查看: 7458|回复: 1
4*4单片机矩阵按键数码管显示0-F字码 Keil程序+Proteus仿真
4*4矩阵按键数码管显示0-F字码
内容包含:keil+protues
适合刚接触单片机的同学;
有什么单片机的问题大家也可以留言评论!
4_4矩阵按键.rar (199.88 KB, 下载次数: 63) 后期补充:4*4KEYPAD行扫描程序
  1. /**********************************************************
  2. 程序功能:4*4矩阵键盘按照行扫描的方式进行按键的确定
  3. 本程序适应上次正反转电平的方式进行确定按键的Protues仿真图
  4. ***********************************************************/
  5. #include<reg52.h>  //头文件
  6. #define uchar unsigned char         //宏定义
  7. #define uint unsigned int
  8. //0-F字码
  9. uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
  10. void delay(uint z)
  11. {
  12.         uint x,y;
  13.         for(x=0;x<z;x++)
  14.                 for(y=0;y<123;y++);
  15. }
  16. void main(void)
  17. {
  18.         while(1)
  19.         {
  20.                 P1 = 0XF0;
  21.                 if(P1 != 0XF0)
  22.                 {
  23.                         delay(5);
  24.                         if(P1 != 0XF0)
  25.                         {
  26.                                 P1 = 0xEF;
  27.                                 if(P1 != 0xEF)
  28.                                 {
  29.                                         switch(P1)
  30.                                         {
  31.                                                 case 0xEE:P2 = 0;P0 = table[0];while(P1 == 0XEE);break;
  32.                                                 case 0xED:P2 = 0;P0 = table[4];while(P1 == 0XED);break;
  33.                                                 case 0xEB:P2 = 0;P0 = table[8];while(P1 == 0XEB);break;
  34.                                                 case 0xE7:P2 = 0;P0 = table[12];while(P1 == 0XE7);break;
  35.                                         }
  36.                                 }
  37.                                 P1 = 0xDF;
  38.                                 if(P1 != 0xDF)
  39.                                 {
  40.                                         switch(P1)
  41.                                         {
  42.                                                 case 0xDE:P2 = 0;P0 = table[1];while(P1 == 0xDE);break;
  43.                                                 case 0xDD:P2 = 0;P0 = table[5];while(P1 == 0xDD);break;
  44.                                                 case 0xDB:P2 = 0;P0 = table[9];while(P1 == 0xDB);break;
  45.                                                 case 0xD7:P2 = 0;P0 = table[13];while(P1 == 0xD7);break;
  46.                                         }
  47.                                 }
  48.                                 P1 = 0xBF;
  49.                                 if(P1 != 0xBF)
  50.                                 {
  51.                                         switch(P1)
  52.                                         {
  53.                                                 case 0xBE:P2 = 0;P0 = table[2];while(P1 == 0xBE);break;
  54.                                                 case 0xBD:P2 = 0;P0 = table[6];while(P1 == 0xBD);break;
  55.                                                 case 0xBB:P2 = 0;P0 = table[10];while(P1 == 0xBB);break;
  56.                                                 case 0xB7:P2 = 0;P0 = table[14];while(P1 == 0xB7);break;
  57.                                         }
  58.                                 }
  59.                             P1 = 0x7F;
  60.                                 if(P1 != 0x7F)
  61.                                 {
  62.                                         switch(P1)
  63.                                         {
  64.                                                 case 0x7E:P2 = 0;P0 = table[3];while(P1 == 0x7E);break;
  65.                                                 case 0x7D:P2 = 0;P0 = table[7];while(P1 == 0x7D);break;
  66.                                                 case 0x7B:P2 = 0;P0 = table[11];while(P1 == 0x7B);break;
  67.                                                 case 0x77:P2 = 0;P0 = table[15];while(P1 == 0x77);break;
  68.                                         }
  69.                                 }
  70.                         }
  71.                 }
  72.         }
  73. }
这里不添加程序包了,这里我直接把程序贴出来,有想学习的同学可以直接复制下来贴到你自己建立的工程中,
这里的行扫描程序和上述程序包中的Protues是匹配的,可以直接替换新的HEX文件进行实验!
ID:574901 发表于 2019-7-2 14:29 来自触屏版 | 只看该作者
请问下这个显示屏的代码是什么呀
