查看: 1235|回复: 0
SyncMOS 59R ADC 源码
ID:496073 发表于 2019-3-22 14:58 | 显示全部楼层 |阅读模式
SyncMOS 59R ADC 源码
#include "OB59R16A5C.h"
#include "ADC.h"
unsigned int n_data;
bit ADCfinish = 0;
void ADCstart(unsigned char n_ADC_CH)
    ADCC2 &= 0x7F;      //ADC stop conversion
    ADCC2  = n_ADC_CH;  //Set a new channel
    ADCC2 |= 0x80;      //ADC start conversion
void ADCInit(unsigned char n_ADCnEN, unsigned char n_ADC_CLK)
    ADCC1 = n_ADCnEN;   //Set ADC channel
    ADCCS = n_ADC_CLK;  //Select ADC clock
    IEADC = 1;          //Enable ADC interrupt.
    EA    = 1;
unsigned int ADC_Read10()//10-bit ADC
    unsigned int n_ADCD10 = 0x0000;
    n_ADCD10 = (ADCDH<<2)|ADCDL;    //10-bit ADC
    return n_ADCD10;
void ADCInterrupt(void) interrupt d_ADC_Vector  // ADC Interrupt Vector Address 0053h => interrupt 10
    n_data = ADC_Read10();  //Read ADC
    ADCfinish = 1;
void ADC_stop(void)
    IEADC = 0;      //Disable ADC interrupt
void ADC(void)
    if (d_ADCnEN & 0x01)
        ADCstart(d_ADC_CH0_IN);
        while(!ADCfinish);
        ADCfinish = 0;
    if (d_ADCnEN & 0x02)
        ADCstart(d_ADC_CH1_IN);
        while(!ADCfinish);
        ADCfinish = 0;
    if (d_ADCnEN & 0x04)
        ADCstart(d_ADC_CH2_IN);
        while(!ADCfinish);
        ADCfinish = 0;
    if (d_ADCnEN & 0x08)
        ADCstart(d_ADC_CH3_IN);
        while(!ADCfinish);
        ADCfinish = 0;
    if (d_ADCnEN & 0x10)
        ADCstart(d_ADC_CH4_IN);
        while(!ADCfinish);
        ADCfinish = 0;
    if (d_ADCnEN & 0x20)
        ADCstart(d_ADC_CH5_IN);
        while(!ADCfinish);
        ADCfinish = 0;
    if (d_ADCnEN & 0x40)
        ADCstart(d_ADC_CH6_IN);
        while(!ADCfinish);
        ADCfinish = 0;
    if (d_ADCnEN & 0x80)
        ADCstart(d_ADC_CH7_IN);
        while(!ADCfinish);
        ADCfinish = 0;
