查看: 6025|回复: 1
蓝牙PIF天线和蛇形PCB天线设计指导
分享一个英文设计文档蓝牙PIF天线宇蛇形PCB板载天线设计资料
The real part of the impedance of this antenna is about 15-25W, depending on geometry and proximity to the
ground plane. The impedance matching is done by adjusting the length of the antenna until the input impedance
is at the unity conductance circle (when normalised to 50W), in the top half of the Smith chart (Point A). A shunt
capacitor is then connected between the antenna input and ground to match to 50W (Point B). Experimental
measurement is used to determine the correct design.
CSR 蓝牙PIF天线和蛇形PCB天线设计指导.pdf
544.51 KB, 下载次数: 53, 下载积分: 黑币 -5
蓝牙PIF天线和蛇形PCB天线设计指导
ID:234281 发表于 2021-2-18 14:37 | 只看该作者
感谢楼主分享资料
