查看: 4536|回复: 1
stm32发送到onenet的方法(程序+资料)
内容详细讲解STM32如何向onenet发送数据
  1. /**********************************************************
  2.
  3. 接线说明:
  4. STM32                 SIM868
  5. GND                <----->        GND
  6. PA2/TX2------>        RXD
  7. PA3/RX2<------        TXD
  8. RX1/PA10<------ GPS-T
  9. //用于调试可不接
  10. STM32                USB-TTL模块
  11. GND                ------>        GND
  12. TX1/PA9------>        RXD
  13. ***********************************************************/
  14. #include "stm32f10x.h"
  15. #include "delay.h"
  16. #include "usart.h"
  17. #include "led.h"
  18. #include "usart2.h"
  19. //常量
  20. #define Success 1U
  21. #define Failure 0U
  22. //定义变量
  23. unsigned long  Time_Cont = 0;       //定时器计数器
  24. char OneNetServer[] = "api.heclouds.com";       //不需要修改
  25. char device_id[] = "10252516";    //修改为自己的设备ID
  26. char API_KEY[] = "MI0I=4cUrvBA=brbvheeAMgNqTk=";    //修改为自己的API_KEY
  27. //char device_id[] = "10129834";    //修改为自己的设备ID
  28. //char API_KEY[] = "pkIGh8Qgk8QmVrlbNzMxRR4pKvk=";    //修改为自己的API_KEY
  29. char sensor_gps[] = "location";                                //不需要修改
  30. unsigned int count = 0;
  31. void errorLog(int num);
  32. void phone(char *number);
  33. unsigned int sendCommand(char *Command, char *Response, unsigned long Timeout, unsigned char Retry);
  34. void sendMessage(char *number,char *msg);
  35. void Sys_Soft_Reset(void);
  36. void parseGpsBuffer(void);
  37. void printGpsBuffer(void);
  38. void postGpsDataToOneNet(char* API_VALUE_temp, char* device_id_temp, char* sensor_id_temp, char* lon_temp, char* lat_temp);
  39. char* longitudeToOnenetFormat(char *lon_str_temp);
  40. char* latitudeToOnenetFormat(char *lat_str_temp);
  41. int Digcount(long num);
  42. int main(void)
  43. {
  44.         delay_init();
  45.
  46.         NVIC_Configuration();          //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
  47.         uart_init(115200);         //串口初始化为115200
  48.         USART2_Init(9600);        //串口2波特率9600
  49.         u2_printf("AT\r\n");
  50.         Init_LEDpin();
  51.
  52.
  53.
  54.         printf("Welcome to use!\r\n");
  55.         printf("ILoveMcu.taobao.com!\r\n");
  56.
  57.         if (sendCommand("AT\r\n", "OK\r\n", 3000, 10) == Success);
  58.         else errorLog(1);
  59.         delay_ms(100);
  60.         if (sendCommand("AT+CGCLASS=\"B\"\r\n", "OK\r\n", 3000, 2) == Success);
  61.         else errorLog(3);
  62.         delay_ms(100);
  63.         if (sendCommand("AT+CGDCONT=1,\"IP\",\"CMNET\"\r\n", "OK", 3000, 2) == Success);
  64.         else errorLog(4);
  65.         delay_ms(100);
  66.         if (sendCommand("AT+CGATT=1\r\n", "OK\r\n", 3000, 2) == Success);
  67.         else errorLog(5);
  68.         delay_ms(100);
  69.
  70.     if (sendCommand("AT+SAPBR=0,1\r\n", "AT+SAPBR", 3000, 5) == Success);//关闭承载,再重新打开
  71.         else errorLog(22);
  72.         delay_ms(100);
  73.
  74.     if (sendCommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\"\r\n", "OK\r\n", 3000, 2) == Success);
  75.         else errorLog(20);
  76.         delay_ms(100);
  77.
  78.     if (sendCommand("AT+SAPBR=3,1,\"APN\",\"CMNET\"\r\n", "OK\r\n", 3000, 2) == Success);
  79.         else errorLog(21);
  80.         delay_ms(100);
  81.
  82.     if (sendCommand("AT+SAPBR=1,1\r\n", "OK\r\n", 3000, 5) == Success);
  83.         else errorLog(22);
  84.         delay_ms(100);
  85.
  86.     if (sendCommand("AT+SAPBR=2,1\r\n", "OK\r\n", 3000, 3) == Success);
  87.         else errorLog(23);
  88.         delay_ms(100);
  89.
  90.     if (sendCommand("AT+CLBSCFG=0,3\r\n", "OK\r\n", 3000, 2) == Success);
  91.         else errorLog(24);
  92.         delay_ms(100);
  93.         clrStruct();
  94.         while(1)
  95.         {
  96.                 parseGpsBuffer();
  97.                 printGpsBuffer();
  98.         delay_ms(1000);
  99.         delay_ms(1000);
  100.         delay_ms(1000);
  101.         delay_ms(1000);
  102.         delay_ms(1000);
  103.         }
  104. }
  105. void parseGpsBuffer()
  106. {
  107.         char *subString;
  108.         char *subStringNext;
  109.         char i = 0;
  110.
  111.     if (sendCommand("AT+CLBS=1,1\r\n", "OK", 15000, 1) == Success)
  112.     {
  113.         printf("**************\r\n");
  114.                 printf(USART2_RX_BUF);
  115.         //+CLBS: 0,113.516557,22.269830,550
  116.         if ((subString = strstr((char *)USART2_RX_BUF, "+CLBS: 0")) != NULL)
  117.         {
  118.             for (i = 0 ; i <= 2 ; i++)
  119.             {
  120.                 if (i == 0)
  121.                 {
  122.                     if ((subString = strstr((char *)subString, ",")) == NULL)
  123.                     {
  124.                         Save_Data.isUsefull = false;
  125.                         errorLog(1);        //解析错误
  126.                     }
  127.                 }
  128.                 else
  129.                 {
  130.                     subString++;
  131.                     if ((subStringNext = strstr(subString, ",")) != NULL)
  132.                     {
  133.                         switch(i)
  134.                         {
  135.                             case 1:memcpy(Save_Data.longitude, subString, subStringNext - subString);break;        //获取经度信息
  136.                             case 2:memcpy(Save_Data.latitude, subString, subStringNext - subString);break;        //获取纬度信息
  137.                             case 3:memcpy(Save_Data.UTCTime, subString, subStringNext - subString);break;        //获取UTC时间
  138.                             default:break;
  139.                         }
  140.
  141.                         subString = subStringNext;
  142.                     }
  143.                     else
  144.                     {
  145.                         Save_Data.isUsefull = false;
  146.                         errorLog(2);        //解析错误
  147.                     }
  148.                     Save_Data.isUsefull = true;
  149.                 }
  150.             }
  151.         }else
  152.         {
  153.             Save_Data.isUsefull = false;
  154.             errorLog(25);
  155.         }
  156.         USART2_CLR_Buf();
  157.     }
  158.         else
  159.     {
  160.         Save_Data.isUsefull = false;
  161.         errorLog(25);
  162.     }
  163. }
  164. void printGpsBuffer()
  165. {
  166.                 if(Save_Data.isUsefull)
  167.                 {
  168.                         Save_Data.isUsefull = false;
  169.                         printf("Save_Data.latitude = ");
  170.                         printf(Save_Data.latitude);
  171.                         printf("\r\n");
  172.                         printf("Save_Data.longitude = ");
  173.                         printf(Save_Data.longitude);
  174.                         printf("\r\n");
  175.
  176.                         postGpsDataToOneNet(API_KEY, device_id, sensor_gps, Save_Data.longitude, Save_Data.latitude);                //发送数据到Onenet
  177.
  178.                         LED1 = 0;
  179.                         delay_ms(100);
  180.                         LED1 = 1;
  181.                 }
  182.                 else
  183.                 {
  184.                         printf("GPS DATA is not usefull!\r\n");
  185.                 }
  186. }
  187. int Digcount(long num)
  188. {
  189.         int i=0;
  190.         while(num>0)
  191.         {
  192.                 i++;
  193.                 num=num/10;
  194.         }
  195.   return i;
  196. }
  197. char* longitudeToOnenetFormat(char *lon_str_temp)                 //经度
  198. {
  199.         unsigned long lon_Onenet = 0;
  200.         unsigned int dd_int = 0;
  201.         unsigned long mm_int = 0;
  202.         float lon_Onenet_double = 0;
  203.         int i = 0;
  204.         unsigned long tempInt = 0;
  205.         unsigned long tempPoint = 0;
  206.         char result[20];
  207.         char point_result[15];
  208.         int pointLength = 0;
  209.         //51单片机没有double,double和float,精度不够,这里只能分开整数和小数换算。
  210.         sscanf(lon_str_temp, "%ld.%ld", &tempInt,&tempPoint);
  211.         lon_Onenet = tempInt%100;
  212.         pointLength = strlen(lon_str_temp) - 1 - Digcount(tempInt);
  213.         for( i = 0 ; i < pointLength ; i++)        //小数点几位,整数部分就放大10的几次方
  214.         {
  215.                 lon_Onenet *= 10;
  216.         }
  217.         dd_int = tempInt / 100; //取出dd
  218.         mm_int = lon_Onenet + tempPoint; //取出MM部分
  219.         mm_int = mm_int*10/6;                         //本来是除以60,这里*10/6为了多2位小数点有有效数字
  220.            sprintf(result,"%d.",dd_int);
  221.         for( i = 0 ; i < pointLength + 2 - Digcount(mm_int) ; i++)
  222.         {
  223.                 strcat(result, "0");
  224.         }
  225.         sprintf(point_result,"%ld",mm_int);
  226.         strcat(result, point_result);
  227. //        SendString("\r\n==========ONENET FORMART==========\r\n");
  228. //        SendString(result);
  229.         return result;
  230. }
  231. char* latitudeToOnenetFormat(char *lat_str_temp)                 //纬度
  232. {
  233.         unsigned long lat_Onenet = 0;
  234.         int dd_int = 0;
  235.         unsigned long mm_int = 0;
  236.         int i = 0;
  237.         unsigned long tempInt = 0;
  238.         unsigned long tempPoint = 0;
  239.         char result[20];
  240.         char  point_result[15];
  241.         int pointLength = 0;
  242. //        char xdata debugTest[30];
  243.
  244.         //51单片机没有double,double和float,精度不够,这里只能分开整数和小数换算。
  245.         sscanf(lat_str_temp, "%ld.%ld", &tempInt,&tempPoint);
  246.         lat_Onenet = tempInt%100;
  247.
  248. //        SendString("\r\n==========ONENET FORMART strlen(lat_str_temp)==========\r\n");
  249. //        sprintf(debugTest,"%d",strlen(lat_str_temp));
  250. //        SendString(debugTest);
  251.         pointLength = strlen(lat_str_temp) - 1 - Digcount(tempInt);
  252. //        SendString("\r\n==========ONENET FORMART pointLength==========\r\n");
  253. //        sprintf(debugTest,"%d",pointLength);
  254. //        SendString(debugTest);
  255.         for( i = 0 ; i < pointLength ; i++)        //小数点几位,整数部分就放大10的几次方
  256.         {
  257.                 lat_Onenet *= 10;
  258.         }
  259. //        SendString("\r\n==========ONENET FORMART tempPoint==========\r\n");
  260. //        sprintf(debugTest,"%ld",tempPoint);
  261. //        SendString(debugTest);
  262. //
  263. //        SendString("\r\n==========ONENET FORMART tempInt==========\r\n");
  264. //        sprintf(debugTest,"%ld",tempInt);
  265. //        SendString(debugTest);
  266. //
  267. //        SendString("\r\n==========ONENET FORMART lat_Onenet==========\r\n");
  268. //        sprintf(debugTest,"%ld",lat_Onenet);
  269. //        SendString(debugTest);
  270.         dd_int = tempInt / 100; //取出dd
  271.         mm_int = lat_Onenet + tempPoint; //取出MM部分
  272.         mm_int = mm_int*10/6;                         //本来是除以60,这里*10/6为了多2位小数点有有效数字
  273. //        SendString("\r\n==========ONENET FORMART mm_int==========\r\n");
  274. //        sprintf(debugTest,"%ld",mm_int);
  275. //        SendString(debugTest);
  276.
  277.         sprintf(result,"%d.",dd_int);
  278.         for( i = 0 ; i < pointLength + 2 - Digcount(mm_int) ; i++)
  279.         {
  280.                 strcat(result, "0");
  281.         }
  282.         sprintf(point_result,"%ld",mm_int);
  283.         strcat(result, point_result);
  284. //        SendString("\r\n==========ONENET FORMART==========\r\n");
  285. //        SendString(result);
  286.         return result;
  287. }
  288. void postGpsDataToOneNet(char* API_VALUE_temp, char* device_id_temp, char* sensor_id_temp, char* lon_temp, char* lat_temp)
  289. {
  290.         char send_buf[400] = {0};
  291.         char text[200] = {0};
  292.         char tmp[25] = {0};
  293.         char sendCom[2] = {0x1A};
  294. //        dtostrf(longitudeToOnenetFormat(lon_temp), 3, 6, lon_str_end); //转换成字符串输出
  295. //        dtostrf(latitudeToOnenetFormat(lat_temp), 2, 6, lat_str_end); //转换成字符串输出
  296. //        lon_temp = "11224.4992";
  297. //        lat_temp = "3438.1633";
  298.         //sprintf(lon_str_end,"%s", longitudeToOnenetFormat(lon_temp));
  299.         //sprintf(lat_str_end,"%s", latitudeToOnenetFormat(lat_temp));
  300.         //连接服务器
  301.         memset(send_buf, 0, 400);    //清空
  302.         strcpy(send_buf, "AT+CIPSTART=\"TCP\",\"");
  303.         strcat(send_buf, OneNetServer);
  304.         strcat(send_buf, "\",80\r\n");
  305.         if (sendCommand(send_buf, "CONNECT", 10000, 3) == Success);
  306.         else errorLog(7);
  307.         //发送数据
  308.         if (sendCommand("AT+CIPSEND\r\n", ">", 3000, 1) == Success);
  309.         else errorLog(8);
  310.         memset(send_buf, 0, 400);    //清空
  311.         /*准备JSON串*/
  312.         //ARDUINO平台不支持sprintf的double的打印,只能转换到字符串然后打印
  313. //        sprintf(text, "{\"datastreams\":[{\"id\":\"%s\",\"datapoints\":[{\"value\":{\"lon\":%s,\"lat\":%s}}]}]}"
  314. //                , sensor_id_temp, lon_str_end, lat_str_end);
  315.     sprintf(text, "{\"datastreams\":[{\"id\":\"%s\",\"datapoints\":[{\"value\":{\"lon\":%s,\"lat\":%s}}]}]}"
  316.                 , sensor_id_temp, lon_temp, lat_temp);
  317.         /*准备HTTP报头*/
  318.         send_buf[0] = 0;
  319.         strcat(send_buf, "POST /devices/");
  320.         strcat(send_buf, device_id_temp);
  321.         strcat(send_buf, "/datapoints HTTP/1.1\r\n"); //注意后面必须加上\r\n
  322.         strcat(send_buf, "api-key:");
  323.         strcat(send_buf, API_VALUE_temp);
  324.         strcat(send_buf, "\r\n");
  325.         strcat(send_buf, "Host:");
  326.         strcat(send_buf, OneNetServer);
  327.         strcat(send_buf, "\r\n");
  328.         sprintf(tmp, "Content-Length:%d\r\n\r\n", strlen(text)); //计算JSON串长度
  329.         strcat(send_buf, tmp);
  330.         strcat(send_buf, text);
  331.         if (sendCommand(send_buf, send_buf, 3000, 1) == Success);
  332.         else errorLog(9);
  333.
  334.         if (sendCommand(sendCom, "\"succ\"}", 6000, 1) == Success);
  335.         else errorLog(10);
  336.         delay_ms(100);
  337.         if (sendCommand("AT+CIPCLOSE\r\n", "CLOSE OK", 3000, 1) == Success);
  338.         else errorLog(11);
  339.         delay_ms(100);
  340.         if (sendCommand("AT+CIPSHUT\r\n", "SHUT OK", 3000, 1) == Success);
  341.         else errorLog(11);
  342.         delay_ms(100);
  343. }
  344. void sendMessage(char *number,char *msg)
  345. {
  346.         char send_buf[20] = {0};
  347.         memset(send_buf, 0, 20);    //清空
  348.         strcpy(send_buf, "AT+CMGS=\"");
  349.         strcat(send_buf, number);
  350.         strcat(send_buf, "\"\r\n");
  351.         if (sendCommand(send_buf, ">", 3000, 10) == Success);
  352.         else errorLog(6);
  353.         if (sendCommand(msg, msg, 3000, 1) == Success);
  354.         else errorLog(7);
  355.         delay_ms(100);
  356.         memset(send_buf, 0, 100);    //清空
  357.         send_buf[0] = 0x1a;
  358.         if (sendCommand(send_buf, "OK\r\n", 10000, 5) == Success);
  359.         else errorLog(8);
  360.         delay_ms(100);
  361. }
  362. void errorLog(int num)
  363. {
  364.         printf("ERROR%d\r\n",num);
  365.         while (1)
  366.         {
  367.                 if (sendCommand("AT\r\n", "OK", 100, 10) == Success)
  368.                 {
  369.                         Sys_Soft_Reset();
  370.                 }
  371.                 delay_ms(200);
  372. ……………………
  373. …………限于本文篇幅 余下代码请从51黑下载附件…………
OneNet平台应用资料.7z (798.71 KB, 下载次数: 58)
ID:193811 发表于 2019-6-20 22:35 | 只看该作者
为啥那两个工程的资料包在keil5里打不开呢?
