查看: 3355|回复: 0
Arduino UNO 驱动 SMS0801D段式液晶显示模块
ID:280298 发表于 2019-2-20 13:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1. 代码为纯源码;
2. 代码为本人原创;
3. 转载,请注明出处;
4. 机械设计一名,粗陋之处,各位高手请无视;
  1. unsigned char ChuShiHua[] = {0xfc, 0xfc, 0x02, 0xfc, 0xfc, 0x02, 0xfc, 0xfc};
  2. unsigned char Di_pin = 8;   //连接到
  3. unsigned char Clk_pin = 9;
  4. unsigned char KaiShi = 7;
  5. unsigned char TingZhi = 3;
  6. unsigned char Qing = 2;
  7. unsigned char TestFlag = 0;
  8. unsigned char DisLCD[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
  9. void QingLing(void);
  10. void ZhuanHuan(void);
  11. char m, s;
  12. char hx[] = {0, 0, 0, 0};
  13. char mx[] = {0, 0};
  14. char sx[] = {0, 0};
  15. int h;
  16. //-------------------------------------------------------------------------------
  17. //数码笔段定义:  8字的最上面一笔段为A笔段,顺时针方向依次为BCDEF笔段,中间的是G笔段
  18. //数码笔段顺序:  D76543210
  19. //                ABCDEFGX
  20. //unsigned char LCDbianma[] = {0xFC, 0x60, 0xDA, 0xF2, 0x66, 0xB6, 0xBE, 0xE0, 0xFE, 0xF6, 0x00, 0x02}; //,0x9C,0xCE,0x9E,0x8E};
  21. //                            0    1    2    3    4     5   6     7   8     9   空格  -          C   P     E   F
  22. //-------------------------------------------------------------------------------
  23. void setup()
  24. {
  25.   pinMode(Di_pin, OUTPUT);
  26.   pinMode(Clk_pin, OUTPUT);
  27.   pinMode(KaiShi, INPUT_PULLUP);
  28.   pinMode(TingZhi, INPUT_PULLUP);
  29.   pinMode(Qing, INPUT_PULLUP);
  30.   QingLing();
  31. }
  32. void loop()
  33. {
  34.   if (digitalRead(KaiShi) == LOW)
  35.   {
  36.     delay(50);
  37.     if (digitalRead(KaiShi) == LOW)
  38.     {
  39.       TestFlag = 1;
  40.     }
  41.   }
  42.   if (digitalRead(Qing) == LOW)
  43.   {
  44.     QingLing ();
  45.   }
  46.   while (TestFlag == 1)
  47.   {
  48.     for (long TimeS = 0;  ; TimeS++)
  49.     {
  50.       h = TimeS / 3600;   //  小时
  51.       m = (TimeS - h * 3600) / 60; //  分钟
  52.       s = TimeS - h * 3600 - m * 60;
  53.       hx[3] = h / 1000;    //  千位
  54.       hx[2] = h / 100;    //  百位
  55.       hx[1] = h / 10;    //  十位
  56.       hx[0] = h % 10;  //  个位
  57.       mx[1] = m / 10;    //  十位
  58.       mx[0] = m % 10;  //  个位
  59.       sx[1] = s / 10;    //  十位
  60.       sx[0] = s % 10;  //  个位
  61.       //digitalWrite(latchPin, LOW);
  62.       //shiftOut(Di_pin, Clk_pin, LSBFIRST,0x00);   //  这里刷数据必须用 LSBFIRST(从最低位开始刷数据)
  63.       //digitalWrite(latchPin, HIGH);
  64.       if (TimeS < 360000)  // 99.99.99小时内分辨率为1秒
  65.       {
  66.         ZhuanHuan(hx[1], 0);
  67.         //delay(10);
  68.         ZhuanHuan(hx[0], 1);
  69.         //delay(10);
  70.         DisLCD[2] = 0x02;
  71.         ZhuanHuan(mx[1], 3);
  72.         //delay(10);
  73.         ZhuanHuan(mx[0], 4);
  74.         //delay(10);
  75.         DisLCD[5] = 0x02;
  76.         ZhuanHuan(sx[1], 6);
  77.         //delay(10);
  78.         ZhuanHuan(sx[0], 7);
  79.         //delay(10);
  80.       }
  81.       else               //  大于99.99.99小时,分辨率为1分钟
  82.       {
  83.         // DisLCD[7] = 0x00;
  84.         DisLCD[0] = 0x00;
  85.         ZhuanHuan(hx[3], 1);
  86.         //delay(10);
  87.         ZhuanHuan(hx[2], 2);
  88.         //delay(10);
  89.         ZhuanHuan(hx[1], 3);
  90.         //delay(10);
  91.         ZhuanHuan(hx[0], 4);
  92.         //delay(10);
  93.         DisLCD[5] = 0x02;
  94.         ZhuanHuan(mx[1], 6);
  95.         //delay(10);
  96.         ZhuanHuan(mx[0], 7);
  97.         //delay(10);
  98.       }
  99.       for (unsigned char i = 0; i < 8; i++) //一共8位数,i<8
  100.       {
  101.         //开始刷屏
  102.         shiftOut(Di_pin, Clk_pin, LSBFIRST, DisLCD[i]);  //  这里刷数据必须用 LSBFIRST(从最低位开始刷数据)
  103.       }
  104.       if (digitalRead(TingZhi) == LOW)
  105.       {
  106.         TestFlag = 0;
  107.         TimeS = 0;
  108.         break;
  109.       }
  110.       delay(1000);
  111.     }
  112.   }
  113. }
  114. //Serial.println(digitalRead(KaiShi));
  115. //Serial.println(digitalRead(Stop));
  116. //Serial.println(digitalRead(QingL));
  117. void QingLing()
  118. {
  119.   for (unsigned char i = 0; i < 8; i++) //一共8位数,i<8
  120.   {
  121.     //初始化上电显示为 00-00-00
  122.     shiftOut(Di_pin, Clk_pin, LSBFIRST, ChuShiHua[i]);  //  这里刷数据必须用 LSBFIRST(从最低位开始刷数据)
  123.   }
  124. }
  125. void ZhuanHuan(int d, int a)
  126. {
  127.   switch (d)
  128.   {
  129.     case 0:
  130.       DisLCD[a] = 0xFC;
  131.       break;
  132.     case 1:
  133.       DisLCD[a] = 0x60;
  134.       break;
  135.     case 2:
  136.       DisLCD[a] = 0xDA;
  137.       break;
  138.     case 3:
  139.       DisLCD[a] = 0xF2;
  140.       break;
  141.     case 4:
  142.       DisLCD[a] = 0x66;
  143.       break;
  144.     case 5:
  145.       DisLCD[a] = 0xB6;
  146.       break;
  147.     case 6:
  148.       DisLCD[a] = 0xBE;
  149.       break;
  150.     case 7:
  151.       DisLCD[a] = 0xE0;
  152.       break;
  153.     case 8:
  154.       DisLCD[a] = 0xFE;
  155.       break;
  156.     case 9:
  157.       DisLCD[a] = 0xF6;
  158.       break;
  159.   }
  160. }
