查看: 2834|回复: 1
51单片机水温水位检测调节程序,采用SR04、12864、DS1820
ID:514508 发表于 2019-4-17 13:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
基于51的水温水位检测调节,采用SR04、12864、DS1820
  1. #include<reg52.h>
  2. #include "12864.h"
  3. #include "delay.h"
  4. #include "sr04.h"
  5. #include "ds18b20.h"
  6. #include "delay.h"
  7. #include "beep.h"
  8. sbit s1=P1^2;
  9. sbit s2=P3^7;
  10. sbit KEY1=P1^3;
  11. sbit KEY2=P1^4;
  12. sbit KEY3=P1^5;
  13. extern uchar table1[];
  14. extern uint time,s;
  15. extern uchar code table5[];
  16. extern uchar code table6[];
  17. uchar num,num2;
  18. uchar j,mode;
  19. uchar weidu=25;
  20. uchar shuiwei=5;
  21. uchar ge,si;
  22. uchar set_w=25;
  23. uchar set_s=2;
  24. bit res;
  25. int temp;        //读取到的当前温度值
  26. int intT, decT;  //温度值的整数和小数部分
  27. unsigned char len;
  28. unsigned char str[12];
  29. void get_temp();
  30. unsigned char IntToString(unsigned char *str, int dat);
  31. void judge();
  32. void keyscan();
  33. void main()
  34. {
  35.         s1=0;s2=0;  // 继电器关
  36.         Start18B20();      //启动DS18B20
  37.         lcd_init();     //液晶初始
  38.         TMOD=0X10;                        // 定时器
  39.         TH1=(65536-45872)/256;//50ms
  40.         TL1=(65536-45872)%256;
  41.         EA=1;
  42.         ET1=1;
  43.         TR1=1;
  44.
  45.         while(1)  // 死循环
  46.         {
  47.
  48.                 if((num==10)&&(mode==0))        // 500ms刷新时间和显示界面0
  49.           {
  50.             num=0;
  51.                    get_temp(); sr04();// 获得温度 距离
  52.                   lcd_pos(0,3);        j=0;                  // 显示距离
  53.                    while(table1[j]!='\0' )
  54.                    {
  55.                        write_dat(table1[j]); j++;
  56.                    }
  57.
  58.                 }
  59.                 if(mode==0)
  60.           {judge();} // 水位水温调节
  61.                 keyscan();
  62.         }
  63. }
  64. void judge()
  65. {
  66.         if(s<set_s) // 水位判断
  67.         {
  68.                 s2=1;  lcd_pos(1,5);        j=0;
  69.                 while(table6[j]!='\0' )
  70.                 {
  71.                                 write_dat(table6[j]); j++;
  72.                 }
  73.                  BEEP=1;
  74.         }
  75.         else
  76.         {
  77.                 s2=0;  lcd_pos(1,5);        j=0;
  78.                 while(table5[j]!='\0' )
  79.                 {
  80.                                 write_dat(table5[j]); j++;
  81.                 }
  82.                  BEEP=0;
  83.         }
  84.         if(intT<set_w) // 温度判断
  85.         {
  86.                 s1=1;lcd_pos(3,6);        j=0;
  87.                 while(table6[j]!='\0' )
  88.                 {
  89.                                 write_dat(table6[j]); j++;
  90.                 }
  91.         }
  92.         else
  93.         {
  94.                 s1=0;lcd_pos(3,6);        j=0;
  95.                 while(table5[j]!='\0' )
  96.                 {
  97.                                 write_dat(table5[j]); j++;
  98.                 }
  99.         }
  100. }
  101. void T1_time() interrupt 3
  102. {
  103.         TH1=(65536-45872)/256;
  104.         TL1=(65536-45872)%256;
  105.         num++;
  106. }
  107. /* 整型数转换为字符串,str-字符串指针,dat-待转换数,返回值-字符串长度 */
  108. unsigned char IntToString(unsigned char *str, int dat)
  109. {
  110.     signed char i = 0;
  111.     unsigned char len = 0;
  112.     unsigned char buf[6];
  113.
  114.     if (dat < 0)  //如果为负数,首先取绝对值,并在指针上添加负号
  115.     {
  116.         dat = -dat;
  117.         *str++ = '-';
  118.         len++;
  119.     }
  120.     do {          //先转换为低位在前的十进制数组
  121.         buf[i++] = dat % 10;
  122.         dat /= 10;
  123.     } while (dat > 0);
  124.     len += i;     //i最后的值就是有效字符的个数
  125.     while (i-- > 0)   //将数组值转换为ASCII码反向拷贝到接收指针上
  126.     {
  127.         *str++ = buf[i] + '0';
  128.     }
  129.     *str = '\0';  //添加字符串结束符
  130.
  131.     return len;   //返回字符串长度
  132. }
  133. void get_temp()
  134. {
  135.         res = Get18B20Temp(&temp);  //读取当前温度
  136.         if (res)                    //读取成功时,刷新当前温度显示
  137.         {
  138.                         intT = temp >> 4;             //分离出温度值整数部分
  139.                         decT = temp & 0xF;            //分离出温度值小数部分
  140.                         len = IntToString(str, intT); //整数部分转换为字符串
  141.                         str[len++] = '.';             //添加小数点
  142.                         decT = (decT*10) / 16;        //二进制的小数部分转换为1位十进制位
  143.                         str[len++] = decT + '0';      //十进制小数位再转换为ASCII字符
  144.                         while (len < 6)               //用空格补齐到6个字符长度
  145.                         {
  146.                                         str[len++] = ' ';
  147.                         }
  148.                         str[len] = '\0';              //添加字符串结束符
  149.                         lcd_pos(2,3);        j=0;
  150.                         while(str[j]!='\0' )                // 显示温度
  151.                         {
  152.                                 write_dat(str[j]);
  153.                                 j++;
  154.                         }
  155.         }
  156.         else                        //读取失败时,提示错误信息
  157.         {
  158.                         //LcdShowStr(0, 0, "error!");
  159.         }
  160.         Start18B20();               //重新启动下一次转换
  161. }
  162. void keyscan()
  163. {
  164.     if(KEY1==0)  // set
  165.                 {
  166.                    delay(5);
  167.        if(KEY1==0)
  168.                          {
  169.                                  while(!KEY1);
  170.                             mode++;
  171.                          }
  172.
  173.                 }
  174.     if(mode==1) //界面1
  175.                 {
  176.                   clear(); //界面1显示
  177.       if(KEY2==0)
  178.                         {
  179.                           delay(5);
  180.         if(KEY2==0)
  181.                           {
  182.                             shuiwei++;
  183.                                         if(shuiwei>9)
  184.                                         {shuiwei=9;}
  185.
  186.                           }
  187.                         }
  188.                   if(KEY3==0)
  189.                         {
  190.                           delay(5);
  191.         if(KEY3==0)
  192.                           {
  193.                            shuiwei--;
  194.                                         if(shuiwei==255)
  195.                                         {shuiwei=0;}
  196.                           }
  197.                         }
  198.                   lcd_pos(2,5);
  199.                   write_dat(shuiwei+0x30);
  200.                         write_dat( );
  201.                 }
  202.    if(mode==2) //界面2
  203.          {
  204.
  205.           mode2();// 界面显示
  206.                  if(KEY2==0)
  207.                         {
  208.                           delay(5);
  209.         if(KEY2==0)
  210.                           {                                 while(!KEY2);
  211.                             weidu++;
  212.                                         if(weidu>50)
  213.                                         {weidu=50;}
  214.
  215.                           }
  216.                         }
  217.                   if(KEY3==0)
  218.                         {
  219.                           delay(5);
  220.         if(KEY3==0)
  221.                           {                                 while(!KEY3);
  222.                            weidu--;
  223.                                         if(weidu==255)
  224.                                         {weidu=0;}
  225.                           }
  226.                         }
  227.                         ge=weidu%10;
  228.                         si=weidu/10;
  229.                   lcd_pos(2,5);
  230.                   write_dat(si+0x30);
  231.                         write_dat(ge+0x30);
  232.          }
  233.    if(mode==3)
  234.    {
  235.            mode=0;lcd_init();//  界面0 及 显示
  236.                  set_w=weidu;
  237.                  set_s=shuiwei;
  238.          }
  239. }
1.程序.zip (76.12 KB, 下载次数: 37)
收藏收藏4 分享淘帖 顶顶 踩踩
ID:1 发表于 2019-4-18 00:46 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
