查看: 1912|回复: 0
蓝桥杯单片机组 第八届省赛-基于单片机的电子钟程序设计
ID:384168 发表于 2019-3-25 15:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
没有使用DS1302模块,用定时器完全实现了题目要求,发出来让没有思路的同学们参考一下。本人水平有限,如果有不足之处多多指正。
  1. #include "intrins.h"
  2. #include "STC15F2K60S2.h"
  3. #include "key.h"
  4. #include "onewire.h"
  5. sbit S7 = P3^0;
  6. sbit S6 = P3^1;
  7. sbit S5 = P3^2;
  8. sbit S4 = P3^3;
  9. unsigned char table[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff,0xbf};
  10. unsigned char distime = 0;
  11. unsigned char num0[] = {0,0,17,0,0,17,0,0};                //显示时钟
  12. unsigned char num1[] = {0,0,17,0,0,17,0,0};                //显示闹钟设置时间
  13. unsigned char num2[] = {16,16,16,16,16,0,0,12};                //显示温度
  14. int shizhong = 0;        //用于时钟的正确运行
  15. unsigned char time_shi = 0 , time_fen = 0 , time_miao = 0;                //时钟参数
  16. unsigned char time_set_mode = 0;                                                        //时钟设置模式,0为不设置,1为设置时,2为设置分,3为设置秒
  17. unsigned char alarm_shi = 0 , alarm_fen = 0 , alarm_miao = 0;                //闹钟参数
  18. unsigned char alarm_set_mode = 0;                                                        //闹钟设置模式,对应同上
  19. int alarm_count = 0 ;
  20. bit alarm_start = 0 , alarm_enough = 0;
  21. unsigned char temper = 0;
  22. unsigned char DS_mode = 0;        //数码管显示模式,0为时钟,1为闹钟,2为温度
  23. bit flash_start = 0 ;
  24. bit flash0 = 1 , flash1 = 1;
  25. bit LED_mode = 0;
  26. unsigned int LED_count = 0;
  27. void LED_flash()
  28. {
  29.         if(LED_mode)
  30.         {
  31.                 P2 = (P2 & 0x1f) | 0x80;
  32.                 P0 = 0xfe;
  33.                 P2 &= 0x1f;
  34.                 P0 = 0xff;
  35.         }
  36.         else
  37.         {
  38.                 P2 = (P2 & 0x1f) | 0x80;
  39.                 P0 = 0xff;
  40.                 P2 &= 0x1f;
  41.                 P0 = 0xff;
  42.         }
  43.
  44.         if(++LED_count==1000)
  45.                 LED_mode = ~(LED_mode);
  46. }
  47. void display()
  48. {
  49.         P2 |= 0xc0;
  50.         P0 = 1<<distime;
  51.         P2 &= ~(0xc0);
  52.         P0 = 0xff;
  53.
  54.         switch(DS_mode)
  55.         {
  56.                 case 0:
  57.                                                 if(flash0)
  58.                                                 {
  59.                                                         P2 |= 0xe0;
  60.                                                         P0 = table[num0[distime]];
  61.                                                         P2 &= ~(0xe0);
  62.                                                         P0 = 0x00;
  63.                                                 }
  64.                                                 else
  65.                                                 {
  66.                                                         if((distime==(3*(time_set_mode-1)))||(distime==(3*(time_set_mode-1)+1)))
  67.                                                         {
  68.        P2 |= 0xe0;
  69.        P0 = 0xff;
  70.        P2 &= ~(0xe0);
  71.        P0 = 0x00;
  72.                                                         }
  73.                                                         else
  74.                                                         {
  75.        P2 |= 0xe0;
  76.        P0 = table[num0[distime]];
  77.        P2 &= ~(0xe0);
  78.        P0 = 0x00;
  79.                                                         }
  80.                                                 }
  81.                                                 break;
  82.                 case 1:
  83.                                                 if(flash1)
  84.                                                 {
  85.                                                         P2 |= 0xe0;
  86.                                                         P0 = table[num1[distime]];
  87.                                                         P2 &= ~(0xe0);
  88.                                                         P0 = 0x00;
  89.                                                 }
  90.                                                 else
  91.                                                 {
  92.                                                         if((distime==(3*(alarm_set_mode-1)))||(distime==(3*(alarm_set_mode-1)+1)))
  93.                                                         {
  94.        P2 |= 0xe0;
  95.        P0 = 0xff;
  96.        P2 &= ~(0xe0);
  97.        P0 = 0x00;
  98.                                                         }
  99.                                                         else
  100.                                                         {
  101.        P2 |= 0xe0;
  102.        P0 = table[num1[distime]];
  103.        P2 &= ~(0xe0);
  104.        P0 = 0x00;
  105.                                                         }
  106.                                                 }
  107.                                                 break;
  108.                 case 2:
  109.                                                 P2 |= 0xe0;
  110.                                                 P0 = table[num2[distime]];
  111.                                                 P2 &= ~(0xe0);
  112.                                                 P0 = 0x00;
  113.                                                 break;
  114.         }
  115.
  116.         if(++distime==8)        distime = 0;
  117. }
  118.
  119. void Timer0Init()        //2ms
  120. {
  121.         AUXR |= 0x80;                //?????1T??
  122.         TMOD &= 0xF0;                //???????
  123.         TL0 = 0x40;                //??????
  124.         TH0 = 0xA2;                //??????
  125.         TF0 = 0;                //??TF0??
  126.         TR0 = 1;                //???0????
  127.
  128.         EA = 1;
  129.         ET0 = 1;
  130. }
  131. void timer0() interrupt 1
  132. {
  133.
  134.
  135. //====================================================================================
  136.         if(alarm_start)        //L1闪烁(闹钟)控制
  137.         {
  138.                 if(++alarm_count==2500)                        //5s
  139.                 {
  140.                         alarm_count = 0;
  141.                         alarm_start = 0;
  142.                         alarm_enough = 1;
  143.                 }
  144.         }
  145.
  146.
  147. //====================================================================================
  148.         if(++shizhong==500)                                                        //时钟正常计时控制,1s
  149.         {
  150.                 if(time_miao==59)
  151.                 {
  152.                         time_miao = 0;
  153.                         if(time_fen==59)
  154.                         {
  155.                                 time_fen = 0;
  156.                                 if(time_shi==23)
  157.                                 {
  158.                                         time_shi = 0;
  159.                                 }
  160.                                 else
  161.                                         time_shi++;
  162.                         }
  163.                         else
  164.                                 time_fen++;
  165.                 }
  166.                 else
  167.                         time_miao++;
  168.                 shizhong = 0;
  169.
  170.
  171.
  172.                 if(flash_start)
  173.                 {
  174.                         if(DS_mode==0)
  175.                                 flash0 = ~(flash0);
  176.                         else
  177.                                 flash0 = 1;
  178.
  179.
  180.                         if(DS_mode==1)
  181.                                 flash1 = ~(flash1);
  182.                         else
  183.                                 flash1 = 1;
  184.
  185.                 }
  186.
  187.
  188.         }
  189. //====================================================================================
  190.         display();
  191. }
  192. void main()
  193. {
  194.         P2 = (P2 & 0x1f) | 0xa0;
  195.         P0 = 0;
  196.         P2 &= 0x1f;
  197.         P0 = 0xff;
  198.
  199.         P2 = (P2 & 0x1f) | 0x80;
  200.         P0 = 0xff;
  201.         P2 &= 0x1f;
  202.         P0 = 0x00;
  203.
  204.         time_shi = 23;
  205.         time_fen = 59;
  206.         time_miao = 50;
  207.
  208.         alarm_shi = 0;
  209.         alarm_fen = 0;
  210.         alarm_miao = 0;
  211.
  212.         Timer0Init();
  213.
  214. //////////////////////初始化
  215. //=========================================================================================
  216.         while(1)
  217.         {
  218.                 num0[0] = time_shi/10;
  219.                 num0[1] = time_shi%10;
  220.                 num0[3] = time_fen/10;
  221.                 num0[4] = time_fen%10;
  222.                 num0[6] = time_miao/10;
  223.                 num0[7] = time_miao%10;
  224.
  225.                 num1[0] = alarm_shi/10;
  226.                 num1[1] = alarm_shi%10;
  227.                 num1[3] = alarm_fen/10;
  228.                 num1[4] = alarm_fen%10;
  229.                 num1[6] = alarm_miao/10;
  230.                 num1[7] = alarm_miao%10;
  231.
  232.
  233. //=========================================================================================
  234.                 if(S7==0)        //时钟设定
  235.                 {
  236.                         Delay10ms();
  237.                         if(S7==0)
  238.                         {
  239.                                 DS_mode = 0;
  240.                                 alarm_set_mode = 0;
  241.                                 switch(time_set_mode)
  242.                                 {
  243.                                         case 0:
  244.        time_set_mode = 1;
  245.        break;
  246.                                         case 1:
  247.        time_set_mode = 2;
  248.        break;
  249.                                         case 2:
  250.        time_set_mode = 3;
  251.        break;
  252.                                         case 3:
  253.        time_set_mode = 0;
  254.        break;
  255.                                         default:
  256.        break;
  257.                                 }
  258.
  259.                                 while(S7==0);
  260.                         }
  261.                 }
  262.
  263. //=========================================================================================
  264.
  265.                 if(S6==0)        //闹钟设定
  266.                 {
  267.                         Delay10ms();
  268.                         if(S6==0)
  269.                         {
  270.                                 DS_mode = 1;
  271.                                 time_set_mode = 0;
  272.                                 switch(alarm_set_mode)
  273.                                 {
  274.                                         case 0:
  275.        alarm_set_mode = 1;
  276.        break;
  277.                                         case 1:
  278.        alarm_set_mode = 2;
  279.        break;
  280.                                         case 2:
  281.        alarm_set_mode = 3;
  282.        break;
  283.                                         case 3:
  284.        alarm_set_mode = 0;
  285.        DS_mode = 0;
  286.        break;
  287.                                         default:
  288.        break;
  289.                                 }
  290.
  291.                                 while(S6==0);
  292.                         }
  293.                 }
  294.
  295. //=========================================================================================
  296.                 if(S5==0)        //加
  297.                 {
  298.                         Delay10ms();
  299.                         if(S5==0)
  300.                         {
  301.                                 if(time_set_mode!=0&&alarm_set_mode==0)
  302.                                 {
  303.                                         switch(time_set_mode)
  304.                                         {
  305.                                                 case 1:
  306.        if(time_shi==23)
  307.        time_shi = 0;
  308.        else
  309.        time_shi++;
  310.        break;
  311.                                                 case 2:
  312.        if(time_fen==59)
  313.        time_fen = 0;
  314.        else
  315.        time_fen++;
  316.        break;
  317.                                                 case 3:
  318.        if(time_miao==59)
  319.        time_miao = 0;
  320.        else
  321.        time_miao++;
  322.        break;
  323.                                                 default:
  324.        break;
  325.                                         }
  326.                                 }
  327.
  328.                                 if(time_set_mode==0&&alarm_set_mode!=0)
  329.                                 {
  330.                                         switch(alarm_set_mode)
  331.                                         {
  332.                                                 case 1:
  333.        if(alarm_shi==23)
  334.        alarm_shi = 0;
  335.        else
  336.        alarm_shi++;
  337.        break;
  338.                                                 case 2:
  339.        if(alarm_fen==59)
  340.        alarm_fen = 0;
  341.        else
  342.        alarm_fen++;
  343.        break;
  344.                                                 case 3:
  345.        if(alarm_miao==59)
  346.        alarm_miao = 0;
  347.        else
  348.        alarm_miao++;
  349.        break;
  350.                                                 default:
  351.        break;
  352.                                         }
  353.                                 }
  354.                                 while(S5==0);
  355.                         }
  356.                 }
  357.
  358. //=========================================================================================
  359.                 if(S4==0)        //减;显示温度
  360.                 {
  361.                         Delay10ms();
  362.                         if(S4==0)
  363.                         {
  364.                                 if(time_set_mode!=0&&alarm_set_mode==0)
  365.                                 {
  366.                                         switch(time_set_mode)
  367.                                         {
  368.                                                 case 1:
  369.        if(time_shi==0)
  370.        time_shi = 23;
  371.        else
  372.        time_shi--;
  373.        break;
  374.                                                 case 2:
  375.        if(time_fen==0)
  376.        time_fen = 59;
  377.        else
  378.        time_fen--;
  379.        break;
  380.                                                 case 3:
  381.        if(time_miao==0)
  382.        time_miao = 59;
  383.        else
  384.        time_miao--;
  385.        break;
  386.                                                 default:
  387.        break;
  388.                                         }
  389.                                 }
  390.
  391.                                 if(time_set_mode==0&&alarm_set_mode!=0)
  392.                                 {
  393.                                         switch(alarm_set_mode)
  394.                                         {
  395.                                                 case 1:
  396.        if(alarm_shi==0)
  397.        alarm_shi = 23;
  398.        else
  399.        alarm_shi--;
  400.        break;
  401.                                                 case 2:
  402.        if(alarm_fen==0)
  403.        alarm_fen = 59;
  404.        else
  405.        alarm_fen--;
  406.        break;
  407.                                                 case 3:
  408.        if(alarm_miao==0)
  409.        alarm_miao = 59;
  410.        else
  411.        alarm_miao--;
  412.        break;
  413.                                                 default:
  414.        break;
  415.                                         }
  416.                                 }
  417.
  418.                                 if(time_set_mode==0&&alarm_set_mode==0)
  419.                                 {
  420.                                         temper = temper_read();
  421.                                         num2[5] = temper/10;
  422.                                         num2[6] = temper%10;
  423.
  424.                                         DS_mode = 2;
  425.                                 }
  426.
  427.                                 while(S4==0);
  428.
  429.                                 DS_mode = 0;
  430.                         }
  431. ……………………
  432. …………限于本文篇幅 余下代码请从51黑下载附件…………
电子钟(自)2018.zip (53.58 KB, 下载次数: 30)
