查看: 4373|回复: 1
stm32光电编码器例程
ID:490589 发表于 2019-3-14 12:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
timer.c
int Temp1= 0 ;
int Temp2= 0 ;
u32 encod3 = 0 ;
u32 encod4 = 0 ;
long all3_Count = 0 ;
long all4_Count = 0 ;
void TIM4_Encoder_Init(u16 arr,u16 psc)
        GPIO_InitTypeDef      GPIO_InitStructure;
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_ICInitTypeDef         TIM_ICInitStructure;
        NVIC_InitTypeDef         NVIC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4|RCC_APB1Periph_TIM3, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOA, ENABLE);
        /*- 正交编码器输入引脚 PB->6   PB->7 */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        /*- TIM4编码器模式配置 -*/
   TIM_DeInit(TIM4);
        TIM_TimeBaseStructure.TIM_Period =arr;
        TIM_TimeBaseStructure.TIM_Prescaler = psc;
        TIM_TimeBaseStructure.TIM_ClockDivision =TIM_CKD_DIV1 ;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
        TIM_EncoderInterfaceConfig(TIM4 , TIM_EncoderMode_TI12, TIM_ICPolarity_BothEdge ,TIM_ICPolarity_BothEdge);//使用编码器模式3,上升下降都计数
        TIM_ICStructInit(&TIM_ICInitStructure);        //配置滤波器
        TIM_ICInitStructure.TIM_ICFilter = 8;
        TIM_ICInit(TIM4, &TIM_ICInitStructure);
        TIM4->CNT =3999;
        TIM_ClearFlag(TIM4, TIM_FLAG_Update);
          TIM_ITConfig( TIM4, TIM_IT_Update ,        ENABLE );
   NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;  //TIM4中断
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
        NVIC_Init(&NVIC_InitStructure);  //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
        TIM_Cmd(TIM4, ENABLE);   //启动TIM4定时器
void TIM2_Encoder_Init(u16 arr,u16 psc)
        TIM_ICInitTypeDef  TIM2_ICInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);        //使能TIM2时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);  //使能GPIOA时钟
//        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
        /*  编码器引脚初始化 ,PA-2 和 PA-3*/
        GPIO_InitStructure.GPIO_Pin  =  GPIO_Pin_1|GPIO_Pin_0;  //PA2 清除之前设置
        GPIO_Init(GPIOA, &GPIO_InitStructure);
/* 初始化定时器2 TIM2定时器的配置*/
        TIM_DeInit(TIM2);
        TIM_TimeBaseStructure.TIM_Period = arr; //设定计数器自动重装值
        TIM_TimeBaseStructure.TIM_Prescaler =psc;         //预分频器
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
        TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
        TIM_EncoderInterfaceConfig(TIM2 , TIM_EncoderMode_TI12, TIM_ICPolarity_BothEdge ,TIM_ICPolarity_BothEdge);//使用编码器模式3,上升下降都计数
        TIM_ICStructInit(&TIM2_ICInitStructure);        //配置滤波器
//        TIM2_ICInitStructure.TIM_Channel = TIM_Channel_3|TIM_Channel_4 ;
//        TIM2_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1 ;
        TIM2_ICInitStructure.TIM_ICFilter = 8;
        TIM_ICInit(TIM2, &TIM2_ICInitStructure);
        TIM2->CNT =3999;
        TIM_ClearFlag(TIM2, TIM_FLAG_Update);
          TIM_ITConfig( TIM2, TIM_IT_Update ,        ENABLE );
   NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;  //TIM4中断
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
        TIM_Cmd(TIM2, ENABLE);   //启动TIM4定时器
void TIM2_IRQHandler(void)
        if (  TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET )
                if ( (TIM2->CR1&0x0010)==0 )
                        encod3++ ;
                        encod3-- ;
                LED0 = !LED0 ;
   TIM_ClearITPendingBit(TIM2, TIM_IT_CC1|TIM_IT_Update); //清除中断标志位
void TIM4_IRQHandler()
        if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
                if ( (TIM4->CR1&0x0010)==0 )
                        encod4++ ;
                        encod4-- ;
                LED1 = !LED1 ;
        TIM_ClearITPendingBit(TIM4, TIM_IT_Update);
main.c
        定时器4 :B 接 PB6 , A 接 PB7.面向自己顺时针为正 , CNT的值增加。
        定时器2 :B 接 PA0 , A 接 PA1.面向自己顺时针为正 , CNT的值增加。
int main(void)
        u8 tab = 0;
        float all_num4 = 0 ;  //转过的圈数
        float all_num3 = 0 ;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 设置中断优先级分组2
        delay_init();                     //延时函数初始化
        uart_init(9600);                 //9600
        LED_Init();
        KEY_Init();                                 //初始化与LED连接的硬件接口
        TIM2_Encoder_Init(7999,0);
        TIM4_Encoder_Init( 7999 ,0);                //以1Mhz的频率计数,以微秒级别进行捕获计时
///////////定时器4 的参数////////////////////////////
                printf("定时器4: %d\r\n" , TIM4->CNT ) ;
                if (encod4 ==0 )
                                all4_Count = TIM4->CNT-3999 ;
                        all4_Count = 3999 + (encod4 - 1) *8000 +TIM4->CNT ;
                all_num4 =  all4_Count/4000.000 ;
                printf("encoder4 的值是:%d--捕获到的总数是%ld*****转过的圈数是%lf\r\n" , encod4,all4_Count , all_num4 );
///////////定时器2 的参///////////////////////////
                printf("定时器2: %d\r\n" , TIM2->CNT ) ;
                if (encod3 ==0 )
                                all3_Count = TIM2->CNT-3999 ;
                        all3_Count = 3999 + (encod3 - 1) *8000 +TIM2->CNT ;
                all_num3 =  all3_Count/4000.000 ;
                printf("encoder2 的值是:%d--捕获到的总数是%ld*****转过的圈数是%lf\r\n" , encod3 ,all3_Count , all_num3 );
收藏收藏2 分享淘帖 顶顶 踩踩
ID:517637 发表于 2020-1-14 14:13 | 只看该作者
你用的光电编码器是什么型号呀
