查看: 1799|回复: 0
stc12单片机三路AD采集两路PWM控制,1602显示。能帮我修改一下程序里的错误吗
ID:511561 发表于 2019-5-2 09:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
   /* ????????12C5A60S2???AD???????·??????????1602?? */
/*   ??????????????8·?????????P1ASF   ????????????   */
#include "stdio.h"
//#include "STC12C5A60S2.H"
#include <reg51.h>
#include "lcd1602.h "
#include<intrins.h>
#define uchar unsigned char;
#define uint unsigned int;
#define ADC_OFF() ADC_CONTR = 0
#define ADC_ON  (1 << 7)
#define ADC_90T  (3 << 5)
#define ADC_180T (2 << 5)
#define ADC_360T (1 << 5)
#define ADC_540T 0
#define ADC_FLAG (1 << 4) //?????t??0
#define ADC_START (1 << 3) //????????0
#define ADC_CH0  0
#define ADC_CH1  1
#define ADC_CH2  2
#define ADC_CH3  3
#define ADC_CH4  4
#define ADC_CH5  5
#define ADC_CH6  6
#define ADC_CH7  7
sfr P1ASF     = 0x9D; //12C5204AD/S2????D????a??????(AD???LVD)????
sfr ADC_CONTR = 0xBC; //AD???????
sfr ADC_RES   = 0xBD; //??8λ
sfr ADC_RESL  = 0xBE; //??2λ
sbit EADC     = IE^5; //AD ?ж?
//pwm ????
//#define FOSC 18432000L
sfr CCON=0xD8;
sbit CCF0=CCON^0;
sbit CCF1=CCON^1;
sbit CR=CCON^6;
sbit CF=CCON^7;
sfr CMOD=0xD9;
sfr CL=0XE9;
sfr CH=0XF9;
sfr CCAPM0=0XDA;
sfr CCAP0L=0XEA;
sfr CCAP0H=0XFA;
sfr CCAPM1=0XDB;
sfr CCAP1L=0XEB;
sfr CCAP1H=0XFB;
sfr PCAPWM0=0XF2;  //p1.3
sfr PCAPWM1=0XF3;  //p1.4
sbit PWM1=P3^0;
sbit PWM2=P3^1;
unsigned char num=0,num1=0;
unsigned code table1[]={101.5,102,102.8,103};     //3.01 2.99  2.97
unsigned code table2[]={204,100,252,53};
//uchar b,i,ge,shi,bai;
uchar da1=0,da2=0,da3=0; da4=0;
double Data,c;
char a[5]="";
uchar ADC_Chanul_Turn=0;
                  ADC????
void InitADC()//???AD?????
         P1ASF=0X27;     //0xff????P1??????ADC???,0x07=0000,1111  ?????P10(??????5),P11,P12 p15???????
        ADC_RES=0X00;    //?????8λ????????
        if(ADC_Chanul_Turn%5==0)//????????
            ADC_CONTR=0xF0; //AD???????????,1111,0000  P10??
            _nop_();
            _nop_();
            _nop_();
            _nop_();
            ADC_CONTR=0xE8;    //1110,1000??????Flag????λStart??
        if(ADC_Chanul_Turn%5==1)
            ADC_CONTR=0xF1; // 1111,0001  P11??
            _nop_();
            _nop_();
            _nop_();
            _nop_();
            ADC_CONTR=0xE9;    //1110,1001
         if(ADC_Chanul_Turn%5==2)
            ADC_CONTR=0xF2; //1111,0010  P12??
            _nop_();
            _nop_();
            _nop_();
            _nop_();
            ADC_CONTR=0xEA;    //1110,1010
        if(ADC_Chanul_Turn%5==4)
            ADC_CONTR=0xF5; //1111,0101  P15??
            _nop_();
            _nop_();
            _nop_();
            _nop_();
            ADC_CONTR=0xED;    //1110,1101
void timer0() interrupt 1      //interrupt 1: ?????0??interrupt3???????3
    TH0=(65536-20000)/256;       //???λ??????????Xms??????????????65536-X????65536,????16λ????????λ??
    TL0=(65536-20000)%256;     //???λ
     InitADC();
void adc_isr() interrupt 5      //FLAG???λ??λ?????ж??????????????????????????????0????
   //V_5REF=V_1REF*256/da_ref;
   if(ADC_Chanul_Turn%5==0)                     //????????
       da1=ADC_RES;                                   //?????????
       Data=((double)da1/256)*5;     //???λ?????????Data,
       c =Data;
       da2=ADC_RES;                                  //?????????
       Data=((double)da2/256)*5;     //???λ????????Data,
       c =Data;
       da3=ADC_RES;                                  //?????????
       Data=((double)da3/256)*5;     //???λ????????Data,
       c =Data;
       da4=ADC_RES;                                  //?????????
       Data=((double)da4/256)*5;     //???λ????????Data,
       c =Data;
   a[0]=((int)c%10+0x30);//??λ?????<5,???и???     //0x30: ASCAI????????0??,?????????????????????????????????1602??????????
   a[1]=0x2e;                    //С????
   a[2]=((int)(c*10)%10+0x30); // ???λ
   a[3]=((int)(c*100)%10+0x30);// ???λ
//a[4]=((int)(c*1000)%10+0x30);
   a[4]='\0';                  //  ?????β?????????????
   //if(ADC_Chanul_Turn%5==0)  LCD_Write_String(0,0,a);
  if(ADC_Chanul_Turn%5==1)  LCD_Write_String(2,0,a);
  if(ADC_Chanul_Turn%5==2) LCD_Write_String(7,0,a);
  if(ADC_Chanul_Turn%5==4) LCD_Write_String(12,0,a);
   ADC_CONTR&=0xEF;               //???λ????
   ADC_Chanul_Turn++;
   if(ADC_Chanul_Turn==255)
      ADC_Chanul_Turn=0;
//PWM ????
void init_PWM()
CCON=0;
CL=0;
CH=0;
CR=1;
CMOD=0X00; //??????PWM??????
//CCAP0H=CCAP0L=0X1E;
PCAPWM0=0X00;
//CCAPM0=0X42;  //?????PWM
// CCAP1H=CCAP1L=0X80;
PCAPWM1=0X00;
// CCAPM1=0X42;CR=1;        //????????????
void key_Contral_PWM(void);
void  delay(int z)
unsigned int x,y;
for(x=z;x>0;x--)
for(y=100;y>0;y--);
    LCD_Init();
LCD_Clear();                     //????
    init_PWM();
InitADC();
  // LCD_Write_Char(2,1,"??");
      DelayMs(255);
TH0=(65536-20000)/256;           //???????0
    EA=1;                             //??????ж?
    ET0=1;                            //???????????ж?
    EADC=1;                          //????ADC?ж?
    TR0=1;
while (1)
    CCAP0H = CCAP0L =table1[num];
    CCAPM0 = 0x42;
    CCAP1H = CCAP1L = table2[num1];
                CCAPM1 = 0x42;
              key_Contral_PWM();
       if(num==4)
       num=0;
    if(num1==4)
            num1=0;
  if(PWM1==0)
   delay(20);
  if(PWM1==0)
      num++;
   while(!PWM1);
  if(PWM2==0)
  delay(20);
  if(PWM2==0)
       num1++;
   while(!PWM2);
AD数据现在只显示了两路,而且还无法及时刷新。p10口做基准电压,P11 12 15 口做三路AD。
两路PWM控制DA输出
主程序不知道怎么改。求助
