查看: 3411|回复: 4
单片机eeprom程序问题
//#include <REGX52.H>
#include <STC8.H>
#include "intrins.h"
sbit LED1 = P1^0;
sbit LED2 = P1^1;
sbit K1   = P3^2;                           //按钮1
sbit K2   = P3^3;                           //按钮2
sbit Y=P1^0;
sbit W=P1^1;
//unsigned  int t,addr;
unsigned  char V,dat,n,m,k;
unsigned char code LED[] = {0xFE,0xFD,0xFC};
//测试工作频率为11.0592MHz
//sfr     IAP_DATA    =   0xC2;
//sfr     IAP_ADDRH   =   0xC3;
//sfr     IAP_ADDRL   =   0xC4;
//sfr     IAP_CMD     =   0xC5;
//sfr     IAP_TRIG    =   0xC6;
//sfr     IAP_CONTR   =   0xC7;
#define WT_30M          0x80
#define WT_24M          0x81
#define WT_20M          0x82
#define WT_12M          0x83
#define WT_6M           0x84
#define WT_3M           0x85
#define WT_2M           0x86
#define WT_1M           0x87
void IapIdle()
    IAP_CONTR = 0;                              //关闭IAP功能
    IAP_CMD = 0;                                //清除命令寄存器
    IAP_TRIG = 0;                               //清除触发寄存器
    IAP_ADDRH = 0x80;                           //将地址设置到非IAP区域
    IAP_ADDRL = 0;
char IapRead(int addr)
    char dat;
    IAP_CONTR = WT_12M;                         //使能IAP
    IAP_CMD = 1;                                //设置IAP读命令
    IAP_ADDRL = addr;                           //设置IAP低地址
    IAP_ADDRH = addr >> 8;                      //设置IAP高地址
    IAP_TRIG = 0x5a;                            //写触发命令(0x5a)
    IAP_TRIG = 0xa5;                            //写触发命令(0xa5)
    _nop_();
    dat = IAP_DATA;                             //读IAP数据
    IapIdle();                                  //关闭IAP功能
    return dat;
void IapProgram(int addr, char dat)
    IAP_CMD = 2;                                //设置IAP写命令
    IAP_DATA = dat;                             //写IAP数据
    _nop_();
void IapErase(int addr)
    IAP_CMD = 3;                                //设置IAP擦除命令
    _nop_();                                    //
void main(void)
   //uchar V;
   V = IapRead(0x0016);                          // 开机读取EEPROM区2002h数据,还原关电前LED的亮灭状况
   if(V == 2)          {LED1=0;LED2=1;}
   else if(V == 6){LED1=0;LED2=0;}
      if(!K1)
              while(!K1);
              LED1=0;LED2=1;
             IapErase(0x0000);                  // 擦除第1个扇区(2000h~21FFh)
              IapProgram(0x0016,2);          // 对EEPROM区2002h写入2
          if(!K2)
               while(!K2);
              LED1=0;LED2=0;
              IapProgram(0x0016,6);                          // 对EEPROM区2002h写入6
  n=IapRead(0x0016);
   EA=1;
        EX0=1;
  IT0=1;
                 if(n==3)
                  n=0;
                 P1=LED[n];
        IapErase(0x0000);
        IapProgram(0x0016,n);
void i0() interrupt 0
        n++;
上面星号部分可以存,下面的存不了,求解
ID:123289 发表于 2019-2-20 13:23 | 只看该作者
你读到的N是什么呢?
ID:474677 发表于 2019-2-20 12:04 | 只看该作者
wulin 发表于 2019-2-19 15:20
IapErase(0x0000);
IapProgram(0x0000,n);
习惯都是单字节按扇区的首地址写,多字节按 ...
你给中间地址STC单片机也会按扇区首地址写EEPROM,手册里面有讲的
ID:57614 发表于 2019-2-20 10:46 | 只看该作者
IapErase(0x0000);
可以的,好了,中断加标志,没想通
ID:213173 发表于 2019-2-19 15:20 | 只看该作者
IapErase(0x0000);
习惯都是单字节按扇区的首地址写,多字节按扇区的首地址顺序写。没有试过单独写中间地址是否会出错。
