查看: 1730|回复: 0
电子密码锁程序求解释
ID:517944 发表于 2019-5-7 14:40 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include<string.h>
#include<intrins.h>
//#define     LCDIO      P2
#define delay4us() _nop_();_nop_();_nop_();_nop_();
uchar buffer[6]="123456";
sbit sda        =        P3^6;
sbit scl        =        P3^5;
sbit beep        =        P2^1;
sbit wp                =        P3^4;
bit flag        =        0,aa;                                //用户蹲渊义定时溢出标志位
uchar  DSY_BUFFER[16]="                ";
uchar  DSY_BUFFER1[16]="                ";
uchar  Userpassword[6]={0};
sbit rs                =        P2^4;
sbit rd                =        P2^5;
sbit lcden        =        P2^6;
sbit led        =        P2^0;
sbit back        =        P2^3;
sbit IN_1        =        P3^0;
sbit IN_2        =        P3^1;
uchar code table2[]="432518";          //管理员密码
uchar code table[]="Your Password...";
void delayms(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void delay()                        //短延时,两个机器周期,做总线的延时用
void write_com(uchar com)
        rs=0;
        rd=0;
        lcden=0;
        P0=com;
        delayms(3);
        lcden=1;
        delayms(3);
        lcden=0;
void write_date(uchar date)
        rs=1;
        rd=0;
        lcden=0;
        P0=date;
        delayms(3);
        lcden=1;
        delayms(3);
        lcden=0;
void Display_String(uchar *p,uchar com)
{  uchar i;
   write_com(com);
   for(i=0;i<16;i++)
   write_date(p[i]);
void init_lcd()
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
    Display_String(table,0x80);
        Display_String("Lock OK!         ",0xc0);
void start()
        sda=1;
        scl=1;
        delay4us();
        sda=0;
        delay4us();
        scl=0;
void stop()
        sda=0;
        scl=1;
        delay4us();
        sda=1;
        delay4us();
        scl=0;
void init()                                                        //初始化
sda=1;
delay();
scl=1;
delay();
void ack()
        sda=0;
        scl=1;
        delay4us();
        scl=0;
        sda=1;
void noack()
        sda=1;
        scl=1;
        delay4us();
        scl=0;
        sda=0;
uchar recbyte()
        uchar i,rd;
        rd=0x00;
        sda=1;
        for(i=0;i<8;i++)
                scl=1;
                rd<<=1;
                rd|=sda;
                delay4us();
                scl=0;
                delay4us();
        scl=0;
        delay4us();
        return rd;
uchar sendbyte(uchar wd)
        uchar i;
        bit ack0;
        for(i=0;i<8;i++)
                sda=(bit)(wd&0x80);
                _nop_();
                _nop_();
                scl=1;
                delay4us();
                scl=0;
                wd<<=1;
        delay4us();
        sda=1;
        scl=1;
        delay4us();
        ack0=!sda;
        scl=0;
        delay4us();
        return ack0;
uchar Recstring(uchar slave,uchar subaddr,uchar *buffer,uchar n)
uchar i;
start();
if(!sendbyte(slave)) return 0;
if(!sendbyte(subaddr)) return 0;
start();
if(!sendbyte(slave+1)) return 0;
for(i=0;i<n-1;i++)
          buffer[i]=recbyte();
        ack();
buffer[n-1]=recbyte();
noack();
stop();
return 1;
uchar Sendstring(uchar slave,uchar subaddr,uchar *buffer,uchar n)
        uchar i;
        start();
        for(i=0;i<n;i++)
                if(!sendbyte(buffer[i])) return 0;
        stop();
        return 1;
void clear_password()
{        uchar i;
        for(i=0;i<6;i++)
         Userpassword[i]=' ';
        for(i=0;i<16;i++)
           DSY_BUFFER[i]=' ';
uchar Keys_Scan()
        uchar temp,keynum;
        P1=0xF0;
        delayms(5);
        temp=P1;
        switch(temp)
                case 0xE0:keynum=0;break;
                case 0xD0:keynum=1;break;
                case 0xB0:keynum=2;break;
                case 0x70:keynum=3;break;
                break;
        delayms(200);
        P1=0x0F;
        temp=P1;
        switch(temp)
                case 0x0E:keynum+=0;break;
                case 0x0D:keynum+=4;break;
                case 0x0B:keynum+=8;break;
                case 0x07:keynum+=12;break;
                break;
        delayms(200);
   return keynum;
{   uchar temp,i=0,j=0,k=0,n;
        uchar IS_valid_user;
        uchar num_dec=100;         //延时自动上锁
        beep=1;
        wp=0;
        back=0;
        init();
    init_lcd();
        delayms(5);
//        aa=Sendstring(0xa0,1,table2,6);
        delayms(5);
        aa=Recstring(0xa0,1,buffer,6);
        delayms(10);
         P1=0xF0;
//         P3=0xFF;
         delayms(2000);
                  delayms(5);
                                                        if(IN_2==0)
        delayms(20);
        led=0;
        Display_String("OPEN    OK!      ",0xc0);
        beep=0;
        delayms(200);
        beep=1;
        while(IN_2==0);
        delayms(1200);
        delayms(1200);
        led=1;
                  P1=0xF0;delayms(5);
                  if(P1!=0xF0)
                            temp=Keys_Scan();
                            switch(temp)
                       case 0:  case 1: case 2: case 3: case 4:
                       case 5:  case 6: case 7: case 8: case 9:
                       if (i<=5)             //密码限制在6位以内
                        Userpassword[i]=temp;
                        DSY_BUFFER[i]=temp+48;
                        Display_String(DSY_BUFFER,0xc0);
                                                i++;
                        break;
                        case 10: //按A键开锁
                                                flag=1;
                                                for(k=0;k<6;k++)
                                                  if(buffer[k]!=(Userpassword[k]+48)&&(Userpassword[k]+48)!=table2[k])
                                                  flag=0;
                        if (flag==1)
                        { flag=0;
                                                  i=0;
                          led=0;  //点亮LED
                                                  num_dec=100;
                           clear_password();
                           IS_valid_user = 1;
                                                   j=0;
                                                   beep=0;
                                                      delayms(200);
                                                   beep=1;
                                                 j++;
                         led=1;   //关闭LED
                         clear_password();
                         Display_String("ERROR!Have try   ",0xc0);
                                                 write_com(0xcf);
                                                 write_date(0x30+j);
                         IS_valid_user=0;
                        i=0;
                        break;
                      case 11: //按B键上锁
                      led=1;
                      clear_password();
                      i=0;
                      IS_valid_user=0;
                      break;
                      case 12: //按C键设置新密码
                       //如果是合法用户则提示输入新密码
                      if ( !IS_valid_user)
                                           i=0;
                                           Display_String("No rights !      ",0xc0);
                                           beep=0;
                                           delayms(200);
                                           beep=1;
                                           Display_String("Your Password...",0x80);
                          i=0;
                          Display_String("New Password:   ",0x80);
                          Display_String("                ",0xc0);
                       break;
                      case 13: //按D键保存新密码
                                          {         i=0;
                                                 beep=0;
                                                    delayms(200);
                                                 beep=1;
                      {i = 0;
                                           init();
                                           delayms(5);
                                           for(k=0;k<6;k++)
                                                   Userpassword[k]=Userpassword[k]+48;
                       aa=Sendstring(0xa0,1,Userpassword,6);
                                           delayms(10);
                                           delayms(10);
                       clear_password();
                       Display_String(table,0x00);
                       Display_String("Password Saved!   ",0xc0);
                                           delayms(1000);
                                           Display_String("Do lock agian ?   ",0xc0);
                      break;
                      case 14: //按E键消除所有输入
                      i=0;
                      clear_password();
                                          break;
                                          case 15:         //清除一位
                                           if(i!=0)i--;
                                           for(n=0;n<i;n++)
                                                   DSY_BUFFER1[n]='*';
                                           Display_String(DSY_BUFFER1,0xc0);
                                          while(P1!=0x0F);
                                          P1=0xF0;
                                         // while(P1==0xF0)
                        if(j==3)
                        {        Display_String("THIEF!!!THIEF!!!",0xc0);
                                j=0;
                                beep=0;
