查看: 2284|回复: 2
PIC12F675单片机奇怪问题
ID:206067 发表于 2019-1-13 02:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
程序目的是实现上电灯就亮”输出1“ 定时后”输出0“
#include<pic.h>
#include <xc.h>
#pragma config FOSC = INTRCIO   // Oscillator Selection bits (INTOSC oscillator: I/O function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-Up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = OFF      // GP3/MCLR pin function select (GP3/MCLR pin function is digital I/O, MCLR internally tied to VDD)
#pragma config BOREN = OFF      // Brown-out Detect Enable bit (BOD disabled)
#pragma config CP = OFF         // Code Protection bit (Program Memory code protection is disabled)
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
#define KEY GP3
unsigned char count=0;
unsigned char miao=0;
unsigned char fen=0;
    OSCCAL=0b00000100;//intside RC
    TRISIO=0b00001000;//IO方向设置
    OPTION_REG=0b00000111;//分频比1:256
    TMR0=0;
    GP0=1;
  //  GP1=GP2=GP4=GP5=0;  写进这行灯就一直不亮,不写就是正常的
            if(TMR0==180)//50ms
                TMR0=0;
                count++;
                if(count==20)//1秒定时
                    miao++;
                    count=0;
                    if(miao==5)
                        miao=0;
                        GP0=0;
ID:206067 发表于 2019-1-21 11:35 | 只看该作者
有人知道吗
ID:138119 发表于 2019-1-27 11:16 | 只看该作者
印象中我也遇到过类似问题,很久了,记得可能是编译器优化级别的问题。
