查看: 1333|回复: 0
求指教,1602显示H为什么不行
ID:439927 发表于 2019-1-21 19:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
sbit  lcden=P0^5;
sbit  lcdrs=P0^7;
sbit  lcdrw=P0^6;
void read_busy()//判断忙不忙
        uchar busy;
        P2=0xff;
        lcdrs = 0 ;
        lcdrw = 1;
        lcden = 1;
        do
                lcden = 1;
                busy = P2;
                lcden = 0;
        while(busy & 0x80);
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com (uchar com)//写一个字节的指令
        read_busy();//判断忙不忙
        lcdrs = 0;
        lcdrw = 1;
        P2 = com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar date)        //写数据显示
        read_busy();
        lcdrs =1;
        lcdrw =0;
        P2 = date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        lcden=0;
        write_com(0x38); //设置16*2
        write_com(0x0c); //开显示
        write_com(0x06); //地址加一
        write_com(0x80); //显示地址
        write_com(0x01); //请屏幕
        write_data(0x48);
        init();
        while(1);
