查看: 2458|回复: 1
51智能小车超声波测距lcd显示源码
ID:330146 发表于 2019-3-20 09:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
51智能小车超声波测距lcd显示源码
#include <reg52.h>
#include <intrins.h>
#include "lcd.h"
sbit ENA = P1^6; //定义ENA为P1^1端口
sbit ENB = P1^7;
sbit IN1 = P1^2;
sbit IN2 = P1^3;
sbit IN3 = P1^4;
sbit IN4 = P1^5;
sbit Trig = P2^1;
sbit Echo = P2^0;
sbit left_1_led = P3^4; //宏定义左避障模块为p3^6口
sbit right_1_led = P3^5;//宏定义右避障模块为p3^7口
sbit left_x = P3^7;
sbit right_x = P3^6;
unsigned char pwm_t = 0; //定义周期
unsigned char Disp[]="  4:XU:TIAN:ZAN   ";
unsigned char code ASCII[15] = {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
unsigned char left_pwm_val = 100,right_pwm_val = 100; //左右电机占空比值
static unsigned char DisNum = 0; //显示用指针
       unsigned int  time=0;
    unsigned long S=0;
    bit      flag =0;
    unsigned char disbuff[4]    ={ 0,0,0,0,};
void Conut(void)
  time=TH1*256+TL1;
  TH1=0;
  TL1=0;
  S=(time*1.7)/100;     //算出来是CM
  if((S>=700)||flag==1) //超出测量范围显示“-”
   flag=0;
   DisplayOneChar(0, 1, ASCII[11]);
   DisplayOneChar(1, 1, ASCII[10]); //显示点
   DisplayOneChar(2, 1, ASCII[11]);
   DisplayOneChar(3, 1, ASCII[11]);
   DisplayOneChar(4, 1, ASCII[12]); //显示M
   disbuff[0]=S%1000/100;
   disbuff[1]=S%1000%100/10;
   disbuff[2]=S%1000%10 %10;
   DisplayOneChar(0, 1, ASCII[disbuff[0]]);
   DisplayOneChar(2, 1, ASCII[disbuff[1]]);
   DisplayOneChar(3, 1, ASCII[disbuff[2]]);
void zd0() interrupt 3    //T0中断用来计数器溢出,超过测距范围
    flag=1;        //中断溢出标志
void  StartModule()            //启动模块
   Trig=1;                        //启动一次模块
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   Trig=0;
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
  while(--i)
   j=10;
   while(--j);
void run() //小车前进函数
IN1 = 1; //左电机前进
IN2 = 0;
IN3 = 1; //右电机前进
IN4 = 0;
//左转
     void  leftrun(void)
     IN1 = 0;
    IN2 = 0;
    IN3 = 1;
    IN4 = 0;
//右转
     void  rightrun(void)
    IN1 = 1;
    IN2 = 0;
    IN3 = 0;
    IN4 = 0;
//停止
     void  stop(void)
     IN1 = 0;
    IN2 = 0;
    IN3 = 0;
    IN4 = 0;
void bi(void)  //小车避障函数
//有信号为0 无信号为1
if(left_1_led == 1 && right_1_led == 1)
  run();
if(left_1_led == 1 && right_1_led == 0)
  stop();
if(left_1_led == 0 && right_1_led == 1)
  stop();
if(left_1_led == 0 && right_1_led == 0)
  stop();
void timer0(void) interrupt 1 //定时器中断服务程序
pwm_t++;
if(pwm_t == 255) //周期最大值时 清零
  pwm_t = ENA = ENB = 0;
if(left_pwm_val == pwm_t) //左电机占空比等于周期时
  ENA = 1;                //使能ENA
if(right_pwm_val == pwm_t) //右电机占空比等于周期时
  ENB = 1;                //使能ENB
void Time0Config()
TMOD|= 0x02;   //八位自动重装模式
TH0= 220;    //1ms定时
  TL0= 220;
ET0 = 1;    //允许定时器0中断
EA = 1;     //开启总中断
TR0 = 1;   //开启定时器0
void Time1Config()
  TMOD=0x10;     //设T0为方式1,GATE=1;
  TH1=0;
  TL1=0;
  ET1=1;             //允许T1中断
  EA=1;      //开启总中断
void main(void)
LcdInit();
LcdShowStr(0,0,Disp);
Time1Config();
Time0Config(); //定时器函数
while(1) //无限循环
     StartModule();
      while(!Echo);  //当RX为零时等待
      TR1=1;       //开启计数
    while(Echo);   //当RX为1计数并等待
    TR1=0;    //关闭计数
    Conut();   //计算
     delayms(10);
  if((left_x!=1)||(right_x!=1))
   if((left_x==1)&&(right_x==0))
    bi();
    leftrun();
   if((left_x==0)&&(right_x==1))
    bi();
        rightrun();
   if((left_x==0)&&(right_x==0))
    bi();
    run();
  if((left_x==1)&&(right_x==1))
   stop();
lcd显示
#include "lcd.h"
* 函 数 名         : Lcd1602_Delay1ms
* 函数功能     : 延时函数,延时1ms
* 输    入         : c
* 输    出         : 无
* 说    名         : 该函数是在12MHZ晶振下,12分频单片机的延时。
void Lcd1602_Delay1ms(uint c)   //误差 0us
    uchar a,b;
for (; c>0; c--)
   for (b=199;b>0;b--)
     for(a=1;a>0;a--);
* 函 数 名         : LcdWriteCom
* 函数功能     : 向LCD写入一个字节的命令
* 输    入         : com
* 输    出         : 无
#ifndef  LCD1602_4PINS  //当没有定义这个LCD1602_4PINS时
void LcdWriteCom(uchar com)   //写入命令
LCD1602_E = 0;     //使能
LCD1602_RS = 0;    //选择发送命令
LCD1602_RW = 0;    //选择写入
LCD1602_DATAPINS = com;     //放入命令
Lcd1602_Delay1ms(1);  //等待数据稳定
LCD1602_E = 1;           //写入时序
Lcd1602_Delay1ms(5);   //保持时间
LCD1602_E = 0;
#else
LCD1602_E = 0;  //使能清零
LCD1602_RS = 0;  //选择写入命令
LCD1602_DATAPINS = com; //由于4位的接线是接到P0口的高四位,所以传送高四位不用改
LCD1602_E = 0;
LCD1602_DATAPINS = com << 4; //发送低四位
LCD1602_E = 0;
#endif
* 函 数 名         : LcdWriteData
* 函数功能     : 向LCD写入一个字节的数据
* 输    入         : dat
* 输    出         : 无
void LcdWriteData(uchar dat)   //写入数据
LCD1602_RS = 1; //选择输入数据
LCD1602_DATAPINS = dat; //写入数据
LCD1602_E = 0;
#else
LCD1602_RS = 1;   //选择写入数据
LCD1602_DATAPINS = dat; //由于4位的接线是接到P0口的高四位,所以传送高四位不用改
LCD1602_E = 0;
LCD1602_DATAPINS = dat << 4; //写入低四位
LCD1602_E = 0;
#endif
* 函 数 名       : LcdInit()
* 函数功能   : 初始化LCD屏
* 输    入       : 无
* 输    出       : 无
void LcdInit()        //LCD初始化子程序
  LcdWriteCom(0x38);  //开显示
LcdWriteCom(0x0c);  //开显示不显示光标
LcdWriteCom(0x06);  //写一个指针加1
LcdWriteCom(0x01);  //清屏
LcdWriteCom(0x80);  //设置数据指针起点
#else
LcdWriteCom(0x32);  //将8位总线转为4位总线
LcdWriteCom(0x28);  //在四位线下的初始化
#endif
void LcdSetCursor(unsigned char x,unsigned char y)  //坐标显示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    LcdWriteCom(addr|0x80);
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //显示字符串
    LcdSetCursor(x,y);      //当前字符的坐标
    while(*str != '\0')
        LcdWriteData(*str++);
//按指定位置显示一个字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //当要显示第二行时地址码+0x40;
X |= 0x80; //算出指令码
LcdWriteCom(X); //发命令字
LcdWriteData(DData); //发数据
收藏收藏1 分享淘帖 顶 踩
ID:1 发表于 2019-3-20 18:23 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
