查看: 1213|回复: 0
刚学的刮雨器编程
ID:525749 发表于 2019-5-1 21:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//12M,T042us,19.80ms,9~        45        ?
#include <reg52.h>
sbit PWM1=P3^0;
sbit KEY1=P2^6;
uint aa;
uint xx;
uint jiajainum;
/******************** ??1??@12.000MHz?? **************************/
void delay1ms(unsigned int a)   //?? 0us
    unsigned int b;
        while(a--)
                for(b=0;b<600;b++);
void tuoji_init()//50
    TMOD = 0x01;
    TH0 = 0x0FF;
    TL0 = 0x0CE;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
PWM1=1;
void chudong_pwm(uchar temp1)
if(aa==temp1) // ??9-28-45(??90?,???,??90?);
  PWM1=0;
void keyscan()
                if(KEY1==0)//????1
                delay1ms(3);
                if(KEY1==0)
                        while(!KEY1);
                        //xx++;
xx=9;
tuoji_init();
         keyscan();
        if(xx>45)
                xx=9;
void dingshi0() interrupt 1
    TH0 = 0x0FF;
    TL0 = 0x0CE;
        chudong_pwm(xx);
aa++;
jiajainum++;
if(jiajainum>2000)
         jiajainum=0;
         xx++;
if(aa==387)
  aa=0;
  PWM1=1;
