查看: 6632|回复: 9
为什么单片机这样显示数码管亮度不够?延时函数的问题?
ID:438858 发表于 2019-4-10 17:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
为什么这样显示数码管亮度不够,为啥显示函数里不要加延时了,加了延时不能实现功能!
  1. #include <reg52.h>
  2. #define dataport P0
  3. #define uint unsigned int
  5. sbit duanch_1 = P2^2;
  6. sbit weich_2 = P2^3;
  7. sbit key_1 = P3^3;
  8. sbit key_2 = P3^4;
  9. uchar code duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6};
  10. uchar weima[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  11. uchar tempdata[8];
  12. void delayms(uchar t);
  13. void display(uchar firstbit,uchar Num);
  14. void init();
  15. void main()
  16. {
  17.         uchar num;
  18.         key_1 = 1;
  19.         key_2 = 1;
  20.         init();
  21.         while(1)
  22.         {
  23.                 if(!key_1)
  24.                 {
  25.                         delayms(10);
  26.                         if(!key_1)
  27.                         {
  28.                                 while(!key_1);
  29.                                 {
  30.                                         if(num<99)
  31.                                                 num++;
  32.                                 }
  33.                         }
  34.                 }
  35.                 if(!key_2)
  36.                 {
  37.                         delayms(10);
  38.                         if(!key_2)
  39.                         {
  40.                                 while(!key_2);
  41.                                 {
  42.                                         if(num>0)
  43.                                                 num--;
  44.                                 }
  45.                         }
  46.                 }
  47.                 tempdata[0] = duanma[num/10];
  48.                 tempdata[1] = duanma[num%10];
  49.         }
  50. }
  51. void delayms(uchar t)
  52. {
  53.         uchar i,j;
  54.         for(i=0;i<120;i++)
  55.                 for(j=0;j<t;j++);
  56. }
  57. void display(uchar firstbit,uchar Num)
  58. {
  59.         uchar i;
  60.         for(i=0;i<Num;i++)
  61.         {
  62.                 dataport = 0;
  63.                 duanch_1 = 1;
  64.                 duanch_1 = 0;
  65.
  66.                 dataport = weima[i+firstbit];
  67.                 weich_2 = 1;
  68.                 weich_2 = 0;
  69.
  70.                 dataport = tempdata[i];
  71.                 duanch_1 = 1;
  72.                 duanch_1 = 0;
  73.         }
  74. }
  75. void init()
  76. {
  77.         TMOD|=0x01;
  78.         EA = 1;
  79.         ET0 = 1;
  80.         TR0 = 1;
  81. }
  82. void time_0 ()interrupt 1
  83. {
  84.         TH0 = (65536-2000)/256;
  85.         TL0 = (65536-2000)%256;
  86.
  87.         display(0,3);
  88. }
ID:213173 发表于 2019-4-10 21:37 | 只看该作者
你的显示函数这样处理当然会出问题,改一下即可。每次中断只显示一位。
#include <reg52.h>
#define dataport P0
sbit key_1 = P3^3;
sbit key_2 = P3^4;
uchar num;
uchar code duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar tempdata[8];
void display();
void init();
        init();
                if(!key_1)
                        delayms(10);
                        if(!key_1)
                                while(!key_1);
                                        if(num<99)
                                        num++;
                if(!key_2)
                        delayms(10);
                        if(!key_2)
                                while(!key_2);
                                        if(num>0)
                                        num--;
        uchar i,j;
        for(i=0;i<120;i++)
            for(j=0;j<t;j++);
void display()
        static uchar i=0;
        dataport=0x00;//消隐
        duanch_1 = 1;
        duanch_1 = 0;
        switch(i)
                case 0:
                        dataport = weima[i];//送十位位码
                        weich_2  = 1;
                        weich_2  = 0;
                        dataport = tempdata[i];//送十位段码
                        duanch_1 = 1;
                        duanch_1 = 0;
                        i++;
                break;
                case 1:
                        dataport = weima[i];//送个位位码
                        weich_2  = 1;
                        weich_2  = 0;
                        dataport = tempdata[i];//送个位段码
                        duanch_1 = 1;
                        duanch_1 = 0;
                        i=0;
                break;
void init()
        TMOD|=0x01;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
        display();
ID:423511 发表于 2019-4-10 22:38 | 只看该作者
延时加大点试试。
ID:164602 发表于 2019-4-11 08:22 | 只看该作者
第一:你的显示函数中没有延时程序,所以亮度不够。数码管从不亮到亮,现从亮到不亮,都是需要时间的,你开了马上关,时间太短,所以不太亮。
第二:你的程序说不能加延时,是因为你的定时器为2ms,如果延时过长,就会中断嵌套,这就不好办了,所以加了延时就死了,功能不能实现。
第三:两种解决方案:
(1)定时器时间加大一点,配合的延时时间要算好,中断程序执行时间不超过定时时间
(2)重新规划程序,例如定时中断一次只显示一位数码管
ID:230559 发表于 2019-4-11 10:21 | 只看该作者
主要是定时器时间问题,上面的解决方案很好!
ID:509436 发表于 2019-4-11 10:39 | 只看该作者
ID:509511 发表于 2019-4-11 12:34 | 只看该作者
我看主要问题还是在没有消影
ID:509620 发表于 2019-4-11 14:29 | 只看该作者
延迟的问题,尝试加长试一试
ID:430571 发表于 2019-4-11 21:23 | 只看该作者
可以加上去延时抖动,如,在
P1=0x01;
delay(5);
P1=0x00;//去延时抖动,解决数码管显示不清楚的问题
ID:509991 发表于 2019-4-11 22:02 | 只看该作者
