查看: 2228|回复: 1
arduino超声波传感器代码
ID:459381 发表于 2019-1-1 16:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
int trigger_pin = 2;
int echo_pin = 3;
int led_pin = 10;
int time;
int distance;
void setup ( ) {
        Serial.begin (9600);
        pinMode (trigger_pin, OUTPUT);
        pinMode (echo_pin, INPUT);
        pinMode (led_pin, OUTPUT);
void loop ( ) {
    digitalWrite (trigger_pin, HIGH);
    delayMicroseconds (10);
    digitalWrite (trigger_pin, LOW);
    time = pulseIn (echo_pin, HIGH);
    distance = (time * 0.034) / 2;
  if (distance <= 20)
        Serial.println (" Door Open ");
        Serial.print (" Distance= ");
        Serial.println (distance);
        digitalWrite (led_pin, HIGH);
        delay (500);
  else {
        Serial.println (" Door closed ");
        digitalWrite (led_pin, LOW);
        delay (500);
ID:1 发表于 2019-1-1 20:36 | 只看该作者
补全原理图或者详细说明一下电路连接即可获得100+黑币
