查看: 6638|回复: 0
[求助]regx51.h对应的是哪种单片机
ID:40336 发表于 2012-5-16 13:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include #include #define uchar unsigned char #define uint unsigned int #define k1 P3_7 //k1功能键 #define k2 P3_6 //k2数值调整键 #define bjh P3_1 //定值输出 #define sx P0_2 //报警值输出(声音) #define csbout P2_7 //超声波发送 #define csbint P3_5 //超声波接收 uchar ec,cls;cs;xl,mq,xm0,xm1,xm2,sec20,sec,sec1,buffer[3],BitCounter,temp,Number[8]={1,2,3,4,5,6,7,8}; uchar temp1,convert[10]={0x81,0xED,0xA2,0xA8,0xCC,0x98,0x90,0xAD,0x80,0x88};//0~9段码 uint zzz,dz,zzbl,i,jsz,yzsj,kk,s,ss; static uchar bdata ke,kw; //可位寻址的状态寄存器 float csbc,wdz; sbit LED1 = P3^4; //数码管位驱动 sbit LED2 = P3^2; //数码管位驱动 sbit LED3 = P3^3; //数码管位驱动 sbit k11=ke^0; sbit k12=ke^1; sbit k22=ke^2; sbit k21=ke^3; sbit b=ke^4; sbit c=ke^5; sbit d=ke^6; sbit e=ke^7; sbit w=kw^0; sbit zj1=kw^1; sbit zj2=kw^2; 上面居然还有ke^0口 怎么发表后没有回车?
[此贴子已经被作者于2012-5-16 13:09:06编辑过]
