查看: 6195|回复: 3
单片机控制8*8点阵动态左右动态显示,并实现改变方向
ID:458698 发表于 2018-12-30 18:40 | 显示全部楼层 |阅读模式
附原理图与程序
#include<reg51.h>
#include<math.h>
#include<intrins.h>
#define data1 P0
#define data2 P2
sbit s1=P3^6;
sbit s2=P3^7;
bit fangxiang;
uint alt=0,net=0,sl=8*10;
bit mode;
uchar code tab[]={
// (0) 0(1) 1(2) 2(3) 3(4) 4(5) 5(6) 6(7) 7(8) 8(9) 9(10)  (11)
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
0x00,0x1C,0x22,0x22,0x22,0x22,0x1C,0x00,/*"0",1*/
0x00,0x12,0x12,0x3E,0x02,0x02,0x00,0x00,/*"1",2*/
0x00,0x12,0x26,0x26,0x26,0x2A,0x36,0x00,/*"2",3*/
0x00,0x14,0x22,0x32,0x32,0x2A,0x2C,0x00,/*"3",4*/
0x00,0x08,0x14,0x24,0x26,0x7E,0x00,0x00,/*"4",5*/
0x00,0x3C,0x2A,0x2A,0x2A,0x2A,0x24,0x00,/*"5",6*/
0x00,0x1C,0x2A,0x2A,0x2A,0x2A,0x04,0x00,/*"6",7*/
0x00,0x30,0x20,0x2E,0x28,0x30,0x20,0x00,/*"7",8*/
0x00,0x34,0x2A,0x2A,0x2A,0x2A,0x34,0x00,/*"8",9*/
0x00,0x10,0x2A,0x2A,0x2A,0x2E,0x1C,0x00,/*"9",10*/
void delay(uint z)           //延时子函数
   uchar x;
   for(;z>0;z--)
   for(x=110;x>0;x--);
void xianshi()                        //显示
        uchar aa,i,num=2;
        for(i=0;i<16;i++)
                switch(i){
                        case 0:
                                num=1;
                                break;
                        case 1:
                                num=2;
                                break;
                        case 2:
                                num=4;
                                break;
                        case 3:
                                num=8;
                                break;
                        case 4:
                                num=16;
                                break;
                        case 5:
                                num=32;
                                break;
                        case 6:
                                num=64;
                                break;
                        case 7:
                                num=128;
                                break;
                        default :
                                num=0;
                                break;
                P2=0xff-num; //列扫描
                data1=tab[net+aa]; //取出上8行数据输出
                aa++;
                delay(5);        //延时
                data1=0;  //清屏
                P1=0x00;  //消除余辉
                if(aa>15) aa=0;  //字模地址
void main()         //主函数
   ET1=1;         //使能定时器0
   EA=1;         //开启总中断
   TR1=1;        //开始计数
   while(1)         //无限循环
           xianshi();  //显示
           if(s1==0)   //检测按键
              delay(30);  //延时消抖
                  TR1=~TR1;          //按下暂停  ,暂按继续
                  while(!s1)xianshi();
                  delay(30);
           if(s2==0)        //检测按键
               delay(30);                        //延时消抖
                   fangxiang=~fangxiang;  //方向取反
                   while(!s2)xianshi();
                   delay(30);
void timer1() interrupt 3
   alt++;
   if(alt==30)                   //到一定的时间加以实现左移
     alt=0;
         if(fangxiang==0)         //如果是正向 正向移动
                 net=net+2;
             if(net>sl)  //字移动数量
             net=0;
         else                           //否则反向移动
             net=net-2;
                 if(net<2)
                 net=sl;          //字移动数量
ID:458698 发表于 2018-12-30 18:41 | 显示全部楼层
其它兄弟可以在此基础上加一个上下动态显示功能
ID:243748 发表于 2019-1-24 21:03 来自触屏版 | 显示全部楼层
学习下不会写程序
ID:233561 发表于 2019-2-6 03:20 | 显示全部楼层
如果共享一下仿真文件就好 了
