查看: 1905|回复: 2
单片机数码管菜单代码
ID:499627 发表于 2019-3-28 10:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include < reg51.h >
#include <intrins.h>
#define uint  unsigned int
uchar layer = 0;
uchar sign = 0;
uchar enable = 4;
uchar enabledata;
struct jigou{
    uchar a;
    uchar b;
    uchar c;
    uchar d;
    }parameter[] = {{0,0,0,0},{1,1,1,1},{2,2,2,2},{3,3,3,3},{4,4,4,4},{5,5,5,5},{6,6,6,6}};
uchar LEDData[] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x98,0xff};
uchar data1[4] = {0,1,2,3};
uchar dispdata[4] = {0,1,2,3};
void delay(uint ms)
uchar k;
while(ms--)
  for( k = 0; k < 120; k++ );
void addparameter( uchar a )
switch(a)
  case 0:
  enabledata =++ parameter[sign].a;
  break;
  case 1:
  enabledata =++ parameter[sign].b;
  break;
  case 2:
  enabledata =++ parameter[sign].c;
  break;
  case 3:
  enabledata =++ parameter[sign].d;
  break;
  default:
  break;
void subparameter( uchar a )   //?layer=2?,?DOWNKEY???,???????
switch(a)
  case 0:
  enabledata =-- parameter[sign].a;
  break;
  case 1:
  enabledata =-- parameter[sign].b;
  break;
  case 2:
  enabledata =-- parameter[sign].c;
  break;
  case 3:
  enabledata =-- parameter[sign].d;
  break;
  default:
  break;
void copymenu()        //?????? ,??esckey?
dispdata[0] = sign;
dispdata[1] = 10;
dispdata[2] = 10;
dispdata[3] = 10;
enabledata = sign;      //??????????
void copy(void)       //????????
dispdata[0] = parameter[sign].a;
dispdata[1] = parameter[sign].b;
dispdata[2] = parameter[sign].c;
dispdata[3] = parameter[sign].d;
enabledata = dispdata[enable];  //?????????
void copyfre(void)       //???????,??????????
dispdata[0] = data1[0];
dispdata[1] = data1[1];
dispdata[2] = data1[2];
dispdata[3] = data1[3];
void esckey()     //???????
if( layer == 0||layer == 2 ) //?????0?2?,???1layer
     enable = 0;
  layer = 1;
  copymenu();
  return;
if( layer == 1 )  //?layer?1??,??????????
  layer=0;
  enable=4;
  copyfre();
if( layer > 1 )    //?????2?,?????????
  layer = 1;
  enable = 0;
  copymenu();
void upkey()     //upkey????
if( layer == 0 )   //??0?,?????
  return ;    //??1?,????1
if( layer == 1&&sign < 6 )
    ++sign;
    copymenu( );
    return;
  if( layer == 2&&dispdata[enable] <9 ) //?????????,???????9,??????1
   addparameter(enable );
  copy();
void downkey()
if ( layer == 0 )
  return;
if( layer == 1&&0 < sign )
    --sign;
    copymenu();
  if( layer == 2&&0<dispdata[enable]&&dispdata[enable] != 10) //?????????,???????0
   subparameter( enable );
  copy();
void enterkey()      //dnterkey????
if(layer == 0)
return;       //?0?,??
if ( layer==1 )     //?1?,????????,???????
    copy();
    enable = 3;
    layer = 2;
    return;
  if ( layer == 2 )    //???????
   if(enable == 0)
   enable = 3;
   copy();
   return;
   --enable;
  copy();
void  scankey(void)    //??????
uint keyvalue = P2&0x0f;
switch(~keyvalue&0x0f)
  case 1:    //?????
  esckey();
  break;
  case 2:
  upkey();
  break;
  case 4:
  downkey();
  break;
  case 8:
  enterkey();
  break;
void keydown(void)     //????????
P2 = 0xff;
if( P2 != 0xff )
  scankey();
while ( P2 != 0xff) ;
void disp()                        //?????,????? 0-3???,????
{ uchar m,i;
    uint left = 119;                                //???????0b00010001,????????????????!
    for( i = 0;1;i = ~i )
  left = 119;
  if( enable != 4 )
         dispdata[enable] = enabledata;
        if( i )                                 //????????????
         dispdata[enable] = 10;
        for( m = 0;m <= 119;m++ )
   left = _crol_(left,1);  //????(??????)
            P1 = (left&0x0f);
            P0 = LEDData[dispdata[m%4]];
   keydown();
            delay(3);
            P0 = 0xff;
main()
     disp();
用于51单片机
ID:1 发表于 2019-3-29 03:47 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
