查看: 13321|回复: 32
单片机红外对管寻迹小车设计
ID:402350 发表于 2019-1-6 11:30 | 显示全部楼层 |阅读模式
#include <red52.h>
sbit hongwai1=P1^0;   //定义红外对管引脚  4个
sbit hongwai2=P1^1;
sbit hongwai3=P1^2;
sbit hongwai4=P1^3;
sbit ENA=P0^0;//电机驱动
sbit M1A=P0^1;
sbit M1B=P0^2;
sbit M2A=P0^3;
sbit M2B=P0^4;
sbit ENB=P0^5;
void tingzhi()         //停止
   M1A=0;
   M1B=0;
   M2A=0;
   M2B=0;
void qianjin()         //前进
   M1A=1;
   M1B=0;
   M2A=1;
   M2B=0;
void houtui()    //后退
   M1A=0;
   M1B=1;
   M2A=0;
   M2B=1;
void zuozhuan()          //左转
   M1A=1;
   M1B=0;
   M2A=0;
   M2B=1;
void weizuozhuan() //左微转
   M1A=1;
   M1B=0;
   M2A=0;
   M2B=0;
void youzhuan()           //右转
   M1A=0;
   M1B=1;
   M2A=1;
   M2B=0;
void weiyouzhuan()        //右微转
   M1A=0;
   M1B=0;
   M2A=1;
   M2B=0;
void delay_nus(unsigned int i)  //延时函数
  i=i/10;
  while(--i);
void delay_nms(unsigned int n) //延时函数
  n=n+1;
  while(--n)
  delay_nus(900);
void ControlCar(unsigned char xunji)
  tingzhi();       //首先是停止
switch(xunji)     //根据swith里面的值来驱动车
  case 1:
    qianjin();
    break;
  case 2:
    houtui();
    break;
  case 3:
    zuozhuan();
        break;
  case 4:
    youzhuan();
        break;
  case 5:
    weiyouzhuan();
        break;
   case 6:
    weizuozhuan();
        break;
  case 7:
    tingzhi();
        break;
void main()          //主函数
   delay_nms (30);//延时
  ControlCar(7);//停止
  ControlCar(1);//前进
   delay_nms (10);
          Start:          //行号
    ENA=1;//电机使能
        ENB=1;
   if(hongwai1==0&&hongwai2 == 0 && hongwai3 == 0&&hongwai4==0)   //寻迹模块的情况判定,4个寻迹模块,可以组合为16种情况
   {                                                            //根据需要选择
      ControlCar(7);
      delay_nms (3);
          goto NextRun;
    if(hongwai1==0&&hongwai2 == 0 && hongwai3 == 0&&hongwai4==1)
      ControlCar(6);
      delay_nms (3);
          goto NextRun;
    if(hongwai1==0&&hongwai2 == 0 && hongwai3 == 1&&hongwai4==1)
      ControlCar(6);
      delay_nms (3);
          goto NextRun;
    if(hongwai1==0&&hongwai2 == 0 && hongwai3 == 1&&hongwai4==0)
     ControlCar(6);
      delay_nms (3);
          goto NextRun;
   if(hongwai1==1&&hongwai2 == 0 && hongwai3 == 0&&hongwai4==0)
      ControlCar(5);
      delay_nms (3);
          goto NextRun;
    if(hongwai1==1&&hongwai2 == 1 && hongwai3 == 0&&hongwai4==0)
      ControlCar(5);
      delay_nms (3);
          goto NextRun;
    if(hongwai1==0&&hongwai2 == 1 && hongwai3 == 0&&hongwai4==0)
      ControlCar(5);
      delay_nms (3);
          goto NextRun;
         if(hongwai1==1&&hongwai2 == 1 && hongwai3 == 1&&hongwai4==1)
      ControlCar(7);
      delay_nms (3);
          goto NextRun;
      ControlCar(7);
      delay_nms (3);
          goto NextRun;
   if(hongwai1==0&&hongwai2 == 1 && hongwai3 == 1&&hongwai4==1)
      ControlCar(3);
      delay_nms (3);
          goto NextRun;
   if(hongwai1==1&&hongwai2 == 1 && hongwai3 == 1&&hongwai4==0)
      ControlCar(4);
      delay_nms (3);
          break;
          goto NextRun;
   goto Start;          //相当于返回  start行
   NextRun:
   ControlCar(1);
ID:487204 发表于 2019-3-13 19:43 来自触屏版 | 显示全部楼层
四轮的用一个驱动模块行吗
ID:402350 发表于 2019-4-5 17:04 | 显示全部楼层
123qs 发表于 2019-3-13 19:43
四轮的用一个驱动模块行吗
可以的
ID:506440 发表于 2019-4-7 19:30 | 显示全部楼层
请问是stc12c5a60s2的吗
ID:502460 发表于 2019-4-10 09:53 来自触屏版 | 显示全部楼层
四轮的用一个驱动模块行吗
可以,左侧两个轮子接一个输出口,右侧轮子接一个输出口。
ID:369974 发表于 2019-4-10 16:28 | 显示全部楼层
请问这个速度怎么控制
ID:402350 发表于 2019-4-10 19:57 | 显示全部楼层
stc51
ID:402350 发表于 2019-4-10 19:58 | 显示全部楼层
zpj159 发表于 2019-4-10 16:28
请问这个速度怎么控制
pwm调速,定时器调脉冲宽度
ID:517628 发表于 2019-4-21 10:54 | 显示全部楼层
请问能把您做的c51循迹小车的电路图发给我吗??还有配件清单
ID:402350 发表于 2019-4-25 08:42 | 显示全部楼层
L298N电机驱动模块,红外对管,最小系统,电源,
ID:514746 发表于 2019-5-8 13:06 来自触屏版 | 显示全部楼层
请问楼主可以发工程吗?
ID:514746 发表于 2019-5-14 10:26 来自触屏版 | 显示全部楼层
请问这是用一个l298nma
ID:402350 发表于 2019-5-14 12:40 | 显示全部楼层
Rainson 发表于 2019-5-14 10:26
请问这是用一个l298nma
嗯,我使用了一个,两个也可以
ID:498152 发表于 2019-5-14 20:24 来自触屏版 | 显示全部楼层
这个可以用吗?
ID:402350 发表于 2019-5-16 20:58 | 显示全部楼层
可以
ID:564037 发表于 2019-6-16 23:36 | 显示全部楼层
我的电机驱动模块用的是L1109S,但我觉得原理都一样,不过我实现不了循迹,就像一个断了线的风筝一样,走的是唯心派,可以帮我解决一下吗,我可以把代码发给你
ID:402350 发表于 2019-6-17 10:28 | 显示全部楼层
电信172 发表于 2019-6-16 23:36
我的电机驱动模块用的是L1109S,但我觉得原理都一样,不过我实现不了循迹,就像一个断了线的风筝一样,走的 ...
嗯呐,可以发过来一起学习。
ID:539167 发表于 2019-6-18 16:16 来自触屏版 | 显示全部楼层
能循黑线走不?
ID:402350 发表于 2019-6-19 09:50 | 显示全部楼层
可以寻黑线
ID:539167 发表于 2019-6-19 14:12 来自触屏版 | 显示全部楼层
止于心 发表于 2019-6-19 09:50
可以寻黑线
为啥我检测到黑线就走不动
ID:402350 发表于 2019-6-19 16:07 | 显示全部楼层
来日可期1 发表于 2019-6-19 14:12
为啥我检测到黑线就走不动
你可以调整一下红外对管之间的距离
ID:526830 发表于 2019-8-5 20:20 | 显示全部楼层
你好,这样不需要用到晶振吗
ID:611926 发表于 2019-9-19 09:20 来自触屏版 | 显示全部楼层
请问这个红外模块的电路是怎样的?
ID:402350 发表于 2019-9-20 21:03 | 显示全部楼层
厚朴 发表于 2019-8-5 20:20
你好,这样不需要用到晶振吗
需要,最小系统里面有
ID:402350 发表于 2019-9-20 21:05 | 显示全部楼层
qq19990601 发表于 2019-9-19 09:20
请问这个红外模块的电路是怎样的?
红外对管一共有三个接口,一个接vcc一个接gnd还有一个接单片机的IO口,具体的可以上网查一下手册。
ID:434283 发表于 2020-2-24 11:17 | 显示全部楼层
有没有PCB、原理图
ID:808225 发表于 2020-8-7 22:38 | 显示全部楼层
楼主,请问,在转弯处,在检测到黑线后,电机没来得及反应,小车就冲出黑线了,应该怎么调?
ID:692524 发表于 2020-8-9 18:20 | 显示全部楼层
楼主,头文件写错了吗?应该是#include<reg51.h>??
ID:402350 发表于 2020-11-13 15:37 | 显示全部楼层
可以用pwm调速
ID:402350 发表于 2020-11-13 15:38 | 显示全部楼层
三旬 发表于 2020-8-9 18:20
楼主,头文件写错了吗?应该是#include??
我用的是52系列的单片机
ID:848452 发表于 2020-11-26 19:55 | 显示全部楼层
四轮的用一个驱动模块行吗
可以的。。。
ID:926637 发表于 2021-5-27 14:32 | 显示全部楼层
红外对管怎么接上去
ID:402350 发表于 2021-6-19 21:33 | 显示全部楼层
自传zz 发表于 2021-5-27 14:32
红外对管怎么接上去
看程序定义的端口
