查看: 3360|回复: 0
LCD1602温控带时间
#include<reg51.h>
#include<intrins.h>
#include <absacc.h>
#define uint   unsigned int
#define BUSY  0x80
#define DATAPORT P0
#define PLAYE_ADDR XBYTE[0XBFFF]
sbit RED_ALARM=P1^0;
sbit WRITE_ALARM=P1^1;
sbit GREEN_ALARM=P1^2;
sbit P1_4=P1^4;
sbit P1_5=P1^5;
sbit P1_6=P1^6;
sbit DQ = P1^7;
sbit LCM_RS=P2^0;
sbit LCM_RW=P2^1;
sbit LCM_EN=P2^2;
sbit ad_busy=P3^2;
sbit RECLED_EOC=P3^5;
sbit OUT=P3^7;
uchar ad_data;
uchar seconde=0;
uchar minite=0;
uchar hour=12;
uchar mstcnt=0;
uchar temp1,temp2,temp;
uchar t,set;
uchar K;
bit ON_OFF=0;
bit outflag;
uchar code str0[]={"---  :  :  ---  "};
uchar code str1[]={"SET:  C SA:  . C"};
void delay_LCM(uint);
void initLCM( void);
void lcd_wait(void);
void WriteCommandLCM(uchar WCLCM,uchar BusyC);
void WriteDataLCM(uchar WDLCM);
void DisplayOneChar(uchar X,uchar Y,uchar DData);
void DisplayListChar(uchar X,uchar Y,uchar code *DData);
void init_timer0(void);
void displayfun1(void);
void displayfun2(void);
void displayfun3(void);
void displayfun4(void);
void keyscan(void );
void set_adj(void);
void inc_key(void);
void dec_key(void);
void delay_18B20(unsigned int i);
void Init_DS18B20(void) ;
uchar ReadOneChar(void);
void WriteOneChar(unsigned char dat);
void ReadTemperature(void);
void ad0809(void);
void playalarm(void);
void delay_LCM(uint k)
    uint i,j;
    for(i=0;i<k;i++)
        for(j=0;j<60;j++)
    if(BusyC)lcd_wait();
        DATAPORT=WCLCM;
    LCM_RS=0;
    LCM_RW=0;
    LCM_EN=1;
        _nop_();
        _nop_();
        _nop_();
    LCM_EN=0;
    lcd_wait( );
        DATAPORT=WDLCM;
    LCM_RS=1;
    LCM_RW=0;
    LCM_EN=1;
    _nop_();
        _nop_();
        _nop_();
    LCM_EN=0;
void lcd_wait(void)
    DATAPORT=0xff;
        LCM_EN=1;
    LCM_RS=0;
    LCM_RW=1;
    _nop_();
    while(DATAPORT&BUSY)
        {  LCM_EN=0;
           _nop_();
           _nop_();
           LCM_EN=1;
           _nop_();
           _nop_();
           LCM_EN=0;
void initLCM( )
        DATAPORT=0;
        delay_LCM(15);
        WriteCommandLCM(0x38,0);    //三次显示模式设置,不检测忙信号
    delay_LCM(5);
    delay_LCM(5);
    delay_LCM(5);
    WriteCommandLCM(0x38,1);    //8bit数据传送,2行显示,5*7字型,检测忙信号
    WriteCommandLCM(0x08,1);    //关闭显示,检测忙信号
    WriteCommandLCM(0x01,1);    //清屏,检测忙信号
    WriteCommandLCM(0x06,1);    //显示光标右移设置,检测忙信号
    WriteCommandLCM(0x0c,1);    //显示屏打开,光标不显示,不闪烁,检测忙信号
    uchar ListLength=0;
    Y&=0x01;
    X&=0x0f;
    while(X<16)
        DisplayOneChar(X,Y,DData[ListLength]);
        ListLength++;
        X++;
        while(i--);
        unsigned char x=0;
        DQ = 1;          //DQ复位
        delay_18B20(8);  //稍做延时
        DQ = 0;          //单片机将DQ拉低
        delay_18B20(80); //精确延时 大于 480us
        DQ = 1;          //拉高总线
        delay_18B20(14);
        x=DQ;            //稍做延时后 如果x=0则初始化成功 x=1则初始化失败
        delay_18B20(20);
/***********ds18b20读一个字节**************/
unsigned char ReadOneChar(void)
        uchar i=0;
        uchar dat = 0;
        for (i=8;i>0;i--)
                DQ = 0; // 给脉冲信号
                dat>>=1;
                DQ = 1; // 给脉冲信号
                if(DQ)
                        dat|=0x80;
                delay_18B20(4);
        return(dat);
/*************ds18b20写一个字节****************/
void WriteOneChar(uchar dat)
        unsigned char i=0;
        for (i=8; i>0; i--)
                DQ = 0;
                DQ = dat&0x01;
                delay_18B20(5);
                DQ = 1;
                dat>>=1;
        DisplayListChar(0,0,str0);
        DisplayListChar(0,1,str1);
        DisplayOneChar(3,0,hour/10+0x30);                    //液晶上显示小时
        DisplayOneChar(4,0,hour%10+0x30);
        DisplayOneChar(6,0,minite/10+0x30);                        //液晶上显示分
        DisplayOneChar(7,0,minite%10+0x30);
        DisplayOneChar(9,0,seconde/10+0x30);            //液晶上显示秒
        DisplayOneChar(10,0,seconde%10+0x30);
        DisplayOneChar(4,1,K/10+0x30);                            //液晶上显示设定的温度
        DisplayOneChar(5,1,K%10+0x30);
           DisplayOneChar(11,1,temp1/10+0x30);         //液晶上显示测得的温度
        DisplayOneChar(12,1,temp1%10+0x30);
        DisplayOneChar(14,1,temp2/10+0x30);
        if(ON_OFF==0)                                                      //若温控标志为0
                DisplayOneChar(14,0,0x4f);                           // 液晶上显示不控温的标志
                DisplayOneChar(15,0,0x46);
                DisplayOneChar(14,0,0x4f);                           // 液晶上显示控温的标志
                DisplayOneChar(15,0,0x4e);
                if(outflag==1)
                        DisplayOneChar(0,0,0x7c);
                        DisplayOneChar(0,0,0xef);
        WriteCommandLCM(0x0f,1);                                            //显示屏打开,光标显示,闪烁,检测忙信号
/**************键盘扫描子函数******************/
void keyscan(void)
        uchar xx;                                           //局部变量
        P1=0xff;
        if(P1!=0xff)
                delay_LCM(50);
                if(P1!=0xff)
                        xx=P1;
                        switch(xx)                                                       // 根据按键状态,调用不同的子函数
                        case 0xfe:set_adj();       break;
                        case 0xfd:inc_key();       break;
                        case 0xfb:dec_key();       break;
                        case 0xf7:ON_OFF=!ON_OFF;  break;
                        default:break;
/**************设定工作模式子函数****************/
void set_adj(void)
        delay_LCM(100);
        set++;
    if(set>=4)set=0;
/****************按键加法子函数******************/
void inc_key(void)
        delay_LCM(100);
        switch(set)
        case 0:if(P1==0xf7)ON_OFF=!ON_OFF;       break;
        case 1:hour++;   if(hour>=23)hour=23;    break;
        case 2:minite++; if(minite>=59)minite=59;break;
        case 3:K++;if(K>=99)K=99;                                 break;
        default:break;
/****************按键减法子函数*****************/
void dec_key(void)
        delay_LCM(100);
        switch(set)
        case 1:hour--;  if(hour<=0)hour=0;    break;
        case 2:minite--;if(minite<=0)minite=0;break;
        case 3:K--;if(K<=1)K=1;                                  break;
        default:break;
/***************定时器t0初始化*******************/
        TMOD=0x01;                                  //time0为定时器,方式1
        TH0=0x3c;                                   //预置计数初值
        TL0=0xb0;
        EA=1;
        ET0=1;
        TR0=1;
void main(void)
    P1=0xff;        //初始化p1口,全设为1
        delay_LCM(500);                                                //延时500ms启动
        initLCM( );                                                               //LCD初始化
        init_timer0( );        //时钟定时器0初始化
    Init_DS18B20( ) ;                                                          //DS18B20初始化
    while (1)
               keyscan();                                            //按键扫描
                ReadTemperature();                                    //温度采集
                switch(set)                                           //LCD根据工作模式显示
                case 0:displayfun1();delay_LCM(1000);break;       //正常工作显示
                case 1:displayfun2();delay_LCM(1000);break;       //调整时显示
                case 2:displayfun3();delay_LCM(1000);break;       //调整分显示
                case 3:displayfun4();delay_LCM(1000);break;           //温度设定
                default:break;
                keyscan( );                                               //相当于延时
                if(ON_OFF==1)        //若温控标志位1, 控制LAMP动作
                        if(temp1>=K+1){outflag=1;OUT=0;}
                        if(temp1<K)
                                delay_LCM(1000);
                                if(temp1<K){outflag=0;OUT=1;}                        //
                else{outflag=0;OUT=1;}
LCD1602温控带时间.rar (21.11 KB, 下载次数: 25)
参与人数 8黑币 +167 收起 理由
正规007 + 10 很给力!
struct00 + 15
还有谁? + 10
jinsheng7533967 + 35
shuisheng60 + 35
yoxi + 35
Trump1438 + 15 绝世好帖!
刀刀见红 + 12 共享资料的黑币奖励!
收藏收藏4 分享淘帖 顶顶 踩踩
