查看: 2514|回复: 0
STM8S103F+74HC595如何控制5X7LED点阵,老乱码
ID:457781 发表于 2018-12-29 09:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "IOSTM8S103F3.h"
#define DIO PD_ODR_ODR1
#define RCLK PD_ODR_ODR2
#define SCLK PD_ODR_ODR3
#define u8 uint8_t
#define u16 uint16_t
#define u32 unin32_t
typedef unsigned char uint8_t;
typedef unsigned short uint16_t;
typedef unsigned long uint32_t;
u8 LED_T[]={0x01,0x02,0x04,0x08,0x20};
u8 LED[5];
void delay(u16 Count);
void LED8_Display(void);
void LED_OUT(u8 outdata);
void main(void)
u8 x;
  PD_ODR=0xFF;
  PD_CR1=0xFF;
  PD_CR2=0x00;
for (x=0;x<5;x++)
LED[x]=x;
    LED8_Display();
void delay(u16 count)//延迟函数
  u16 i,j;
  while(count--)
    for(i=0;i<50;i++)
      for(j=0;j<50;j++);
  u8 i,duan_table;
  for (i=0;i<5;i++){
    duan_table=*(LED_T+LED[i]);
   LED_OUT(duan_table);
    RCLK=0;
   RCLK=1;
    delay(50);
  u8 i;
  for(i=0;i<8;i++)
    if(outdata&0x80)
      DIO=1;
      DIO=0;
    outdata<<=1;
    SCLK=0;
    SCLK=1;
