查看: 2409|回复: 0
High voltage barrier for LED Driver
In general application for linear LED lighting, most of engineers will have problem with high voltage requirement but many LED drivers cannot sustain high voltage. Therefore, here is a way to use high voltage barrier, which consists of Zener diode and P-MOS to suppress voltage and then protect LED and LED driver.
