查看: 8418|回复: 4
Arduino制作的指纹锁(源程序Fingerprint Sensor library库)
ID:489767 发表于 2019-3-13 11:03 | 显示全部楼层 |阅读模式
先下载Fingerprint Sensor library运行库,解压库并放到arduino 运行库里,然后在arduino里样例里打开一个如下案例,
路径如下:
Example ->Adafruit_Fingerprint→fingerprint
接线
接线
FPM10A
FPM10A
  1. #include <Adafruit_Fingerprint.h>
  2. #include <SoftwareSerial.h>
  3. int getFingerprintIDez();
  4. // pin #2 is IN from sensor (GREEN wire)
  5. // pin #3 is OUT from arduino  (WHITE wire)
  6. SoftwareSerial mySerial(2, 3);
  7. Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  8. void setup()
  9. {
  10.   Serial.begin(9600);
  11.   Serial.println("fingertest");
  12.   // set the data rate for the sensor serial port
  13.   finger.begin(57600);
  14.
  15.   if (finger.verifyPassword()) {
  16.     Serial.println("Found fingerprint sensor!");
  17.   } else {
  18.     Serial.println("Did not find fingerprint sensor :(");
  19.     while (1);
  20.   }
  21.   Serial.println("Waiting for valid finger...");
  22. }
  23. void loop()                     // run over and over again
  24. {
  25.   getFingerprintIDez();
  26.   delay(50);            //don't ned to run this at full speed.
  27. }
  28. uint8_t getFingerprintID() {
  29.   uint8_t p = finger.getImage();
  30.   switch (p) {
  31.     case FINGERPRINT_OK:
  32.       Serial.println("Image taken");
  33.       break;
  34.     case FINGERPRINT_NOFINGER:
  35.       Serial.println("No finger detected");
  36.       return p;
  37.     case FINGERPRINT_PACKETRECIEVEERR:
  38.       Serial.println("Communication error");
  39.       return p;
  40.     case FINGERPRINT_IMAGEFAIL:
  41.       Serial.println("Imaging error");
  42.       return p;
  43.     default:
  44.       Serial.println("Unknown error");
  45.       return p;
  46.   }
  47.   // OK success!
  48.   p = finger.image2Tz();
  49.   switch (p) {
  50.     case FINGERPRINT_OK:
  51.       Serial.println("Image converted");
  52.       break;
  53.     case FINGERPRINT_IMAGEMESS:
  54.       Serial.println("Image too messy");
  55.       return p;
  56.     case FINGERPRINT_PACKETRECIEVEERR:
  57.       Serial.println("Communication error");
  58.       return p;
  59.     case FINGERPRINT_FEATUREFAIL:
  60.       Serial.println("Could not find fingerprint features");
  61.       return p;
  62.     case FINGERPRINT_INVALIDIMAGE:
  63.       Serial.println("Could not find fingerprint features");
  64.       return p;
  65.     default:
  66.       Serial.println("Unknown error");
  67.       return p;
  68.   }
  69.
  70.   // OK converted!
  71.   p = finger.fingerFastSearch();
  72.   if (p == FINGERPRINT_OK) {
  73.     Serial.println("Found a print match!");
  74.   } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
  75.     Serial.println("Communication error");
  76.     return p;
  77.   } else if (p == FINGERPRINT_NOTFOUND) {
  78.     Serial.println("Did not find a match");
  79.     return p;
  80.   } else {
  81.     Serial.println("Unknown error");
  82.     return p;
  83.   }
  84.
  85.   // found a match!
  86.   Serial.print("Found ID #"); Serial.print(finger.fingerID);
  87.   Serial.print(" with confidence of "); Serial.println(finger.confidence);
  88. }
  89. // returns -1 if failed, otherwise returns ID #
  90. int getFingerprintIDez() {
  91.   uint8_t p = finger.getImage();
  92.   if (p != FINGERPRINT_OK)  return -1;
  93.   p = finger.image2Tz();
  94.   if (p != FINGERPRINT_OK)  return -1;
  95.   p = finger.fingerFastSearch();
  96.   if (p != FINGERPRINT_OK)  return -1;
  97.
  98.   // found a match!
  99.   Serial.print("Found ID #");
  100. Serial.print(finger.fingerID);
  101.   Serial.print(" with confidence of ");
  102. Serial.println(finger.confidence);
  103.   return finger.fingerID;
  104. }
fingerprint.rar
1.2 KB, 下载次数: 66, 下载积分: 黑币 -5
指纹锁文件
ID:556810 发表于 2019-6-6 20:28 | 显示全部楼层
你好,请问串口监视器中出现 did not Found fingerprint Sensor!该怎么解决呢
ID:864911 发表于 2020-12-21 17:58 | 显示全部楼层
ID:879963 发表于 2021-1-23 15:57 来自触屏版 | 显示全部楼层
它有没有 什么弊端
ID:879963 发表于 2021-1-23 20:25 来自触屏版 | 显示全部楼层
怎么录指纹
