查看: 1750|回复: 0
单片机GPS检测程序 通过短信控制LED灯
ID:526724 发表于 2019-5-3 23:50 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
include "string.h"
#include "delay.h"
#include "uart.h"
#include "timer0.h"
#include "SIMxxx.h"
sbit P10=P1^0;        //用于提示程序进行到哪里
sbit P11=P1^1;        //用于提示程序进行到哪里
sbit RUNING_LED=P1^2;        //程序中控制的LED灯
unsigned char xdata Display_GPGGA_Buffer[68]={0};                //用于储存GPGGA的数据
unsigned int k=0,qian_a=0,hou_a=0,qian_b=0,hou_b=0,qian_c=0,hou_c=0;        //存储前后逗号的位置序号的变量
bit qian_OK=0;                   //已找出前面的逗号的标志变量
//bit First_Share_OK=0;  //已开始LCD显示的标志变量
bit jiajian=1;                    //进行加或减的标志变量
//bit Page = 0;
bit Flag_Calc_GPGGA_OK = 0;           //GPGGA完整有效的数据已收到的标志变量
//u8 NUM[][10]={"0030","0031","0032","0033","0034","0035","0036","0037","0038","0039"};//数字编码
//char a[10]={0,1,2,3,4,5,6,7,8,9};
//int x;
/*************  外部函数和变量声明*****************/
* 函数名 : main
* 描述   : 主函数
* 输入   :
* 输出   :
* 返回   :
* 注意   :
void main(void)
        unsigned char i = 0;
        u8 res;
        Uart1Init();
        Timer0Init();
        EA=1;        //开总中断
        res=1;
        P10=0;P11=0;
        while(res)
                res=sim900a_work_test();
        res=1;
        while(res)
                res=sim900a_enmessage_mode_out();
        P10=1;
        res=1;
        Delay_ms(10);
        clrStruct();
                parseGpsBuffer();
                if(Flag_Rec_Message==1)
                        Flag_Rec_Message=0;
                        res=SIM_HANDLE_MESSAGE_CMD();
                        if (
                           Flag_Calc_GPGGA_OK  == 1
                && RX_Buffer[1] == 'G'
                && RX_Buffer[3] == 'G'
                && RX_Buffer[4] == 'G'
                && RX_Buffer[5] == 'A'
                && (RX_Buffer[28] == 'N'|| RX_Buffer[28] == 'S')
                && (RX_Buffer[41] == 'E'|| RX_Buffer[41] == 'W')
                                )        //确认是否收到"GPGGA"这一帧完整有效的数据
                        if(res)
                                if(res==1)
                                RUNING_LED=1;
//                                if(res==1)
//                                        for(x=0;x<10;x++)
//                                                a[x]=NUM[x];
                                res=sim900a_send_chmessage("00310037003600380039003200380039003000310039","4F60597D00680065006C006C006F");
                                else if(res==2)
                                RUNING_LED=0;
//                                if(res==2)
//                                                a[x]=NUM[x];
void errorLog(int num)
        while (1)
                  UartPrintf("ERROR");
                UartPrintASCII(num+0x30);
                UartPrintf("\r\n");
void parseGpsBuffer()
        char *subString;
        char *subStringNext;
        char i = 0;
        if (Save_Data.isGetData)
                Save_Data.isGetData = false;
                UartPrintf("**************\r\n");
                UartPrintf(Save_Data.GPS_Buffer);
                for (i = 0 ; i <= 6 ; i++)
                        if (i == 0)
                                if ((subString = strstr(Save_Data.GPS_Buffer, ",")) == NULL)
                                        errorLog(1);        //解析错误
                                subString++;
                                if ((subStringNext = strstr(subString, ",")) != NULL)
                                        char usefullBuffer[2];
                                        switch(i)
                                                case 1:memcpy(Save_Data.UTCTime, subString, subStringNext - subString);break;        //获取UTC时间
                                                case 2:memcpy(usefullBuffer, subString, subStringNext - subString);break;        //获取UTC时间
                                                case 3:memcpy(Save_Data.latitude, subString, subStringNext - subString);break;        //获取纬度信息
                                                case 4:memcpy(Save_Data.N_S, subString, subStringNext - subString);break;        //获取N/S
                                                case 5:memcpy(Save_Data.longitude, subString, subStringNext - subString);break;        //获取经度信息
                                                case 6:memcpy(Save_Data.E_W, subString, subStringNext - subString);break;        //获取E/W
                                                default:break;
                                        subString = subStringNext;
                                        Save_Data.isParseData = true;
                                        if(usefullBuffer[0] == 'A')
                                                Save_Data.isUsefull = true;
                                        else if(usefullBuffer[0] == 'V')
                                                Save_Data.isUsefull = false;
                                        errorLog(2);        //解析错误
void printGpsBuffer()
        if (Save_Data.isParseData)
                Save_Data.isParseData = false;
                UartPrintf("Save_Data.UTCTime = ");
                UartPrintf(Save_Data.UTCTime);
                UartPrintf("\r\n");
                if(Save_Data.isUsefull)
                        UartPrintf("Save_Data.latitude = ");
                        UartPrintf(Save_Data.latitude);
                        UartPrintf("\r\n");
                        UartPrintf("Save_Data.N_S = ");
                        UartPrintf(Save_Data.N_S);
                        UartPrintf("\r\n");
                        UartPrintf("Save_Data.longitude = ");
                        UartPrintf(Save_Data.longitude);
                        UartPrintf("\r\n");
                        UartPrintf("Save_Data.E_W = ");
                        UartPrintf(Save_Data.E_W);
                        UartPrintf("\r\n");
                        UartPrintf("GPS DATA is not usefull!\r\n");
8 通过短信控制LED灯-STC89C52.zip
188.33 KB, 下载次数: 10, 下载积分: 黑币 -5
