查看: 5310|回复: 3
DELPHI开发的甲醛测试仪上位机源码 DART传感器数据发串口
基于DELPHI开发的甲醛测试仪,上位机程序。配合常见的英国DART传感器,协议长9字节。通过串口发送。
delphi程序源码:
  1. unit Unit2;
  2. interface
  3. uses
  4.   Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  5.   Dialogs, CPortCtl, CPort, StdCtrls;
  6. type
  7.   TForm2 = class(TForm)
  8.     GroupBox1: TGroupBox;
  9.     GroupBox2: TGroupBox;
  10.     GroupBox3: TGroupBox;
  11.     Label2: TLabel;
  12.     Label8: TLabel;
  13.     Button1: TButton;
  14.     Button2: TButton;
  15.     Memo1: TMemo;
  16.     ComPort1: TComPort;
  17.     ComLed1: TComLed;
  18.     ComLed2: TComLed;
  19.     Label13: TLabel;
  20.     Label14: TLabel;
  21.     ComDataPacket1: TComDataPacket;
  22.     procedure Button1Click(Sender: TObject);
  23.     procedure Button2Click(Sender: TObject);
  24.     procedure FormCreate(Sender: TObject);
  25.     procedure ComPort1AfterOpen(Sender: TObject);
  26.     procedure ComDataPacket1Packet(Sender: TObject; const Str: string);
  27.   private
  28.     { Private declarations }
  29.   public
  30.     { Public declarations }
  31.   end;
  32.     TAir = Record   //Start from 0
  33.             CH2O:Integer;//Byte6(High) Byte7(Low)
  34.     End;
  35. var
  36.   Form2: TForm2;
  37.   i:integer;
  38. implementation
  39. {$R *.dfm}
  40. procedure TForm2.Button1Click(Sender: TObject);
  41. begin
  42.     ComPort1.ShowSetupDialog;
  43. end;
  44. procedure TForm2.Button2Click(Sender: TObject);
  45. begin
  46.     ComPort1.Open;
  47. end;
  48. procedure TForm2.ComDataPacket1Packet(Sender: TObject; const Str: string);
  49. var
  50.   value:TAir;
  51.   s:string;
  52.   j:integer;
  53. begin
  54.   Value.CH2O:=ord(Str[5])shl 8+ ord(Str[6]);
  55.   //Label7.Caption:=IntToStr(Value.PM1CF);
  56.   Label8.Caption:=IntToStr(Value.CH2O);
  57. // Label9.Caption:=IntToStr(Value.PM10CF);
  58. // Memo1.Lines.Add('Received No. '+IntToStr(i)+' packages');
  59. // s:='';
  60.   //for j := 1 to 9 do //20- sizeof('FF')
  61.    // s:=s+'['+IntToStr(ord(Str[j]))+']';
  62.   //Memo1.Lines.Add(s);
  63.   //inc(i);
  64. end;
  65. procedure TForm2.ComPort1AfterOpen(Sender: TObject);
  66. begin
  67.   memo1.Lines.Add('opedn');
  68. end;
  69. procedure TForm2.FormCreate(Sender: TObject);
  70. begin
  71.    i:=0;
  72. end;
  73. end.
全部资料51hei下载地址:
甲醛测试仪 制作源程序.rar (410.09 KB, 下载次数: 21)
ID:277550 发表于 2019-1-18 09:40 | 只看该作者
CPort 组件有包含?
ID:441300 发表于 2019-1-18 10:44 | 只看该作者
附件不含。相关需要组件,安装时DELPHI一般已经安装了
ID:65369 发表于 2022-5-13 19:06 | 只看该作者
刚好需要这个例子,多谢大神支持!
