查看: 2090|回复: 0
msp430程序第二个中断无法执行,也就是进不去第二个中断
ID:511424 发表于 2019-4-20 21:47 来自触屏版 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <msp430.h>
* main.c
int main(void) {
    WDTCTL = WDTPW | WDTHOLD;        // Stop watchdog timer
    P1OUT =BIT3;
    P1REN |=BIT3;
        P1IE |=BIT3;
        P1IES |=BIT3;
        P1IFG &=~BIT3;
        P1OUT |=BIT2;
        _BIS_SR(GIE);
        while (1)
                if((P1OUT&BIT2)==0)
                        TA0CTL = TASSEL_1 + MC_1 + TACLR;
                        TA0CCTL0 = CCIE;
                        TACCR0 = 32768;       //30秒计时
                        _BIS_SR(GIE);
                        __no_operation();
#pragma vector=PORT1_VECTOR
__interrupt void Port_1(void)
        P1OUT &=~BIT2;
        P1IFG &= ~BIT3;
#pragma vector = TIMER0_A0_VECTOR
__interrupt void Timer_A(void)
        static int i=0;
        i++;
        if(i==30)
        P1OUT |=BIT2;
                __no_operation();
