查看: 5001|回复: 0
keil编译错误ERROR L104: MULTIPLE PUBLIC DEFINITIONS,求大佬帮忙看看下
回帖奖励 10 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次(中奖概率 10%)
ID:478396 发表于 2019-2-28 15:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit RS = P2^0;
sbit RW = P2^1;
sbit EN = P2^2;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
void delay_us(unsigned int r) /{
if (r== 0)
  return ;
  while (--r);
void delay_ms(unsigned char f)
unsigned char k, u;
for (k = 1; k < f; k++)
   for (u = 1;u; u++)
void LCD_write_com(unsigned char com)
RS_CLR;
RW_CLR;
EN_SET;
P0 = com;
delay_us(5);
EN_CLR;
void LCD_write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
P0 = Data;
delay_us(5);
EN_CLR;
/*                   ÇåÆáoˉêy                                     */
void LCD_clear(void)
LCD_write_com(0x01);
delay_ms(5);}
void LCD_write_str(unsigned char x1,unsigned char y1,unsigned char *s)
if (y1 == 0)
LCD_write_com(0x80 + x1);
LCD_write_com(0xC0 + x1);
while (*s)
LCD_write_Data( *s);
s ++;
void LCD_write_char(unsigned char x1,unsigned char y1,unsigned char Data)
if (y1 == 0)
LCD_write_Data( Data);
void LCD_init(void)
   LCD_write_com(0x38);
   delay_ms(5);
   delay_ms(5);
   delay_ms(5);
   LCD_write_com(0x08);
   LCD_write_com(0x06);
   delay_ms(5);
   LCD_write_com(0x0C);
   void main(void)
  unsigned char i2;
unsigned char *p;
delay_ms(100);
LCD_init();
while (1)
i2 = 1;
p = "333333";
LCD_clear();
LCD_write_str(2,0,"Welcome to");
delay_ms(250);
while (*p)
LCD_write_char(i2,1,*p);
i2 ++;
p ++;
delay_ms(250);
delay_ms(250);
头文件
REG52.H
Header file for generic 80C52 and 80C32 microcontroller.
Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc.
All rights reserved.
#ifndef __REG52_H__
#define __REG52_H__
/*  BYTE Registers  */
sfr P0    = 0x80;
sfr P1    = 0x90;
sfr P2    = 0xA0;
sfr P3    = 0xB0;
sfr PSW   = 0xD0;
sfr ACC   = 0xE0;
sfr B     = 0xF0;
sfr SP    = 0x81;
sfr DPL   = 0x82;
sfr DPH   = 0x83;
sfr PCON  = 0x87;
sfr TCON  = 0x88;
sfr TMOD  = 0x89;
sfr TL0   = 0x8A;
sfr TL1   = 0x8B;
sfr TH0   = 0x8C;
sfr TH1   = 0x8D;
sfr IE    = 0xA8;
sfr IP    = 0xB8;
sfr SCON  = 0x98;
sfr SBUF  = 0x99;
/*  8052 Extensions  */
sfr T2CON  = 0xC8;
sfr RCAP2L = 0xCA;
sfr RCAP2H = 0xCB;
sfr TL2    = 0xCC;
sfr TH2    = 0xCD;
/*  BIT Registers  */
/*  PSW  */
sbit CY    = PSW^7;
sbit AC    = PSW^6;
sbit F0    = PSW^5;
sbit RS1   = PSW^4;
sbit RS0   = PSW^3;
sbit OV    = PSW^2;
sbit P     = PSW^0; //8052 only
/*  TCON  */
sbit TF1   = TCON^7;
sbit TR1   = TCON^6;
sbit TF0   = TCON^5;
sbit TR0   = TCON^4;
sbit IE1   = TCON^3;
sbit IT1   = TCON^2;
sbit IE0   = TCON^1;
sbit IT0   = TCON^0;
/*  IE  */
sbit EA    = IE^7;
sbit ET2   = IE^5; //8052 only
sbit ES    = IE^4;
sbit ET1   = IE^3;
sbit EX1   = IE^2;
sbit ET0   = IE^1;
sbit EX0   = IE^0;
/*  IP  */
sbit PT2   = IP^5;
sbit PS    = IP^4;
sbit PT1   = IP^3;
sbit PX1   = IP^2;
sbit PT0   = IP^1;
sbit PX0   = IP^0;
/*  P3  */
sbit RD    = P3^7;
sbit WR    = P3^6;
sbit T1    = P3^5;
sbit T0    = P3^4;
sbit INT1  = P3^3;
sbit INT0  = P3^2;
sbit TXD   = P3^1;
sbit RXD   = P3^0;
/*  SCON  */
sbit SM0   = SCON^7;
sbit SM1   = SCON^6;
sbit SM2   = SCON^5;
sbit REN   = SCON^4;
sbit TB8   = SCON^3;
sbit RB8   = SCON^2;
sbit TI    = SCON^1;
sbit RI    = SCON^0;
/*  P1  */
sbit T2EX  = P1^1; // 8052 only
sbit T2    = P1^0; // 8052 only
/*  T2CON  */
sbit TF2    = T2CON^7;
sbit EXF2   = T2CON^6;
sbit RCLK   = T2CON^5;
sbit TCLK   = T2CON^4;
sbit EXEN2  = T2CON^3;
sbit TR2    = T2CON^2;
sbit C_T2   = T2CON^1;
sbit CP_RL2 = T2CON^0;
#endif
要生成hex时出现时,出现这个怎么解决啊
Rebuild target 'Target 1'
compiling 18b20.c...
compiling L1602.C...
linking...
*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
    SYMBOL:  MAIN
    MODULE:  .\L1602.obj (L1602)
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?MAIN?L1602
Program Size: data=28.0 xdata=0 code=851
Target not created.
Build Time Elapsed:  00:00:00
