查看: 5488|回复: 3
关于51单片机modbus通讯程序的请教
本人小白,在网上找了一个51 单片机modbus通讯的从机程序,编译后提示好像是缺少modbus校验的部分,请各位大佬帮忙看看这个程序怎么添加modbus部分。(老师只要求了功能码03读寄存器)
  1. #include "reg52.h"
  2. typedef unsigned char uint8;
  3. typedef unsigned int uint16;
  4. typedef unsigned long uint32;
  5. #define TIMER_HIGHT 0xf8
  6. #define TIMER_LOW 0xcd
  7. sbit bRunLED =P3^4; //运行指示灯
  8. sbit bWatchDog =P1^7; //看门狗复位
  9. sbit b485Send= P1^3; //75LBC184 发送接收控制
  10. uint32  dwTickCount,dwIntTick;  //时钟
  11. uint8   idata sendBuf[16],receBuf[16]; //发送接收缓冲区
  12. uint8   idata checkoutError;    // ==2 偶校验错
  13. uint8   idata receTimeOut;      //接收超时
  14. uint8   idata c10ms;            //10ms 计时
  15. bit     b1ms,bt1ms,b10ms,bt10ms,b100ms,bt100ms; //定时标志位
  16.
  17. // 串行中断程序
  18. void commIntProc() interrupt 4
  19. {
  20.     if(TI)
  21.     {
  22.         TI = 0;
  23.         if(sendPosi < sendCount)
  24.         {
  25.             sendPosi++;
  26.             ACC = sendBuf[sendPosi];
  27.             TB8 = P;    //加上校验位
  28.             SBUF = sendBuf[sendPosi];
  29.         }
  30.         else
  31.         {
  32.             b485Send = 0;    //发送完后将485置于接收状态
  33.             receCount = 0;   //清接收地址偏移寄存器
  34.             checkoutError = 0;
  35.         }
  36.     }
  37.     else if(RI)
  38.     {
  39.         RI = 0;
  40.         receTimeOut = 10;    //通讯超时值
  41.         receBuf[receCount] = SBUF;
  42.         ACC = receBuf[receCount];
  43.         if(P != RB8)
  44.             checkoutError = 2;  //偶校验出错
  45.         receCount++;          //接收地址偏移寄存器加1
  46.         receCount &= 0x0f;    //最多一次只能接收16个字节
  47.     }
  48.
  49. }   // void CommIntProc()
  50.
  51. //定时器0 1ms 中断
  52. void timer0IntProc() interrupt 1
  53. {
  54.     TL0 = TIMER_LOW;
  55.     TH0 = TIMER_HIGHT;
  56.     dwIntTick++;
  57.     bt1ms = 1;
  58.     c10ms++;
  59.     if(c10ms >= 10)
  60.     {
  61.         c10ms = 0;      //10ms计时器清零
  62.         bt10ms = 1;
  63.     }
  64. }   // void Timer0IntProc()
  65.
  66. //外部中断0
  67. void intEx0Proc(void) interrupt 0
  68. {
  69.
  70. }
  71.
  72. //计数器1中断
  73. void counter1IntProc(void) interrupt 3 using 1
  74. {
  75.
  76. }
  77. //定时处理
  78. void timeProc(void)
  79. {
  80.     static uint8 c200ms;
  81.     bWatchDog = ~ bWatchDog;    //看门狗取反
  82.     b1ms = 0;
  83.     b10ms = 0;
  84.     b100ms = 0;
  85.     ET0 = 0;
  86.     dwTickCount = dwIntTick;
  87.     ET0 = 1;
  88.     if(bt1ms)
  89.     {
  90.         bt1ms = 0;
  91.         b1ms = 1;
  92.         if(receTimeOut>0)
  93.         {
  94.             receTimeOut--;
  95.             if(receTimeOut==0 && receCount>0)   //判断通讯接收是否超时
  96.             {
  97.                 b485Send = 0;       //将485置为接收状态
  98.                 receCount = 0;      //将接收地址偏移寄存器清零
  99.                 checkoutError = 0;
  100.             }
  101.         }
  102.     }
  103.     if(bt100ms)
  104.     {
  105.         bt100ms = 0;
  106.         b100ms = 1;
  107.     }
  108.     if(bt10ms)      //判断中断10ms标志位是否1
  109.     {
  110.         bt10ms = 0;     //清中断10ms标志位
  111.         b10ms = 1;
  112.
  113.         c200ms++;                   //200ms计时器加1
  114.         if(c200ms >= 20)            //判断是否计时到200ms
  115.         {
  116.             c200ms = 0;             //清200ms计时器
  117.             bRunLED = ~bRunLED;     //取反运行指示灯
  118.         }
  119.     }
  120. }   // void TimerProc(void)
  121.
  122. //初始化串口
  123. void initUart(void)
  124. {
  125.     //T2 用于波特率 9600
  126.     T2CON = 0x30;
  127.     RCAP2H = 0xff;
  128.     RCAP2L = 0xb8;
  129.     TR2 = 1;
  130.     //偶校验
  131.     SCON = 0xd0;
  132.     PCON = 0;
  133.     ES = 1;
  134. }//void initUart(void)
  135.
  136. //初始化中断
  137. void initInt(void)
  138. {
  139.     TMOD = 0x51;
  140.     TH0 = TIMER_HIGHT;
  141.     TL0 = TIMER_LOW;
  142.     TR0 = 1;
  143.     ET0 = 1;
  144.     TH1 = 0;            //9600
  145.     TL1 = 0;
  146.     TR1 = 0;            //定时器1用于计数定时器2用于波特
  147.     ET1 = 1;
  148.     IT0 = 1;
  149.     IT1 = 1;
  150.     EX0 = 0;
  151.     PX0 = 1;
  152.     EX1 = 0;
  153.     initUart();
  154.     EA = 1;
  155. }   // void initInt(void)
  156.
  157. //初始化
  158. void initProg(void)
  159. {
  160.     initInt();
  161.     b485Send = 0;
  162. }
  163. void main(void)
  164. {
  165.     initProg();
  166.
  167.     while(1)
  168.     {
  169.         timeProc();
  170.         checkComm0Modbus();
  171.     }
  172. }
ID:93224 发表于 2019-5-19 18:45 | 只看该作者
问题解决了吗?
加我的QQ 1014461948我可以帮助你解决
ID:578727 发表于 2020-5-27 10:09 | 只看该作者
你好,可以知道一下单片机做从机的MODBUS程序吗,刚做这个不知道怎么下手
