查看: 1887|回复: 1
求教这个蓝牙遥控小车里的str函数有什么功能
ID:435624 发表于 2019-1-19 14:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  #include<AT89x51.H>
        #define Leftgo      {P1_2=1,P1_3=0;}      //左电机前
        #define Leftback    {P1_2=0,P1_3=1;       //左电机后
        #define LeftStop    {P1_2=0,P1_3=0;}      // 左电机停
        #define Rightgo     {P1_4=1,P1_5=0;}
        #define Rightback   {P1_4=0,P1_5=1;
        #define RightStop   {P1_4=0,P1_5=0;}
        #define left     'C'
        #define right    'D'
        #define up       'A'
        #define down     'B'
        #define stop     'F'
        #define uint    unsigned int
        #define uchar   unsigned char
        char code str[] =  "向前!\n";
        char code str1[] = "向后!\n";
        char code str2[] = "向左\n";
        char code str3[] = "向右!\n";
        char code str4[] = "停!\n";
        bit  flag_ly=0;   //蓝牙
        bit  flag    =0;
        bit  flag_bz =0;  //红外避障
        unsigned char  i=0;
        unsigned char  dat=0;
        unsigned char  buff[5]=0;//接受缓冲字节
        #define   Lled   P2^6         //左红外传感器
        #define   Rled   P2^5         //右红外传感器
        sbit BUZZ = P2^1;    //蜂鸣器
//延时函数
   void delay(unsigned int k)
     unsigned int x,y;
         for(x=0;x<k;x++)
           for(y=0;y<2000;y++);
//字符串发送函数
          void send_str( )             // 传送字符
            unsigned char i = 0;
            while(str[i] != '\0')
                SBUF = str[i];
                while(!TI);                                // 等待字符串送
                TI = 0;                                        //清楚字符串送标志
                i++;                                        // 下一个字符
                  void send_str1( )
            while(str1[i] != '\0')
                SBUF = str1[i];
                while(!TI);
                TI = 0
                i++;
                          void send_str2( )
            while(str2[i] != '\0')
                SBUF = str2[i];
                while(!TI);
                TI = 0;
                i++;
                          void send_str3()
            while(str3[i] != '\0')
                SBUF = str3[i];
                while(!TI);
                TI = 0
                i++;
              void send_str4()
            while(str4[i] != '\0')
                SBUF = str4[i];
                while(!TI);
                TI = 0;
                i++;
     void  run(void)
         Leftgo ;
         Rightgo ;
     void  backrun(void)
         Leftback ;
         Rightback ;
     void  rightrun(void)
          Leftgo ;
         Rightback ;
     void   leftrun(void)
         Leftback ;
         Rightgo ;
     void  stoprun(void)
         LeftStop ;
         RightStop ;
void sint() interrupt 4          //中断接受三个字节
    if(RI)                         //是否接受中断
       RI=0;
       dat=SBUF;
       if(dat=='O'&&(i==0)) //接受数据第一帧
            buff[i]=dat;
            flag=1;        //开始接受数据
      if(flag==1)
      i++;
      buff[i]=dat;
      if(i>=2)
      {i=0;flag=0;flag_ly=1 ;}  //停止接收
        void main(void)
    P1=0X00;              //关电机
                BUZZ=0;
                delay(50);
                BUZZ=1;
    TMOD=0x20;
    TH1=0xFd;                     //11.0952,9600波特率
    TL1=0xFd;
    SCON=0x50;
    PCON=0x00;
    TR1=1;
          ES=1;
    EA=1;
           if(flag_bz == 1)       //切换到避障模式
         if(Lled==1&&Rled==1)
                         run();
                                      if(Lled==1&&Rled==0)            //右边检测到红外信号
                                            leftrun();
                                           delay(40);
                                           if(Rled==1&&Lled==0)
                                           rightrun();
                                          delay(40);
        if(Rled==0&&Lled==0)
                                    backrun();
                                        delay(40);
                                        rightrun();
                                        delay(90);
          if(flag_ly==1)
                flag_ly=0;
                if(buff[0]=='O'&&buff[1]=='N')        //第一个字节为0,第二个字节为N,第三个字节为控制码
                switch(buff[2])
                      case up :
                          send_str( );
                          flag_bz = 1;
                          break;
                      case down:
                           send_str1( );
                           flag_bz = 0;
                          backrun();
                          break;
                      case left:
                           send_str3( );
                          leftrun();
                          flag_bz = 0;
                          break;
                      case right:
                          send_str2( );
                          rightrun();
                          flag_bz = 0;
                          break;
                      case stop:
                           send_str4( );
                          stoprun();
                          flag_bz = 0;
                          break;
ID:164602 发表于 2019-1-19 20:37 | 只看该作者
就是串口发送字符串嘛。
不过,这个程序我没有看得很懂:程序好像是控制小车的吧,那么就应该是另一个程序发送字符串,这个程序来执行,它为什么要发送字符串?不懂
