查看: 9810|回复: 1
[求助]FATAL ERROR L201: INVALID COMMAND LINE SYNTAX
ID:40557 发表于 2012-6-19 16:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用Silicon laboratories IDE(编译器采用KEIL破解版)编译时,出现提示如下:
Invoking project defined compiler.
C:\Keil\C51\BIN\C51.exe "www.c" DB OE
C51 COMPILER V7.06 - SN: K1DZP-5IUSHE
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2003
C51 COMPILATION COMPLETE.  0 WARNING(S),  0 ERROR(S)
Link in progress...
C:\Keil\C51\BIN\BL51.EXE @"D:\c8051\cyglink.txt"
BL51 BANKED LINKER/LOCATER V5.03 - SN: K1DZP-5IUSHE
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002
"D:\c8051\www.obj"  TO( "D:\c8051\www" ) RS(256) PL(68) PW(78)
*** FATAL ERROR L201: INVALID COMMAND LINE SYNTAX
    POS: 40
    C:\KEIL\C51\BIN\BL51.EXE D:\c8051\www.obj TO (D:\c8051\www)#
好像是连接器有问题,请高人指教!!!多谢!
