查看: 4457|回复: 3
[求助]求助 帮忙看看这两程序啊
ID:41360 发表于 2012-6-6 23:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求大神看看 这个程序中哪个语句可以控制二极管发光? 是什么时间发光啊?
程序:
LEDDUAN EQU 8004H
LEDWEI  EQU 8002H
KVALUE  EQU 52H
NUM     EQU 50H
        ORG 0000H
        LJMP MAIN
        ORG 000BH
        LJMP COUNT
        ORG 0100H
MAIN:   CLR A
        CLR B
        MOV R0,#00H
        MOV R1,#00H
        MOV R2,#00H
        MOV R3,#00H
        MOV R4,#00H
        MOV R5,#00H
        MOV NUM,#10
        MOV SP,#70H
        MOV DPTR,#LEDDUAN
        MOV A,#00H
        MOVX @DPTR,A
        MOV DPTR,#LEDWEI
        MOV A,#00H
        MOVX @DPTR,A
J1S:    MOV TMOD,#01H
        MOV TH0,#3CH
        MOV TL0,#0B0H
        SETB EA
        SETB ET0
        SETB TR0
START:  LCALL DISPLAY
        LCALL KEYBOARD
        MOV A,KVALUE
        CJNE A,#0FFH,TIME
        LCALL CHANGE
 TIME:  CJNE R0,#60,NEXT2 ;SECOND
        MOV R0,#00H
        INC R1
        CJNE R1,#60,NEXT2 ;MINUTE
        MOV R1,#00H
        INC R2
        CJNE R2,#24,NEXT2 ;HOUR
        MOV R2,#00H
 NEXT2: SJMP START
;***********CHANGE TIME****************
CHANGE: CLR TR0
 CHOUR: MOV R5,#01H
CHOUR2: LCALL DISPLAY
        LCALL KEYBOARD
        MOV A,KVALUE
        CJNE A,#0FFH,KEY1
        LJMP CMIN
  KEY1: CJNE A,#10H,KEY2
        LJMP ADHOUR
  KEY2: LJMP CHOUR2
 ADHOUR:INC R2
        CJNE R2,#24,JHOUR
        MOV R2,#00H
 JHOUR: LJMP CHOUR2
 CMIN:  MOV R5,#02H
 CMIN2: LCALL DISPLAY
        LCALL KEYBOARD
        MOV A,KVALUE
        CJNE A,#0FFH,KEY3
        LJMP CSEC
  KEY3: CJNE A,#10H,KEY4
        LJMP ADMIN
  KEY4: LJMP CMIN2
 ADMIN: INC R1
        CJNE R1,#60,JMIN
        MOV R1,#00H
 JMIN:  LJMP CMIN2
 CSEC:  MOV R5,#03H
 CSEC2: LCALL DISPLAY
        LCALL KEYBOARD
        MOV A,KVALUE
        CJNE A,#0FFH,KEY5
        LJMP EXCH
  KEY5: CJNE A,#10H,KEY6
        LJMP ADSEC
  KEY6: LJMP CSEC2
 ADSEC: INC R0
        CJNE R0,#60,JSEC
        MOV R0,#00H
  JSEC: LJMP CSEC2
  EXCH: MOV TH0,#3CH
        MOV TL0,#0B0H
        MOV R5,#00H
        SETB TR0
        RET
;*************END***************
;***********DISPLAY*************
DISPLAY:MOV DPTR,#LEDWEI        ;HOUR
        MOV A,#20H
        MOVX @DPTR,A
        MOV A,R2
        MOV B,#10
        DIV AB
        MOV DPTR,#LEDTAB
        MOVC A,@A+DPTR
        CJNE R5,#01H,CMOD0
        ORL A,#80H              ;POINT
CMOD0:  MOV DPTR,#LEDDUAN
        MOVX @DPTR,A
        LCALL D2MS
        MOV DPTR,#LEDWEI
        MOV A,#10H
        MOVX @DPTR,A
        MOV A,B
        MOV DPTR,#LEDTAB
        MOVC A,@A+DPTR
        CJNE R5,#00H,JU1
        SJMP POI1
  JU1:  CJNE R5,#01H,CMOD1
  POI1: ORL A,#80H              ;POINT
CMOD1:  MOV DPTR,#LEDDUAN
        MOVX @DPTR,A
        LCALL D2MS
        MOV DPTR,#LEDWEI        ;MINUTE
        MOV A,#08H
        MOVX @DPTR,A
        MOV A,R1
        MOV B,#10
        DIV AB
        MOV DPTR,#LEDTAB
        MOVC A,@A+DPTR
        CJNE R5,#02H,CMOD2
        ORL A,#80H              ;POINT
CMOD2:  MOV DPTR,#LEDDUAN
        MOVX @DPTR,A
        LCALL D2MS
        MOV DPTR,#LEDWEI
        MOV A,#04H
        MOVX @DPTR,A
        MOV A,B
        MOV DPTR,#LEDTAB
        MOVC A,@A+DPTR
        CJNE R5,#00H,JU2
        SJMP POI2
  JU2:  CJNE R5,#02H,CMOD3
  POI2: ORL A,#80H              ;POINT
CMOD3:  MOV DPTR,#LEDDUAN
        MOVX @DPTR,A
        LCALL D2MS
        MOV DPTR,#LEDWEI        ;SECOND
        MOV A,#02H
        MOVX @DPTR,A
        MOV A,R0
        MOV B,#10
        DIV AB
        MOV DPTR,#LEDTAB
        MOVC A,@A+DPTR
        CJNE R5,#03H,CMOD4
        ORL A,#80H              ;POINT
CMOD4:  MOV DPTR,#LEDDUAN
        MOVX @DPTR,A
        LCALL D2MS
        MOV DPTR,#LEDWEI
        MOV A,#01H
        MOVX @DPTR,A
        MOV A,B
        MOV DPTR,#LEDTAB
        MOVC A,@A+DPTR
        CJNE R5,#00H,JU3
        SJMP POI3
  JU3:  CJNE R5,#03H,CMOD5
  POI3: ORL A,#80H              ;POINT
CMOD5:  MOV DPTR,#LEDDUAN
        MOVX @DPTR,A
        LCALL D2MS
        RET
;**********END**************
D2MS:   MOV R4,#0AH
   DL2: MOV R3,#32H
   DL1: NOP
        NOP
        DJNZ R3,DL1
        DJNZ R4,DL2
        RET
D10MS:  MOV R4,#64H
   DL4: MOV R3,#14H
   DL3: NOP
        NOP
        NOP
        DJNZ R3,DL3
        DJNZ R4,DL4
        RET
COUNT:  DJNZ NUM,NEXT
        INC R0
        MOV NUM,#10
  NEXT: MOV TH0,#3CH
        MOV TL0,#0B0H
        RETI
;*******KEYBOARD*************
KEYBOARD:MOV P1,#0FFH
         MOV KVALUE,#16H
WAIT:  MOV A,P1
       ANL A,#03H
       XRL A,#03H
       JZ NOKEY1
       LCALL D10MS
       MOV A,P1
       ANL A,#03H
       XRL A,#03H
       JZ NOKEY1
       MOV A,P1
       ANL A,#03H
       CJNE A,#02H,NK1
       MOV KVALUE,#0FFH
       LJMP DK1A
NK1:   CJNE A,#01H,DK1A
       MOV KVALUE,#10H
DK1A:  MOV A,P1
       ANL A,#03H
       XRL A,#03H
       JNZ DK1A
;*********LIE-2***************
NOKEY1: RET
;********END************
LEDTAB: DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH
ID:27916 发表于 2012-6-7 08:58 | 只看该作者
DISPLAY以下的
[此贴子已经被作者于2012-6-7 8:58:23编辑过]
ID:7485 发表于 2012-9-11 10:28 | 只看该作者
楼主讲的是发光二级管,不是数码管。
我没看见哪儿有发光二级管。
ID:44646 发表于 2012-9-13 16:55 | 只看该作者
可以设断点来找你需要的程序。
