查看: 4108|回复: 0
DHT11温湿度传感器单片机代码—串口发送检测数据到电脑
ID:474829 发表于 2019-2-3 14:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
#include <intrins.h>
typedef unsigned char  U8;       /* defined for unsigned 8-bits integer variable           无符号8位整型变量  */
typedef signed   char  S8;       /* defined for signed 8-bits integer variable                  有符号8位整型变量  */
typedef unsigned int   U16;      /* defined for unsigned 16-bits integer variable           无符号16位整型变量 */
typedef signed   int   S16;      /* defined for signed 16-bits integer variable           有符号16位整型变量 */
typedef unsigned long  U32;      /* defined for unsigned 32-bits integer variable           无符号32位整型变量 */
typedef signed   long  S32;      /* defined for signed 32-bits integer variable           有符号32位整型变量 */
typedef float          F32;      /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double         F64;      /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
#define   Data_0_time    4
//----------------IO口定义区--------------------//
sbit  P2_0  = P2^0 ;
//----------------定义区--------------------//
U8  U8FLAG,k;
U8  U8count,U8temp;
U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
U8  U8comdata;
U8  outdata[5];  //定义发送的字节数
U8  indata[5];
U8  count, count_r=0;
U8  str[5]={"RS232"};
U16 U16temp1,U16temp2;
SendData(U8 *a)
        outdata[0] = a[0];
        outdata[1] = a[1];
        outdata[2] = a[2];
        outdata[3] = a[3];
        outdata[4] = a[4];
        count = 1;
        SBUF=outdata[0];
       void Delay(U16 j)
    {      U8 i;
            for(;j>0;j--)
                for(i=0;i<27;i++);
       void  Delay_10us(void)
        U8 i;
        i--;
        i--;
        i--;
        i--;
        i--;
        i--;
        void  COM(void)
                U8 i;
       for(i=0;i<8;i++)
                       U8FLAG=2;
                   while((!P2_0)&&U8FLAG++);
                        Delay_10us();
                    Delay_10us();
                        Delay_10us();
                          U8temp=0;
             if(P2_0)U8temp=1;
                    U8FLAG=2;
                 while((P2_0)&&U8FLAG++);
                   //超时则跳出for循环
                    if(U8FLAG==1)break;
                   //判断数据位是0还是1
                // 如果高电平高过预定0高电平值则数据位为 1
                   U8comdata<<=1;
                      U8comdata|=U8temp;        //0
             }//rof
        //-----湿度读取子程序 ------------
        //----以下变量均为全局变量--------
        //----温度高8位== U8T_data_H------
        //----温度低8位== U8T_data_L------
        //----湿度高8位== U8RH_data_H-----
        //----湿度低8位== U8RH_data_L-----
        //----校验 8位 == U8checkdata-----
        //----调用相关子程序如下----------
        //---- Delay();, Delay_10us();,COM();
        void RH(void)
          //主机拉低18ms
       P2_0=0;
           Delay(180);
           P2_0=1;
         //总线由上拉电阻拉高 主机延时20us
           Delay_10us();
           Delay_10us();
           Delay_10us();
           Delay_10us();
         //主机设为输入 判断从机响应信号
           P2_0=1;
         //判断从机是否有低电平响应信号 如不响应则跳出,响应则向下运行
           if(!P2_0)                 //T !
           U8FLAG=2;
         //判断从机是否发出 80us 的低电平响应信号是否结束
           U8FLAG=2;
         //判断从机是否发出 80us 的高电平,如发出则进入数据接收状态
         //数据接收状态
           COM();
           U8RH_data_H_temp=U8comdata;
           COM();
           U8RH_data_L_temp=U8comdata;
           COM();
           U8T_data_H_temp=U8comdata;
           COM();
           U8T_data_L_temp=U8comdata;
           COM();
           U8checkdata_temp=U8comdata;
           P2_0=1;
         //数据校验
           U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
           if(U8temp==U8checkdata_temp)
                     U8RH_data_H=U8RH_data_H_temp;
                     U8RH_data_L=U8RH_data_L_temp;
                  U8T_data_H=U8T_data_H_temp;
                     U8T_data_L=U8T_data_L_temp;
                     U8checkdata=U8checkdata_temp;
           }//fi
           }//fi
//main()功能描述:  AT89C51  11.0592MHz         串口发
//送温湿度数据,波特率 9600
        U8  i,j;
        //uchar str[6]={"RS232"};
        /* 系统初始化 */
        TMOD = 0x20;          //定时器T1使用工作方式2
        TH1 = 253;        // 设置初值
        TL1 = 253;
        TR1 = 1;          // 开始计时
        SCON = 0x50;          //工作方式1,波特率9600bps,允许接收
        ES = 1;
        EA = 1;           // 打开所以中断
        TI = 0;
        RI = 0;
        SendData(str) ;   //发送到串口
        Delay(1);         //延时100US(12M晶振)
           //调用温湿度读取子程序
           RH();
           //串口显示程序
           str[0]=U8RH_data_H;
           str[1]=U8RH_data_L;
           str[2]=U8T_data_H;
           str[3]=U8T_data_L;
           str[4]=U8checkdata;
           //读取模块数据周期不易小于 2S
           Delay(20000);
        }//elihw
}// main
void RSINTR() interrupt 4 using 2
        U8 InPut3;
        if(TI==1) //发送中断
                TI=0;
                if(count!=5) //发送完5位数据
                        SBUF= outdata[count];
                        count++;
        if(RI==1)         //接收中断
                InPut3=SBUF;
                indata[count_r]=InPut3;
                count_r++;
                RI=0;
                if (count_r==5)//接收完4位数据
                //数据接收完毕处理。
                        count_r=0;
                str[0]=indata[0];
                 str[1]=indata[1];
                   str[2]=indata[2];
                         str[3]=indata[3];
                                 str[4]=indata[4];
                                 P0=0;
51_DHT11.zip
41.64 KB, 下载次数: 22, 下载积分: 黑币 -5
收藏收藏2 分享淘帖 顶 踩
