查看: 2912|回复: 1
RGB_to_HSL HSL_to_RGB 颜色转换 STM32f030源码
void RGB_to_HSL(/*[in]*/const COLOR_RGB* rgb, /*[out]*/COLOR_HSL* hsl);
void HSL_to_RGB(const COLOR_HSL* hsl, COLOR_RGB* rgb);
  1. #include "colorconvert.h"
  2. #define min3v(v1, v2, v3)   ((v1)>(v2)? ((v2)>(v3)?(v3):(v2)):((v1)>(v3)?(v3):(v2)))
  3. #define max3v(v1, v2, v3)   ((v1)<(v2)? ((v2)<(v3)?(v3):(v2)):((v1)<(v3)?(v3):(v1)))
  4. void RGB_to_HSL(const COLOR_RGB* rgb, /*[out]*/COLOR_HSL* hsl)
  5. {
  6.     float h=0,s=0,l=0;
  7.           //int h=0;
  8.      // normalizes red-green-blue values
  9.     float r = rgb->red/255.f;
  10.     float g = rgb->green/255.f;
  11.     float b = rgb->blue/255.f;
  12.     float maxVal = max3v(r, g, b);
  13.     float minVal = min3v(r, g, b);
  14.   // hue
  15.   if(maxVal == minVal)
  16.     {
  17.         h = 0; // undefined
  18.     }
  19.   else if(maxVal==r && g>=b)
  20.     {
  21.         h = 60.0f*(g-b)/(maxVal-minVal);
  22.     }
  23.   else if(maxVal==r && g<b)
  24.     {
  25.         h = 60.0f*(g-b)/(maxVal-minVal) + 360.0f;
  26.     }
  27.   else if(maxVal==g)
  28.     {
  29.         h = 60.0f*(b-r)/(maxVal-minVal) + 120.0f;
  30.     }
  31.     else if(maxVal==b)
  32.     {
  33.         h = 60.0f*(r-g)/(maxVal-minVal) + 240.0f;
  34.     }
  35.   // luminance
  36.   l = (maxVal+minVal)/2.0f;
  37.     // saturation
  38.   if(l == 0 || maxVal == minVal)
  39.     {
  40.         s = 0;
  41.     }
  42.   else if(0<l && l<=0.5f)
  43.     {
  44.         s = (maxVal-minVal)/(maxVal+minVal);
  45.     }
  46.     else if(l>0.5f)
  47.     {
  48.         s = (maxVal-minVal)/(2 - (maxVal+minVal)); //(maxVal-minVal > 0)?
  49.     }
  50.     hsl->hue = (h>360)? 360 : ((h<0)?0:h);
  51.     hsl->saturation = ((s>1)? 1 : ((s<0)?0:s));
  52.     hsl->luminance = ((l>1)? 1 : ((l<0)?0:l));
  53. }
  54. void HSL_to_RGB(const COLOR_HSL *hsl, COLOR_RGB *rgb)
  55. {
  56.           int i;
  57.     float h = hsl->hue;  // h must be [0, 360]
  58.     float s = hsl->saturation; // s must be [0, 1]
  59.     float l = hsl->luminance;      // l must be [0, 1]
  60.     float R, G, B;
  61.
  62.   if( hsl->saturation == 0)
  63.     {
  64.         // achromatic color (gray scale)
  65.         R = G = B = 1*255.f;
  66.                 }
  67.                 else
  68.     {
  69.         float q = (l<0.5f)?(l * (1.0f+s)):(l+s - (l*s));
  70.         float p = (2.0f * l) - q;
  71.         float Hk = h/360.0f;
  72.         float T[3];
  73.         T[0] = Hk + 0.3333333f; // Tr   0.3333333f=1.0/3.0
  74.         T[1] = Hk;              // Tb
  75.         T[2] = Hk - 0.3333333f; // Tg
  76.   for(i=0; i<3; i++)
  77.         {
  78.             if(T[i] < 0) T[i] += 1.0f;
  79.             if(T[i] > 1) T[i] -= 1.0f;
  80.             if((T[i]*6) < 1)
  81.             {
  82.                 T[i] = p + ((q-p)*6.0f*T[i]);
  83.             }
  84.             else if((T[i]*2.0f) < 1) //(1.0/6.0)<=T[i] && T[i]<0.5
  85.             {
  86.                 T[i] = q;
  87.             }
  88.             else if((T[i]*3.0f) < 2) // 0.5<=T[i] && T[i]<(2.0/3.0)
  89.             {
  90.                 T[i] = p + (q-p) * ((2.0f/3.0f) - T[i]) * 6.0f;
  91.             }
  92.             else T[i] = p;
  93.         }
  94.         R = T[0]*255.0f;
  95.         G = T[1]*255.0f;
  96.         B = T[2]*255.0f;
  97.   }
  98.     rgb->red = (uint8_t)((R>255)? 255 : ((R<0)?0 : R));
  99.     rgb->green =(uint8_t)((G>255)? 255 : ((G<0)?0 : G));
  100.     rgb->blue = (uint8_t)((B>255)? 255 : ((B<0)?0 : B));
  101.   }
color.zip (1.73 KB, 下载次数: 32)
参与人数 2黑币 +80 收起 理由
arther + 30
收藏收藏1 分享淘帖 顶 踩
ID:511429 发表于 2019-7-28 15:03 | 只看该作者
楼主 你取RGB最小值那里写错了
