查看: 1915|回复: 0
知道单片机程序和原理图求框图 求帮助
100黑币
系统软件总体框图显示子程序框图
中断子程序框图
显示电路设计分频电路设计
信号输入模块电路设计
#include <reg52.h >
#include <intrins.h >
sbit  k1=P3^0;
sbit  k2=P2^0;
sbit  LED=P2^1;
unsigned  char code dispbit[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned  char code dispcode[11]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
unsigned  char count [8]={0, 0, 0, 0, 0, 0, 0, 0};
unsigned  int  T0count =0;
unsigned  char time1tick =0;
unsigned  char i =0,a=0,j=0,y=0;
unsigned  int x ;
void pulse_init (void)
  TMOD =0x16;
  TH0=0x00;
  TL0=0x00;
  TH1=(65536-50000)/256;
  TL1=(65536-50000)%256;
  ET0=1;
  ET1=1;
  EA=1;
void delay (uint ms)
  unsigned char i,j;
  for(i =0; i<ms; i ++)
  for(j =0; j<250;j ++)
        _nop_();
        _nop_();
    _nop_();
static void time0_int (void) interrupt 1 using 0
  T0count ++;
void t1(void) interrupt 3 using 0
  time1tick++;
  if (time1tick==10*a)
    time1tick=0;
    TR0=0;
    TR1=0;
    ET0=0;
    ET1=0;
void display (void)
  x=256*T0count+TL0;
  i=7;
  while(x)
    count[ i]=x%10;
    x=x/10;
    i--;
  while(i--)
    count[ i]=10;//修改
  for(i=0;i<8;i++)
        if(i==7&&j==1)
                P1=0x80;
                delay(1);
           P0=dispbit[ i];
           P1=dispcode[count[ i]];
           delay(1);
  if(!k2)
    delay(5);
        if(!k2)
        j=0;
                j=1;
  switch(j)
        case(0):a=2; LED=1; break;
        case(1):a=20; LED=0; break;
  pulse_init();
  TR1=1;
  TR0=1;
  do
    display();
  }while(k2);
