查看: 2805|回复: 0
求助undefined reference to `usbInterruptIsReady'编译错误
ID:487476 发表于 2019-3-9 16:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在man函数里
if(usbInterruptIsReady()){
            /* called after every poll of the interrupt endpoint */
            advanceCircleByFixedAngle();
            DBG1(0x03, 0, 0);   /* debug output: interrupt report prepared */
            usbSetInterrupt((void *)&reportBuffer, sizeof(reportBuffer));
在头文件<usbdrv.h>里有
#if USB_CFG_HAVE_INTRIN_ENDPOINT
        USB_PUBLIC void usbSetInterrupt(uchar *data, uchar len);//////////////////////////////
       #define usbInterruptIsReady()   (usbTxLen1 & 0x10)//////////////////////////////////////////
#endif /* USB_CFG_HAVE_INTRIN_ENDPOINT */
编译时出错
undefined reference to `usbSetInterrupt'
请问是哪里的问题
