查看: 4048|回复: 0
[求助]求大侠帮忙分析分析此段程序错在哪?谢谢了
ID:43135 发表于 2012-7-22 09:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
想用ds1302和1602液晶做做时钟的程序,在proteus仿真,但怎么也达不到要求。编译无错,运行结果出乎意料,只显示0,而且时钟没工作。
各位大侠帮忙着分析分析,谢谢了。
/*************程序ds1302.c*****************/
#include <reg52.h>
#include "ds1302.h"
#include "lcd1602.h"
//uchar th[]="i am a teacher !";
 uchar i;
 struct _time time;
// struct _time *t=time;
 lcd_init();
 ds1302_init();
 set_time(ds1302_sec,5);
 set_time(ds1302_min,15);
 set_time(ds1302_hr,12);
 set_time(ds1302_date,21);
 set_time(ds1302_mon,12);
 set_time(ds1302_day,6);
 set_time(ds1302_year,12);
  get_time(&time);
  date_to_format(&time);
  time_to_format(&time);
  lcd_write_cmd(0x80+0);
  for(i=0;i<9;i++)
   lcd_write_dat(time.DateFormat);
   //lcd_write_dat(th);
  lcd_write_cmd(0x80+0x40);
  for(i=0;i<9;i++)
   lcd_write_dat(time.TimeFormat);
  //delay_ms(100);
/*********************程序ds1302.h************************/
#include <reg52.h>
#define ds1302_sec 0x80
#define ds1302_min 0x82
#define ds1302_hr 0x84
#define ds1302_date 0x86
#define ds1302_mon 0x88
#define ds1302_day 0x8a
#define ds1302_year 0x8c
sbit ds1302_rst=P1^5;
sbit ds1302_sclk=P1^6;
sbit ds1302_io=P1^7;
sbit ACC7=ACC^7;
sbit ACC0=ACC^0;
struct _time
 unsigned char sec;
 unsigned char min;
 unsigned char hr;
 unsigned char date;
 unsigned char mon;
 unsigned char day;
 unsigned char year;
 unsigned char DateFormat[9];
 unsigned char TimeFormat[9];
};                                //定义的时间类型
void ds1302_write(uchar cmd,uchar dat)   //往指定地址写入数据
 uchar i;
 ds1302_sclk=0;
 ds1302_rst=1;
 ACC=cmd;
 for(i=0;i<8;i++)
  ds1302_io=ACC0;
  ds1302_sclk=1;
  ds1302_sclk=0;
  ACC=ACC>>1;
 ACC=dat;
 for(i=0;i<8;i++)
  ds1302_io=ACC0;
  ds1302_sclk=1;
  ds1302_sclk=0;
  ACC=ACC>>1;
 ds1302_sclk=1;
 ds1302_rst=0;
uchar ds1302_read(uchar cmd)    //读出指定地址的数据
 uchar i;
 ds1302_sclk=0;
 ds1302_rst=1;
 ACC=cmd;
 for(i=0;i<8;i++)
  ds1302_sclk=0;
  ds1302_io=ACC0;
  ds1302_sclk=1;
//  ds1302_sclk=0;
  ACC=ACC>>1;
 for(i=0;i<8;i++)
//  ACC7=ds1302_io;
  ACC=ACC>>1;
  ds1302_sclk=1;
  ds1302_sclk=0;
  ACC7=ds1302_io;
 ds1302_sclk=1;
 ds1302_rst=0;
 return ACC;
void ds1302_SetProtect(bit flag)        //设置写保护
 if(flag)
  ds1302_write(0x8E,0x80);
  ds1302_write(0x8E,0x00);
void set_time(uchar add,uchar var)  //设置时间
 ds1302_SetProtect(0);
 ds1302_write(add,((var/10)<<4|(var%10))); //转成BCD码
void get_time(struct _time *t)        //读取时钟寄存器放入time结构体
 uchar var;
 var=ds1302_read(ds1302_sec);
 t->sec=(var&0x70>>4)*10+(var&0x0f);
 var=ds1302_read(ds1302_min);
 t->min=(var&0x70>>4)*10+(var&0x0f);
 var=ds1302_read(ds1302_hr);
 t->hr=(var&0x70>>4)*10+(var&0x0f);
 var=ds1302_read(ds1302_date);
 t->date=(var&0x70>>4)*10+(var&0x0f);
 var=ds1302_read(ds1302_mon);
 t->mon=(var&0x70>>4)*10+(var&0x0f);
 var=ds1302_read(ds1302_day);
 t->day=(var&0x70>>4)*10+(var&0x0f);
 var=ds1302_read(ds1302_year);
 t->year=(var&0x70>>4)*10+(var&0x0f);
void date_to_format(struct _time *t)               //将日期数据转化为日期格式并将数字转为字符
 t->DateFormat[0] = t->year/10+'0';
 t->DateFormat[1] = t->year%10+'0';
 t->DateFormat[2] ='-';
 t->DateFormat[3] = t->mon/10+'0';
 t->DateFormat[4] = t->mon%10+'0';
 t->DateFormat[5] = '-';
 t->DateFormat[6] = t->date/10+'0';
 t->DateFormat[7] = t->date%10+'0';
 t->DateFormat[8] = '\0';
void time_to_format(struct _time *t)               //将时间数据转化为时间格式并将数字转为字符
 t->TimeFormat[0] = t->hr/10+'0';
 t->TimeFormat[1] = t->hr%10+'0';
 t->TimeFormat[2] =':';
 t->TimeFormat[3] = t->min/10+'0';
 t->TimeFormat[4] = t->min%10+'0';
 t->TimeFormat[5] = ':';
 t->TimeFormat[6] = t->sec/10+'0';
 t->TimeFormat[7] = t->sec%10+'0';
 t->TimeFormat[8] = '\0';
              //初始化启动时钟
void ds1302_init()
 uchar second=ds1302_read(ds1302_sec);
 if(second&0x80)
  set_time(ds1302_sec,0);
/****************程序lcd1602.h*************************/
#include <reg52.h>
sbit lcd_rs=P2^0;
sbit lcd_rw=P2^1;
sbit lcd_e=P2^2;
sfr lcd_d=0x80;
void delay_ms(uint ms)
 uint x,y;
 for(x=ms;x>0;x--)
  for(y=120;y>0;y--);
void lcd_write_cmd(uchar cmd)
 lcd_rs=0;
 lcd_rw=0;
 lcd_e=0;
 lcd_d=cmd;
 lcd_e=1;
 delay_ms(1);
 lcd_e=0;
void lcd_write_dat(uchar dat)
 lcd_rs=1;
 lcd_rw=0;
 lcd_e=0;
 lcd_d=dat;
 lcd_e=1;
 delay_ms(1);
 lcd_e=0;
void lcd_init()
 lcd_write_cmd(0x38);
 delay_ms(1);
 lcd_write_cmd(0x01);
 delay_ms(1);
 lcd_write_cmd(0x0c);
 delay_ms(1);
 lcd_write_cmd(0x06);
 delay_ms(1);
