
关于XL4016 PWM buck芯片的控制
ID:428204 发表于 2018-12-28 22:06 | 显示全部楼层 |阅读模式
这是datasheet上的资料,求大佬看看这个芯片是怎么控制输出电压的
General Description The XL4016 is a 180 KHz fixed frequency PWM buck (step-down) DC/DC converter, capable of driving a 8A load with high efficiency, low ripple and excellent line and load regulation. Requiring a minimum number of external components, the regulator is simple to use and include internal frequency compensation and a fixed-frequency oscillator.
The PWM control circuit is able to adjust the duty ratio linearly from 0 to 100%. An over current protection function  is built inside. When short protection function happens, the operation frequency will be reduced from 180KHz to 48KHz. An internal compensation block is built in to minimize external component count.
datasheet上的资料
datasheet上的资料
ID:149144 发表于 2020-6-20 23:12 | 显示全部楼层
VOUT = 1.25 * (1 + R2 / R1) 写的那么清楚
